Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-14-2022, 06:25 PM | #29 |
extra what?
edit: ^^^yeah. Not slow, can't.
even if I'm FOS, I still think the secret is buried in those charts.
12-14-2022, 06:28 PM | #30 |
Drives: 2013 FRS
so a new ECU could learn if it was a notched cam gear or tabbed is what you are thinking. So this ECU had learned with tabbed and with tabbed style in it now starts but its showing 18 degrees advanced on both intake cams. So could it be that with all new timing stuff its not exactly the same as it was before and it wont relearn?
12-14-2022, 06:34 PM | #31 |
extra what?
I don't know! I can't study those charts now! Mrs. Ultra needs her washing machine. haha
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (12-14-2022) |
12-14-2022, 06:41 PM | #32 |
Drives: 2013 FRS
Good luck!
The Following User Says Thank You to jonho For This Useful Post: | Ultramaroon (12-15-2022) |
12-14-2022, 07:35 PM | #33 | |
Drives: Crapcan
Sucks you are having this issue, but this sure is an interesting one. @tomm.brz thoughts?
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-15-2022) |
12-15-2022, 02:08 AM | #34 |
extra what?
I don't know if this makes sense but it's how the old ECU would interpret the signal from the new reluctor wheel with the tabs. I've wondered about this exact scenario all these years. They definitely aren't compatible but would it run? It must. Yours did, right? I think I'd replace ECU and mount the old-style, notched wheels for the sensors.
12-15-2022, 11:18 AM | #35 |
Drives: 2013 FRS
yes it did run and it ran well until had a ringland failure. I still have notched gears. Do you think I need a new ECU or maybe one from a wrecked car? I see 3 by me on car-part for under 60$ in wrecked cars.
12-15-2022, 02:13 PM | #36 |
extra what?
Buy 'em all and hope that at least one isn't locked with an ecutek flash.
12-16-2022, 05:50 PM | #37 |
Drives: 2013 FRS
ok put a junk yard ECU in and no start at all with tabbed gears. So my morning project is to replace with notched gears and test. I will keep you pasted as to if that works. What is the best way to update VIN in ECU they link in this thread for techstream is dead https://www.ft86club.com/forums/showthread.php?t=102810
12-16-2022, 07:45 PM | #38 | |
Drives: Crapcan
That is always the thread I sent other people. I'm not sure without digging around for more info.
12-16-2022, 08:55 PM | #39 |
extra what?
https://www.ft86club.com/forums/show...09#post3560409
can't yet vouch for it. *shrug* wait.... don't you already have techstream? That link was just for the media.
12-19-2022, 10:48 AM | #40 |
Drives: 2013 FRS
so new notched gears and junk yard ECU made it run normal Cams all look good and everything! I have a friend with techstream but he says he cant write a VIN is there different levels of license for it?
The Following User Says Thank You to jonho For This Useful Post: | NoHaveMSG (12-19-2022) |
12-19-2022, 11:24 AM | #41 | |
Drives: Crapcan
Not sure, I need to buy techstream, I don't have it.
12-19-2022, 01:19 PM | #42 |
Drives: 2013 FRS
Its odd that it ran fan the whole time we had it on the old ECU and tabbed gears then when we rebuild it runs but shows 18* advanced on intake cams. My theory is someone redid timing before we owned it did a replacement ECU tabbed gears and had the intake cams off a tooth then on startup thats how it learned it??
Similar Threads | ||||
Timing Chain cover revisions / changes 2013-2020 | FrickingReallySlow | Engine, Exhaust, Transmission | 0 | 09-21-2021 05:10 PM |
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) | MJones_RB | Issues | Warranty | Recalls / TSB | 9 | 08-22-2019 04:00 PM |
Cam position - timing issue. | cab33 | Engine, Exhaust, Transmission | 3 | 07-01-2018 11:52 AM |
Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-10-2016 11:25 PM |
FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! | CSG Mike | Tracking / Autocross / HPDE / Drifting | 47 | 06-24-2013 05:23 PM |
