Old 11-15-2024, 02:04 PM   #29
Ultramaroon
not playing cards
Ultramaroon's Avatar
That is commitment!
I predict a bad connection between engine and chassis harnesses.
Edit: NVM... I'm repeating myself.
Still!... Go Ron, Go!
blsfrs (11-16-2024)
Old 11-18-2024, 09:52 PM   #30
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Ron says the sensor is bad. He swapped B1/B2 and, this time the code followed the sensor. He put the "bad" sensor in his car and got the code. He's been driving my car around with no cel.
Here what I think happened:
When the code popped up, I swapped the intake cam sensors. Still had the P0341.
I then put in a new, Beck Arnley, sensor from RockAuto. Still had the code.
I found a short in the plug to the sensor. I replaced the plug and rechecked continuity but I still had the code.
So, IMHO, the short was the original problem. I compounded the issue by installing a new but defective sensor.
Or, Gremlins
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (11-20-2024), T-Steve (11-20-2024), Ultramaroon (11-18-2024)
Old 11-18-2024, 10:15 PM   #31
Ultramaroon
not playing cards
No gremlins. Your conclusion makes sense. This is a lesson in logical troubleshooting learned the hard way. I am responsible for neglecting to ask for more details when you first reported things you tried.
Make only one change at a time between functional tests. I bet you and Ron had the talk. It's a big one.
blsfrs (11-19-2024), NoHaveMSG (11-20-2024)
Old 11-19-2024, 09:47 AM   #32
blsfrs
blsfrs's Avatar
I hear what you are saying, but what are the odds of a sensor being bad, right out of the box, still in it's unopened plastic bubble?
The Following User Says Thank You to blsfrs For This Useful Post:
DarkPira7e (11-19-2024)
Old 11-19-2024, 10:03 AM   #33
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I don't know the specific number but I would say around 5%. Electronic devices have a failure rate but I doubt you'll get any of the manufacturers to tell you what their numbers are.
RT-BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RT-BRZ For This Useful Post:
blsfrs (11-19-2024), Ultramaroon (11-19-2024)
Old 11-19-2024, 01:08 PM   #34
Ultramaroon
not playing cards
Way more often than one would hope. Not only is it a crap shoot from the start, but I also wait for new "devices" to fail soon after being placed into service.
Simple mechanical parts are one thing but my trust goes down with assemblies, and even lower with electronic devices.
blsfrs (11-19-2024)
Another FA24 swap blsfrs Engine Swaps 40 12-21-2024 11:59 AM
FA24 swap to a GT86 ? Anything I need be aware of? twasd Engine Swaps 23 01-09-2024 11:28 PM
Viability of complete FA24 swap (motor and ECU)? Tatsu333 Engine Swaps 43 02-18-2023 07:18 PM
P0341 Code being thrown on 2020 brz ts bbearchell Issues | Warranty | Recalls / TSB 4 08-06-2022 06:42 PM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
