CANADA Canada
Old 05-31-2015, 09:38 PM   #29
wbradley
Sarcastic SOB
wbradley's Avatar
I have read that high ZDDP levels sometimes damage the cats.
Old 06-01-2015, 09:28 AM   #30
Hagbard
Hagbard's Avatar
AMSOil in motor last 2 changes i do have amsoil gear oil for the dif and tranny but not in any hurry to change that right now.
Hagbard is offline   Reply With Quote
Old 06-01-2015, 03:30 PM   #31
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Ah okay that explains that rotten egg smell I used to get after an oil change.
I've read that competition oils like Motul 300V is really bad for the cat.
Had no choice cuz the early VAG 2.0T came with a flat tappet cam follower and without adequate ZDDP the high pressure fuel pump will punch a hole thru it, destroying the camshaft lobe in the process. That engine also tend to burn a lot of oil when running Mobil 1 0W40 or Castrol SLX 5W40 compare to Motul 8100 5W40.
FA20 I think Mobil 1 0W40 should be okay since this engine doesn't burn oil even with a light oil like 0W20. I think Mobil 1 always comes out all black during an oil change which to me means it holds dirt very well in suspension. I understand Mobil 1 also comes in a 5W50 weight.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
wbradley (06-01-2015)
Old 03-10-2018, 04:23 PM   #32
Dru670
Drives: 2016 Scion FR-S
How is that RP in your trans and diff so far? Planning on trying RP for my trans and diff also.
Originally Posted by JEDI View Post
I used Royal Purple 0w-20 for engine.
Royal Purple 75w-90 for both Trans and Diff.
Here's a pic of my Differential Drain Plug after 9900 miles.
I bought the car with 9560. I'm hearing this is common in our cars, but not fact. Sorry for the huge pic.
Dru670 is offline   Reply With Quote
AT Trans Shift Knob Replacement sapphire Cosmetic Modification (Interior/Exterior/Lighting) 7 11-15-2012 12:08 AM
How many hp more can the AT trans handle? K-R Scion FR-S / Toyota 86 GT86 General Forum 1 08-18-2012 02:21 PM
Sat Aug. 25th, Trans Am Nationals Cruise In oops86 Other Vehicles & General Automotive Discussions 1 08-09-2012 11:09 PM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 09:41 PM
Launch control with auto trans Dbringer Scion FR-S / Toyota 86 GT86 General Forum 3 06-12-2012 05:54 PM
