#29 | |||
Drives: 2014 BRZ Limited
Man, talk about thread necro.
First, if the light comes on with 2 gallons left, and you only have 15 miles left, that means you're only getting 7.5 miles per gallon in a car designed to get as much as 35 mpg. So right off the bat that's telling me either you're making wild guesses without thinking about them, or something is seriously wrong with your car. Second, it's not possible to pump 13.07 gallons into this tank unless it's a completely empty tank that was just installed with no fuel in it. That's because although this is a 13.2 gallon tank, only 12.5 gallons are usable. The pickup is situated above the bottom of the tank so that it does not suck in water or sediment. You could not drive up to a pump and pump 13.07 gallons unless you spilled some of it. The car will quit before that with 1/2 gallon still in the tank. If the pump actually said you pumped 13.07 gallons, it was wrong. That happens. I had a pump read that I pumped 21 gallons into a 20 gallon tank once. If that happens, you can report it to your state government, and they will sometimes send out someone to inspect the pumps and fine the gas station for tampering with them to make more money. Now, to answer your question directly, I monitor my fuel remaining in Torque, which reads it out as gallons, and my low fuel light seems to come on consistently at 2.4 gallons. That means there are about 3 gallons still in the tank, with 2.4 gallons available to me. At my normal fuel economy, I should be able to drive at least another 60 miles before running out of gas. And in case anybody reads this ancient thread and believes some of the stuff that was posted: Quote:
| The Following 2 Users Say Thank You to extrashaky For This Useful Post: | Chaetagnath (08-22-2015), dentalprodigy (08-22-2015) |
#30 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
I can put 14+ gallons in my 13.2 gallon tank If I want. Fill the filler neck etc. Not recommended. I always run until the light comes on most of the time filling up @ well over 400 miles. Not worried about sediment etc.
#31 |
Drives: RAVEN
I first heard about not running the tank on empty from my mechanic. He claims that he gets a lot of fuel pump work when the price of gas is high because people run with lower fuel level hoping for the price to drop or because they cant afford it.
| ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! | ZILLA | DIY (Do-It-Yourself) Guides | 117 | 09-19-2017 11:17 AM |
| Check engine light just came on after 2k miles. | danthedirt | Issues | Warranty | Recalls / TSB | 604 | 01-31-2015 05:26 PM |
| experiencing tail light + fog light condensation? | whyreeto | AUSTRALIA | 20 | 01-15-2013 12:15 AM |
| Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! | DjDATZ | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 06-28-2012 12:21 PM |
| I saw, I went I left a deposit :D | 86design | BRZ First-Gen (2012+) — General Topics | 350 | 02-29-2012 10:32 PM |
