Old 03-10-2023, 09:26 PM   #29
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by pope View Post
I think this is where an electric valve and a controller would be beneficial rather than a manual valve or pressure switch.
The electric valves are only closed in one direction when off enabling it to fill and hold until switched on by the user or a pressure switch, unlike the the manual valve which must be opened to fill and/or empty.
Tying an electric valve into either a standalone or arduino (etc) and say comparing oil pressure vs rpm vs accumulator charge pressure to determine when to open the valve would give the benefit of fast reaction like a simple pressure switch, but without dumping oil every time pressure drops because rpm did.
Link?
All the solenoid valves I was looking at were either NO or NC so they won't fill unless triggered or would need a one way bypass to refill the accumulator. Most also had buna orings and seals so not good for high enough temperature. Need either viton or epdm.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-11-2023), Ultramaroon (03-10-2023)
Old 03-10-2023, 10:15 PM   #30
Ultramaroon
not playing cards
Ultramaroon's Avatar
I wasn't ready to build it. I'm keeping all options open until I feel that I've adequately defined the requirements.
blsfrs (03-11-2023)
Old 03-11-2023, 04:24 AM   #31
pope
has a funny hat
Drives: 2014 BRZ Limited
Link?
I don’t have a link, but my Moroso valve only held against pressure in one direction when de-energized. As long as the “In” port faced the accumulator it could charge and hold when switched off. Made it convenient to fill before shutting off the vehicle. Also, essential for pressure switch activated systems to be able recharge once oil pump output resumes and the pressure switch turns off.
pope is offline   Reply With Quote
The Following 2 Users Say Thank You to pope For This Useful Post:
blsfrs (03-11-2023), whataboutbob (03-05-2024)
Old 03-11-2023, 09:46 AM   #32
KillerBMotorsport
KillerBMotorsport's Avatar
The system is incomplete. For an accumulator to do any good there must be some hysteresis, like an easily opened check valve to fill and in parallel, a dump valve that flops open below a set pressure delta.
^ This!
With NO valves it's a dampener. With valves it's supplies supplemental pressure, but again, it's highly arguable as to the effectiveness on an FA, and not a solution to the core problem. We already know on EJs (with 12mm pump and D-AVCS it's not an effective solution.
On the right track here, but it should go a step further and ONLY recharge when load is low. With a good standalone, this is easy to do. Off the shelf, it will recharge, dropping system pressure, at the worst possible time, under full load.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
900BRZ (07-03-2023), blsfrs (03-11-2023)
Old 08-24-2023, 11:12 PM   #33
justnutsandbolts
Drives: Tacoma
Sorry to revive this thread...with a manual only valve set up, what happens if you spin out and stall?
I assume the oil pressure will go to 0 psi and overfill crank with 2qt of oil rapidly, since the driver will most likely not be able to close the valve quickly.
Electric valve would prevent this as long as it is getting power?
justnutsandbolts is offline   Reply With Quote
Old 08-25-2023, 09:59 AM   #34
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I doesn't hurt anything. I've forgotten to close mine after a session and have not had a problem. Maybe a little smoke on startup.
It's not quite 2 quarts. If you start with a 7psi precharge, at 60psi of engine oil pressure, the accusump with have 56.5 oz of oil in reserve. (If my math is correct LOL)
Also, the first half of the discharge is reasonably rapid. Discharge slows considerably as the pressure and volume in the accusump decreases.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 10-02-2023, 01:12 PM   #35
blsfrs
blsfrs's Avatar
I'm finally getting my FRS back together. I wanted to continue reading my OP at the top galley so I added a "tee fitting. So far, it works great.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (10-03-2023), Ultramaroon (10-02-2023), whataboutbob (03-05-2024)
Oil accumulator users bmacfrs Engine, Exhaust, Transmission 3 07-24-2018 12:08 PM
