Old 12-26-2022, 08:41 AM   #29
falcon_wizard
Drives: BRZ 2013
I’ve been running studded nokian hakkapelliitas and had the non studded version before that. Personally unless someone has to regularly go in underground garage where studded tires are forbidden, it’s a no brainer for heavy snow and ice conditions. They are a bit noisier, but the braking, traction and directional control you gain is substantial and well worth it. Initially I was concerned they might be a little slippery in raining conditions on asphalt, but it’s not the case, you can threshold brake them on aspalt as well no problem.
falcon_wizard is offline   Reply With Quote
The Following User Says Thank You to falcon_wizard For This Useful Post:
Pat (12-26-2022)
Old 12-26-2022, 09:29 AM   #30
Pat
Pat's Avatar
Drives: 2023 BRZ
You can threshold any vehicle on any surface with any tires any time.
The Following User Says Thank You to Pat For This Useful Post:
SCFD (12-29-2022)
Old 12-26-2022, 09:55 AM   #31
falcon_wizard
Drives: BRZ 2013
Personally I’ve been running Redline 0-30 in winter (vice 0-20 due to the turbo), and we had
Two weeks of -30C at the thermometer last winter, and it held up fine. Redline is expensive however so I would not necessarily recommend it for regular stock and daily driving applications. I switched to it when going FI, to maximize longevity of the engine, and use higher grades in summer.
Old 12-26-2022, 10:00 AM   #32
falcon_wizard
Drives: BRZ 2013
You are absolutely right… I realized the incoherence of the words after I wrote it… what I meant was that I was able to get very good threshold braking distance with them, such that it was not a concern for normal emergency braking situations compared to non studded tires. I actually bedded my ferodo DS2500 winter brake pads with them on, so that was a good test.
SCFD (12-29-2022)
Old 12-27-2022, 02:33 PM   #33
MJones_RB
MJones_RB's Avatar
Throw a quart of this in your engine, add a pat of butter, and you'll have some smooth sailing.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
x808drifter (12-30-2022)
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 10:08 PM
BREATHE IN THAT COLD AIR! AMAZING DEALS ON COLD AIR INTAKES AT EAST END RACESHOP! eastendraceshop Engine, Exhaust, Bolt-Ons 50 09-24-2019 07:45 PM
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 08:18 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 12:20 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
