Old 09-20-2012, 07:26 PM   #29
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
Originally Posted by Gamma View Post
Is that for a stock spare key?
yeah
i about poo'd a brick when teller told me how much it was
draggin_az is offline   Reply With Quote
Old 09-20-2012, 07:48 PM   #30
Gamma
Drives: 2013 Scion FRS
Oh my! Why did you need another?
Gamma is offline   Reply With Quote
Old 09-20-2012, 08:00 PM   #31
draggin_az
draggin_az's Avatar
i did one with my spare key and didnt take any pics. it came out a little loose from where i missed up the pin hammering it back in. the key had a little bit of a wobble to it where it connected to the fob.
i wanted to do another one and take my time to get it right and tight also it would give me a chance to take pics and post up a DIY on here. i would have used my other key doing it so i would need a spare key in case i f'd something up.
Old 09-25-2012, 02:29 PM   #32
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Just got my blank in from china. $10 shipped. Just gotta swing by the locksmith to get it cut. Excellent mod. It should have come this way from the start.
post_break is offline   Reply With Quote
Old 09-25-2012, 04:02 PM   #33
draggin_az
draggin_az's Avatar
totally agree
post up how it went with the locksmith when you get it done
Old 09-25-2012, 05:48 PM   #34
post_break
post_break's Avatar
Originally Posted by draggin_az View Post
totally agree
Locksmith had me disassemble the key, then cut it in about 10 seconds. Works like a charm.
Total cost of mod: $10.35
Old 09-26-2012, 02:33 AM   #35
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
I think mine is easier to use.
But yours is nice.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 09-26-2012, 12:36 PM   #36
draggin_az
draggin_az's Avatar
i saw those and like how they look but 1. do they come with a transponder and 2. they would probably have to be programmed. when i bought a spare key from the dealership, on the invoice it was $106 to have it programmed.
Old 09-27-2012, 12:16 AM   #37
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
how would you pop the trunk & no panic alarm :O
Furtive is offline   Reply With Quote
Old 09-27-2012, 03:40 AM   #38
MemphisR
Memphis
MemphisR's Avatar
There are buttons there. They are just hidden under the leather to give a sleeker look. It still functionally seems to work well. Also, you would take the transponder from your current key. I don't think it is as hard as the O.P. makes it out to be.
Old 09-27-2012, 10:37 AM   #39
draggin_az
draggin_az's Avatar
if you get your key cut and move over the transponder then no
i had to take my key out of the donor and cut it to fit in the flip fob
Old 10-11-2012, 03:09 PM   #40
Turbowned
Turbowned's Avatar
That's bad-ass, man! Lots of ingenuity!
Old 10-11-2012, 10:08 PM   #41
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
did this last night!! thanks for the write up
RAN94A is offline   Reply With Quote
The Following User Says Thank You to RAN94A For This Useful Post:
draggin_az (10-11-2012)
Old 10-14-2012, 12:51 PM   #42
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
theres a 1/16'' pin that you have to take out. i used a drill bit and hammer. in the first pic its the hole on the left
once you get a little bit out, you can grab it with a pair of pliers and take it the rest of the way out. its a little tough but it'll come out.
the blank and the donor
what i used to do the trimming
donor and blank for comparison
a little tip. when trimming use the high speed to cut it down to the basic shape. then use the low speed to grind it down to the exact shape and size. this is what takes the longest but take your time and get it right the first time.
then comes the slit. line up the spare and mark it off. make it just big enough to where the pin fits inside the slit.
place the trimmed key in the slot. line up the pin and lightly with a hammer tap it into place. once its about 2/3 of the way, use a pair of pliers to force it the rest of the way.
Hey OP, not exactly sure what's going on here. Why do you have to take the blank key out of the circle thing (let's call it a ring) and replace it with a donor key?
Do you have to take the blank out of the ring to get it cut? Or can I just bring my blank (with the ring attached) to Home Depot or something and get it cut?
I don't have any tools that I can use to do the trimming part so hopefully I can skip this part and still finish your DIY guide.
i_4got is offline   Reply With Quote
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 07:27 PM
BRZ HIDs vs FR-S HID Conversion DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 37 06-28-2012 06:20 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 03:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 09:44 PM
