Old 05-19-2023, 04:02 PM   #29
Kulebrero
Drives: GR86
Has anyone done this on a Gen 2 car?
I can’t figure out where it’d make most sense to install some support to keep the trunk from bending/flexing with a wang.
Would it make sense to replace the rubber supports on both side of the latch with hard bolts, and removing the plastic piece on the edge of the trunk so the bolts have a hard point to rest on?
Kulebrero is offline   Reply With Quote
Old 05-19-2023, 04:12 PM   #30
RedReplicant
Drives: None
Originally Posted by GrandSport View Post
Deck lids will flex. This is why chassis mount is best practice.
My small ARP wing has flexed my decklid to the point where it has cracked paint. Reinforcement is good.
This. I ran a 9LR on my S2000 when they first came out, after a season my trunk lid itself was cracked about 25% of the way around the top feet.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
BatStig (05-19-2023)
Old 05-19-2023, 04:31 PM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can mitigate that with a backing plate on the inside to distribute load across a wider area, if you have room on the inside of the lid. It will probably still flex, but should help it from tearing. I am going to have to do that with the little APR universal mounts I bought.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
RedReplicant (05-19-2023)
Old 05-19-2023, 06:48 PM   #32
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Well, isn't that terrifying. Thank you for sharing!
BatStig is offline   Reply With Quote
Old 05-22-2023, 05:46 PM   #33
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Yeah, a lot of reinforcement is needed for deck-lid mounted wings. It's pretty easy to make a few hundred pounds of downforce at high speeds, and even more at "peak" (ie: strong head wind + high speed).
Most mounts have fair small footprints- maybe 8-10 square inches at most. You're talking hundreds of PSI there.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
The Following User Says Thank You to GrandSport For This Useful Post:
NoHaveMSG (05-22-2023)
Old 05-22-2023, 05:49 PM   #34
GrandSport
GrandSport's Avatar
I'd be more concerned about reinforcing the actual lid itself. Localized pressure is going to be rough on thin sheetmetal. You could probably bond some sheetmetal to it. Again, not idea, but it would help with localized loads a ton. Remember, rigidity increases cubically (power of 3) with thickness.
Rubber mounts are fine, IMO. If anything, they can flex a bit and that's a good thing. Maybe just make them bigger or more of them. The Viper ACR, which has a MASSIVE "double decker" wing that is deck mounted, runs rubber mounts. They just have a bigger landing pad than the non-acr versions. I think they also basically bond a second layer of carbon to the deck lid. A little different, as it's a pure carbon body panel, but same concept.
Old 05-22-2023, 07:46 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I actually really like the wing mounts on my GTC200 and have been thinking about reusing them with my new wing. They have a very large footprint.
RedReplicant (05-22-2023)
Old 05-23-2023, 04:20 PM   #36
GrandSport
GrandSport's Avatar
Yeah, those are monsters. Not very aesthetically pleasing, but great for load distribution.
Old 05-28-2023, 12:21 PM   #37
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
At the track yesterday I noticed that the rear mounts were pushing down away from the bolts. These were tightened down to the point of bending the the trunk a bit with a backing washer. On the top I am using backing washers, but I'm highly considering building some plates similar to the ARP ones above.
villainous_frx is online now   Reply With Quote
WTB: Nine Lives Wang - wing justnutsandbolts Want-To-Buy Requests 0 01-17-2023 04:59 PM
Nine lives Racing Big Wang Install hedtrip DIY (Do-It-Yourself) Guides 4 01-26-2022 06:01 PM
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
GPS Track Time /Nine Lives Racing Track Day and Auto Show (Sun. 9/8) Chicago Great Lakes 0 08-13-2013 08:42 AM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
