Old 05-21-2013, 01:45 PM   #29
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by shirker View Post
Subscribed, looking forward to this guide and very much so
What's there to look forward to? Read posts after the one you quoted.
dsgerbc is offline   Reply With Quote
Old 07-17-2013, 12:24 AM   #30
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Ok, I did this a bit different, I pulled a jumper wire from the power out pin of the DRL relay under the hood then routed that power to the input of the power wire to the headlight height adjustment and that powers up the Halo's, side markers and tails any time the DRL's are on, and this also powers the DRL's any time the other lights are on.
Next time I get a chance I will be routing that power to the + side of the Halo's only right at the connector to the headlight assy. then I will install a Diode to block the power from getting to the rest of the lights and the dim relay so the result should be halo's and DRL's on any time the car is on. This will have to wait until I have another weekend with nothing else to do.
Respect BRZ is offline   Reply With Quote
The Following User Says Thank You to Respect BRZ For This Useful Post:
DNAPoPo (08-02-2013)
Old 07-17-2013, 11:34 AM   #31
qoncept
qoncept's Avatar
Originally Posted by dsgerbc View Post
Ok, it works, but has an unfortunate side effect.
So here's a recap:
1) I added a wire to pin 50 of connector 3A on the back of the 'body integrated unit'.
2) Grounded that wire through an ignition-switched relay (tapped into one of the fuses on the bottom of the 'body integrated unit' for a source of ignition).
Results:
Halo lights (and all other parking markers) come on with ignition, stay on no matter what position the headlight stalk is in. Headlights work.
However, triggering tail relay seems to be what's controlling the dimming feature of the navigation unit in "headlight" mode. So by having halos on navi unit is sent into night mode. Which is really unfortunate (although not unexpected now that I think about it), since navi going into night mode is a major annoyance cause the unit can't seem to read/calculate sunrise/sunset time off the GPS network.
If I pull the fuse in the "panel" line on the diagram above, the navi stays in day mode; so I think if I turn that fuse into a relay that switches on with actual headlights it's gonna be fine. Gonna see if there's a way to do it.
Couldn't you just put a diode on the original halo power wire?
qoncept is offline   Reply With Quote
Old 07-17-2013, 04:59 PM   #32
dsgerbc
To achieve what?
Old 07-17-2013, 05:16 PM   #33
qoncept
qoncept's Avatar
To achieve what?
Nevermind, I read that wrong. I thought you were splicing in power to the halos and it was backfeeding and triggering the night mode. Nothing to see here.
Old 07-17-2013, 05:34 PM   #34
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Surprised people arent all over this. Seems like one of the first things people would have done
hamlet is offline   Reply With Quote
The Following User Says Thank You to hamlet For This Useful Post:
feedbag (08-14-2013)
Old 07-17-2013, 10:58 PM   #35
FnFast
Doctor
FnFast's Avatar
Drives: Fast
I am confused of what's going on here. Are you making the halo's (boomerang) a separate entity? I just switch my headlights knob forward so I only have the halo and DRLs...whats so hard about that.
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 07-18-2013, 04:51 PM   #36
hamlet
This switches Nav/stereo to NIGHT mode. Would be nice to have those lights always on
Old 07-18-2013, 05:53 PM   #37
FnFast
Doctor
FnFast's Avatar
Drives: Fast
gotcha.
Old 08-02-2013, 11:45 AM   #38
Respect BRZ
Old Mechanic
So this mod is done. Also the drl's are now on even when the headlights come on.
Sent from my DROID RAZR using Tapatalk 4 Beta
Old 08-07-2013, 05:17 PM   #39
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Just go into info, then settings then scroll down and put your dimming on time or Manuel on your head unit then you dont have dimming or night mode when you roll the knob once for them to be on in daytime
Kwisak is offline   Reply With Quote
The Following 2 Users Say Thank You to Kwisak For This Useful Post:
kakarot1657 (09-06-2013), sftateofmind (05-05-2015)
Old 08-08-2013, 03:24 AM   #40
ASdispatch
Drives: GBM Subaru BRZ
Any chance you could add pictures or video on how to do this? Sounds simple but I dont want to screw anything up.
Much thanks
ASdispatch is offline   Reply With Quote
Old 08-09-2013, 04:57 AM   #41
4pokguy
Drives: 2013 BRZ WRB Sport Tech MT
Much thanks
+1
A step-by-step guide would be awesome. Please and Thank you!
4pokguy is offline   Reply With Quote
Old 08-14-2013, 02:30 PM   #42
Respect BRZ
Old Mechanic
The center aft brown relay is the DRL relay find the power out pin and solder your jumper wire to that post as near to the body of the relay as possible. Take that wire and splice into the power input of the halo as shown in pictures.
Halo ODST Commercial (Epic)!! MR2fan Off-Topic Lounge [WARNING: NO POLITICS] 7 09-14-2015 02:29 PM
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 10:23 PM
Halo Light Logic Modification? feedbag Cosmetic Modification (Interior/Exterior/Lighting) 9 01-29-2013 12:33 AM
New test from Ignition. zoomzoomers Scion FR-S / Toyota 86 GT86 General Forum 9 05-01-2012 12:31 AM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 05:41 PM
