Old 09-11-2012, 02:57 PM   #29
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by shu5892001 View Post
Made by the same company doesn't mean made by the same place, same reason why your frs/brz is made in japan but the camry and corolla are made here. In case you can't see, it's made in taiwan
Made by the same company doesn't have to mean made by the same place, duh. Are the cars Toyota have made in Japan and lesser quality than the ones made in the USA? I don't think so. That is the point here. you are bashing a brand that is designed and created by the same people as the brand you praise.
Do you see your error here?
TouchMyHonda is offline   Reply With Quote
Old 09-11-2012, 03:02 PM   #30
Vegas
Drives: 2012 WRX Limited
shu5892001 your digging yourself into a hole. There have been several members on here trying to explain to you what you can't seem to comprehend. I'm not trying to put you down, but clearly you are a little delusional. I'll break it down since you seem to be trying to justify using aluminum lugs. Are they safe...well that depends on a lot of things but let's keep it simple for ya. If you change tires/wheels often for autoX or track or for whatever reason I would HIGHLY recommend you use steel and not aluminum. I have a feeling you're going to use aluminum cause RACECAR!
Vegas is offline   Reply With Quote
Old 09-11-2012, 03:11 PM   #31
gmookher
Japan>USA in manufacturing precision failure rate
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
Hamza (01-20-2021)
Old 09-11-2012, 03:16 PM   #32
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I never said anything was made anywhere. You were saying that because you assumed Multeki lugs nuts were made in china and that you assume Rays are made in japan that that makes Muteki's less safe or lesser quality.
I simply informed you that you are basically claiming that mutekis are crap... when they are made the the same factory as rays engineering under that same manufacture plant designed both by the same engineers.
You clearly didn't know you were bashing one brand with another brand... when they are both the same brand. HA
Well if you look back at my initial post, the only claim I made was to avoid muteki since I used a set and it chipped very badly after 1 season. I was only giving my opinion based on my own experiences. I didn't even get into which one is safer, which one had better quality and more importantly I don't go on post and tell other to learn something new
shu5892001 is offline   Reply With Quote
Old 09-11-2012, 03:19 PM   #33
shu5892001
Ontario's FT86
Toyota has plants in Japan, China, US and Canada.. just to name a few. It's no secret that the same corolla made in japan has better built quality than the ones made in China and etc.. But that's off topic...
Old 09-11-2012, 03:34 PM   #34
TouchMyHonda
Vtec Jesus
What kinda facts do you have to back that up?
Old 09-11-2012, 03:58 PM   #35
empower-auto
Kouki-Monster
empower-auto's Avatar
This thread is painful.
You don't use an impact gun on these aftermarket lug nuts because it will take the finish off of them.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-11-2012, 08:50 PM   #36
TouchMyHonda
Vtec Jesus
Or because the metal is too soft and will simply stripp out the threads. Yes this is stupid.
Old 09-13-2012, 08:52 AM   #37
Blaster
Drives: 2007 VW GTI
I would never recommend aluminum lug nuts to anybody. Especially if you take your wheels on and off very often. Since the aluminum is softer than the steel stud they will wear every time you put them on or take them off.
Of course if you're extremely careful with them you can get away with them. Personally, I would never use them.
Blaster is offline   Reply With Quote
Old 12-21-2012, 02:11 AM   #38
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
I think Mackin has the Muteki made, but the Rays etc they import. This has been my understanding, although I haven't been in the aftermarket industry in over 15 years.
ZC6BRZ is offline   Reply With Quote
Old 12-21-2012, 03:26 AM   #39
gmookher
Ended up running these:
[ame="http://www.amazon.com/gp/product/B002009YPA/ref=wms_ohs_product"]Amazon.com: McGard 65354BK Chrome/Black SplineDrive Lug Nuts (M12 x 1.25 Thread Size) - Set of 4: Automotive[/ame]
USA made...
Old 12-21-2012, 03:20 PM   #40
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Running my WedsSport lugs and love them on the street. If you track your car, then just go with the simple steel open acron lug nuts like all the racers do.
Old 12-21-2012, 03:41 PM   #41
We use aluminum Lugnuts.
However, we couldn't find exactly what we wanted, so we had our own made... 7075-T6 hot forged Aluminum alloy, type-II hard anodized, Open ended, 40mm, 17mm for maximum wheel compatability. Color is a result of the treatment, so you only get one choice
We do have a limited amount of these available for purchase.
Old 12-21-2012, 07:36 PM   #42
robispec
Drives: Black frs project
We needed to ”spec” ours too..
7075 forged alloy open top
19mmhex thats 40 mm long and HARD anodized with 30mm thread area
(we gun these on and off all the time)
Rolled in threads (no cut in stress risers)
Any color you want as long as it is hard anodized black:-)
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
CSG Mike (12-21-2012)
Black Chromed Accents and Emblems for SWP ScottDRFT Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2014 03:17 PM
Chromed out FT? KritiK Scion FR-S / Toyota 86 GT86 General Forum 37 09-30-2012 02:01 PM
Why no aluminum??? epson1 Engine, Exhaust, Transmission 41 08-01-2012 02:18 PM
Steel Vs Aluminum in the FT86 blur Scion FR-S / Toyota 86 GT86 General Forum 72 06-08-2011 04:35 AM
