Old 08-31-2011, 11:50 PM   #29
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
Pass, lol
82mm 4g63 is offline   Reply With Quote
Old 09-01-2011, 12:27 AM   #30
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Originally Posted by fatoni View Post
why would those issues be more pronounced in a fr? i feel like having the shifter actually attatched to the transmission would reduce some of the issues a vague linkage would cause
If the entire transmission unit twisted bad enough under load where you'd miss the shift, not just a vague linkage.
Neutral_Eyes is offline   Reply With Quote
Old 09-01-2011, 03:26 AM   #31
madfast
Drives: 2010 Evo X MR-T
anyone else notice the line to R is curved, but the line to 7 isnt? does this mean no 7th gear lockout of any sort? hmmm...
madfast is offline   Reply With Quote
Old 09-01-2011, 09:50 AM   #32
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
I would guess in order to use R gear you need to first release to neutral and then press down to the R gear. That may also be the reason where there is a little gap in the line.
Many manual cars from VW is done like this. Not sure if BMW or mb are like this as well but I guess that is a german car thing.
Want.FR-S is offline   Reply With Quote
Old 09-01-2011, 12:51 PM   #33
Allch Chcar
Drives: N/A
amazingly short gears dont equate to maximum acceleration. what it does mean is that you spend more time shifting than accelerating. this is why the wrx accelerates faster to 60 than an sti. im not saying that the wrx is faster but i am saying that extra gears dont mean more performance. also tall top gears dont mean great mileage if they remove the engine from its range of desirable effeciency
Originally Posted by cyde01 View Post
Yeah I wud misshift too before i got used to it. Anything more than seven and i dont see how u wud avoid misshifts. Oh and theres no point in having a taller extra overdrive gear so having more gears means closer spaced 2-5 with overdrive 6 and 7
Misinformation much? If you check automatic gearing you can see that they not only reduce the RPM for cruising beyond a manual but they put the engine outside of it's torque curve. EG the tiny engined Honda Fit cruises at 60mph @ 2800RPMs with 5spdStandard vs 2200RPMs with the 5spdAuto. Or maybe a better example is the RX-8's Renesis. 3000RPM with 6spdStandard vs 2000RPM with 6spdAuto.
The Mustang, Camaro, Corvette, and Viper have had double overdrives in 6spds for awhile now.
If you want, there is probably a dozen articles I can find on the subject.
And pretty much all sports/y/ish cars with standard could use a taller set of cruising gears.
Offering more gears is the easiest way to offer short enough gears for acceleration yet tall enough for good MPG. You are not required to use all of them all the time.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 09-01-2011, 03:07 PM   #34
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
well i used to drive an s2000 so i know about having double overdrives. and yes, during highway cruising it was revving around 4k so it could've used a taller gear. i've heard the same about the miata 6 speed. but it honestly would be a lot easier to just make the 6th gear taller as opposed to adding a whole 'nother overdrive gear. i just don't see the point of having 3 overdrives, why would you need an in between overdrive gear between 5 and 7? i guess that's what porsche is doing but i really can't think of a lot of times that would come in handy.
cyde01 is offline   Reply With Quote
Old 09-01-2011, 03:17 PM   #35
Allch Chcar
Drives: N/A
well i used to drive an s2000 so i know about having double overdrives. and yes, during highway cruising the it was revving around 4k so it could've used a taller gear. i've heard the same about the miata 6 speed. but it honestly would be a lot easier to just make the 6th gear taller as opposed to adding a whole 'nother overdrive gear. i just don't see the point of having 3 overdrives, why would you need an in between overdrive gear between 5 and 7? i guess that's what porsche is doing but i really can't think of a lot of times that would come in handy.
I don't quite understand what you are saying. You say you understand but you're discussing two cars that don't have double overdrives but instead had very short 6th gears?
Too much of a drop is bad if they're shifting fast, bad for syncros. Some of the double over drives are basically a regular OD and taller OD with a really short axle ratio. I triple OD I could see being a bit wasteful but it would really depend on the axle gears.
-Allch Chcar
Old 09-01-2011, 03:43 PM   #36
cyde01
cyde01's Avatar
um, what? an overdrive gear is any gear with a ratio of less than 1:1. both 5th and 6th gear in the s2000 are below 1:1. i don't know the miata 6 speed gear ratios off the top of my head but i'm positive it has double overdrives as well.
what i'm saying is, the s2000 had double overdrive but the final drive was a little short, so i can understand wanting an even taller gear. but why not just make the 6th gear taller instead of adding a 7th?
yes too much of a drop is bad when shifting fast, but why would you be shifting fast or shifting near redline in a cruise gear? the only time you'll notice the difference is if you're going 140+mph.
Old 09-01-2011, 04:06 PM   #37
Allch Chcar
Drives: N/A
Yeah, the S2000 isn't a good example of a Double Overdrive, it's a very close ratio box and 5th is barely more than 1:1 ratio. Most domestics use a 1:1 gear and they use two gears for OD and that 6th gear can be from .50-.68 or so.
-Allch Chcar
Old 09-01-2011, 04:30 PM   #38
cyde01
cyde01's Avatar
well i like the gear spacing on the s2000 so for a 7 speed, it would make more sense to me if 5th was 1:1 or at least close to 1:1 with an overdrive 6th and 7th, which is why i made the initial comment. but i guess that's not what porsche is doing.
Old 09-01-2011, 04:34 PM   #39
Allch Chcar
Drives: N/A
I didn't mean to make that sound like a negative X).
-Allch Chcar
Old 09-01-2011, 04:38 PM   #40
cyde01
cyde01's Avatar
ok well you quoted me and said "misinformation much" so you made it sound like i didn't know what i was talking about. i feel vindicated much!!!
Old 09-01-2011, 04:43 PM   #41
Allch Chcar
Drives: N/A
It was more to do with you two saying that taller gearing would hurt MPG. But w/e. I'm passed it.
-Allch Chcar
Old 09-01-2011, 04:45 PM   #42
cyde01
cyde01's Avatar
never said that!
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 12:30 PM
This Porsche may be the most detailed Lego car ever ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 8 07-10-2011 05:23 PM
Porsche 911 GT3 RS 4.0 tranzformer Other Vehicles & General Automotive Discussions 15 05-03-2011 12:07 PM
Need For Speed Shift 2 Dragonitti Other Vehicles & General Automotive Discussions 12 04-09-2011 11:49 PM
FT-86 Future Said to may include hybrid ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2011 10:40 PM
