| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#29 |
Resident Grannyshifter
Drives: 2022 BRZ w/ STI aero
Seconding this, mine feels like a completely different transmission after the first 10 minutes. Nothing unusual just cold. Notchy is the perfect word to describe it.
#30 |
Drives: Crapcan
That sounds like something people who drive Volvos would pay for.
#31 |
LMGTFY
Drives: 13 FRS, 91 Miata
#32 |
Drives: 22 BRZ limited
| The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | CaptainFenderbaum (10-18-2022), WildCard600 (10-21-2022) |
#33 |
Drives: '22 BRZ
It's been quite a number of years....but my first new car was a 2003 WRX and the SFL suby dealers were so bad I refused to take my car there and instead learned how to do stuff myself. Thankfully the suby auto-x community down there was amazing at the time and helped me jump in with maintenance and mods.
#34 |
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
#35 | |
#36 | |
LMGTFY
Can find a bunch of straight weight gear oils listed for sale as 75W nothing after that. ![]() Go up 3 posts. READ AGIAN |
| The Following User Says Thank You to x808drifter For This Useful Post: | DocWalt (11-02-2022) |
#37 | |
Drives: 2023 BRZ, LTD, MT
Fun fact: Multi-weight oils didn't come out until the early 1950s, before that everything was a single weight. I had an old Chevy with a big in line six that used straight 40w. It would burn through anything else (probably because it needed new rings). |
| The Following User Says Thank You to Squirrely For This Useful Post: | DocWalt (11-02-2022) |
#38 |
Drives: 22 WR Blue BRZ
At about 8000 miles and half a dozen days on track I changed the transmission and differential lube to the Ford Motorcraft XT-M5-QS 75w90. The transmission had gotten very notchy and started whining. When I drained the original 75w transmission fluid it smelled very bad- burned smell, very dark, had a lot of metal in it, and had the consistency of water. The original 75w90 differential lube was a bit better in that it still resembled a lubricant but was dark and had a ton of particulates in suspension and stuck to the drain plug.
After the change the transmission shifted noticeably better and the whine quieted down. Seeing these results I plan on changing at least once a year or every 5-6 track days at a minimum. I hope the 75w90 in the trans holds up better than the OEM 75w. |
| break in period for transmission? | rydollasign | Issues | Warranty | Recalls / TSB | 11 | 11-11-2018 07:42 PM |
| WARNING: If you changed your transmission fluid, please read | MrBodyMassage | Engine, Exhaust, Transmission | 47 | 05-09-2015 12:09 AM |
| Break-in for Auto transmission? | djmm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-13-2014 01:46 AM |
| Owner's manual slight confusion about engine break in period... | davey90 | AUSTRALIA | 48 | 09-05-2012 09:51 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
