Old 03-02-2023, 07:55 AM   #29
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
There's this thread and this thread.
Here is the TSB from Subaru that covers it.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
soundman98 (03-03-2023)
Old 03-02-2023, 08:56 AM   #30
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Thanks!
So wildly enough, someone commented that the previous owner of my car had the 2015 harness
"It's interesting that you are running the new MY15 coil packs with the redesigned connector but still experiencing the same issues.. I wonder what the point of the redesign was then?"
So adaptor allows for 2017 coils. The harness is for 2015-2016 coils. I'm a bit confused. Do I go up to 2015 harness and then the adaptor for 2017 coils?
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is online now   Reply With Quote
Old 03-02-2023, 09:15 AM   #31
M0nk3y
This is going to sound elementary. But when you come off track are you popping the hood and letting the car vent and cool down?
Hood vents be dammed, when you're just sitting still air is stagnate and you'll cook coils
Kyle H. - #89 STX
The Following 6 Users Say Thank You to M0nk3y For This Useful Post:
blsfrs (03-02-2023), GrandSport (03-02-2023), Jdmjunkie (03-02-2023), RedReplicant (03-02-2023), RT-BRZ (03-02-2023), soundman98 (03-03-2023)
Old 03-02-2023, 10:28 AM   #32
GrandSport
GrandSport's Avatar
I do now (took me a while but I figured it out) but after a 30 min session in texas summers, it still happens.
I will likely upgrade the hood regardless of all this at some point and install more cooling, but I’m wayyyy too deep in cost in this winter refresh right now (plus the simulator to keep me busy while she’s under the knife!).
The Following User Says Thank You to GrandSport For This Useful Post:
Old 03-02-2023, 11:42 AM   #33
GrandSport
GrandSport's Avatar
Update:
Car does not have the TSB update harness. Am going to do that and the pigtails to get 2017 coils.
Anything else?
Old 03-02-2023, 01:50 PM   #34
jflogerzi
jflogerzi's Avatar
Originally Posted by GrandSport View Post
Update:
Anything else?
That should take care of it.
2013 Series 10 FRS #553
Old 03-02-2023, 02:40 PM   #35
GrandSport
GrandSport's Avatar
Also an update. They apparently don't even make the 2013 coils anymore. Dealer said discontinued. Idk, guess it doesn't really matter for me, but that's odd.
Old 03-02-2023, 07:30 PM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I can find and buy it online. 22433AA652, been superseded twice. He may be looking at -650 or -651.
Old 03-11-2023, 01:18 AM   #37
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
While a vented hood did bring down under-hood temps, it did not reduce how often my 2013-14 coils failed. I had three go bad over 2 years. (mostly #1 and #2).
Upgrading to 2015+ coils is the way to go, but you'll need an adapter.
Just tired of overheating coils and killing track days. It doesn't happen OFTEN, but even twice a season is annoying.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 03-15-2023, 03:56 PM   #38
GrandSport
GrandSport's Avatar
Same issue.
Got the upgraded harness and coils. Super excited about something else being the weakest link (trans?), lol.
New engine, new harness, new trans, new diff, new gearing, new (rebuilt) coil overs and new bushings. Bunch of little things (removable steering wheel, better gauges/mounting, hard wired SOLO, etc). Can't wait. Wish I would have rebuilt the calipers and gone with different pads but it slipped my mind. Doh!
Kelse92 (03-16-2023)
Old 03-17-2023, 09:30 PM   #39
jflogerzi
jflogerzi's Avatar
Same issue.
NA the Trans is fine. Boosted its glass in certain gears and WTQ numbers
Old 03-20-2023, 03:44 PM   #40
GrandSport
GrandSport's Avatar
My issue has been sycros I think this is my 3rd trans in about . Seems to be a common problem with them with track use. I'll probably go through them even faster now that I have steeper gears and will shift more.
Anyway, I did a two session engine break in and shake down. Car felt fantastic. Part of it I'm sure is the adjustable camber arms and adjustable sway bar I added, but I'm sure a big part was that BSP did a fantastic job on the suspension setup and alignment.
I'm gonna try to get another day out of these tires with the engine under 6k rpm, then add fresh tires and really let her rip.
jflogerzi (03-23-2023)
Old 04-05-2023, 05:36 AM   #41
Goosfraba121
Goosfraba121's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by kask2_6.0 View Post
Working on some vents for those looking to increase the size of existing vents to something more geared towards a track day car. I was in this boat as well. I don’t have CFD data or wind tunnel test results to back up any claims of increased cooling at this point. Would like to do some A to B track comparisons though.
Attachment 218843
i remember commenting on a facebook post about these, but i cant seem to find it anymore since i dont remember where exactly it was posted.. but was wondering how this is coming along?
Goosfraba121 is offline   Reply With Quote
Old 04-05-2023, 02:24 PM   #42
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
It has been a little slower than anticipated on the manufacturing side but they are coming along. I currently have 20 sets at powder coat I'm waiting to get back. Then they will be available!
kask2_6.0 is offline   Reply With Quote
Coil pack issue, pls help Limitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-19-2022 01:17 AM
Varis V1 CF Cooling Hood beltax90 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-04-2020 08:33 PM
Strange issue - looking for suggestions - Possible DI or Coil pack problem sfruski Engine, Exhaust, Transmission 6 10-02-2018 02:07 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 06:16 PM
FS: VARIS cooling bonnet hood 2 Chris6052 Canada Classifieds 10 08-18-2017 08:59 PM
