Old 02-24-2022, 08:15 PM   #29
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Christian628 View Post
Drove it to work today. I let it idle for a while and saw it get as low as -7 while parked before i had to go in. STFT was still jumping around from 2 to 0. Ill update on my next break. Tomorrow Im going to replace my intake filter and clean the pipe. See if i can find what was or still is causing this. Going to inspect/clean my o2 sensors and double check my headers as well. Anything else I should check out?
Going to log some driving to scale as well. Going to do 2nd gear 3k to redline WOT pulls and slow under 3k rpm driving. Any tips?
Are there any videos of people walking you through all this stuff? If not someone should really make one. A whole lot easier to listen to and see someone do it then read and understand it. At least for me it is.
I'm the same way, better visual learner then book learner.
The easiest guide that I found is the one by steve99. I know guys like him, tomm.brz, and kodename47 are pretty knowledgeable on that stuff. I know enough to get myself into, and sometimes out of trouble.
This is the thread I used to tweak the maf scaling my car and it worked pretty well. I'd put a bit more mileage on your's before changing anything though.
https://www.ft86club.com/forums/showthread.php?t=64790
Old 02-24-2022, 09:17 PM   #30
Christian628
Drives: 2013 Scion FRS
Now it will get down to high -7 low -8 and then go back to high -11 to low -12. AFR is much more consistent. Yeah i have to run around and do some stuff tomorrow. By the time Im done i should have that 100 miles. Then I’m going to double check everything and if it doesn’t change I’m scaling.
Christian628 is offline   Reply With Quote
Old 02-25-2022, 12:03 AM   #31
Christian628
Before i even start the car my diagnostics say that my ltft is -5.6 is this normal?
Old 02-25-2022, 11:23 AM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I wouldn't worry about it. May just be showing you the last value.
Old 02-26-2022, 01:24 AM   #33
Christian628
Something seriously wrong?
Where can i buy a new o2 sensor gasket? Mine is done and after reinstalling I’m throwing a code for my first 02 sensor. I cleaned my maf again and now my afr is stuck at 14.69. Have i trashed it now as well?
Old 02-26-2022, 04:15 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Without seeing a log or knowing the code I can't tell you what's going on. The ECU pulls the afr from the O2 so maf may be fine. I'd really only fix issues and not mess with anything else. Let it hit 100 miles minimum then start logging. Through your previous logs it didn't look like you had an exhaust leak and it looked like the maf was reading fine. O2 sensor gaskets can probably be picked up at a local parts store.
Old 02-26-2022, 05:24 PM   #35
Christian628
Im just getting the code for the first O2 sensor. I forgot that the O2 sensor affects afr as well. I got a new one coming and if the issue isn’t solved after the new O2 and washers then ill rescale.
Even though I had the O2 sensor code the idle was good so im hoping its fixed. I cleaned entire intake, throttle body, and changed to a new freshly oiled filter. Along with re torquing the headers and screwing up my O2 lmao.
Old 02-26-2022, 09:48 PM   #36
Ultramaroon
not playing cards
Ultramaroon's Avatar
Are you fouling your MAF with too much oil? That is one of the two reasons I steer clear of reusable filters. That and, without increasing cross-sectional area, the only way to get an air filter to flow better is by reducing filtration.
NoHaveMSG (02-28-2022), soundman98 (02-26-2022)
Old 02-27-2022, 05:52 PM   #37
humfrz
(it's a slow day in Puyallup - )
Old 02-27-2022, 07:21 PM   #38
Ultramaroon
not playing cards
That doesn't make the air filter flow any better. It just sucks at it harder.
humfrz (02-27-2022)
Old 02-27-2022, 07:46 PM   #39
humfrz
That makes no sense -
I suggest you go back and finish your nap -
Old 02-27-2022, 08:08 PM   #40
Ultramaroon
not playing cards
It's physics, old man. Don't hurt yourself.
humfrz (02-27-2022), soundman98 (02-28-2022)
Old 02-28-2022, 02:13 AM   #41
tomm.brz
Drives: brz 2017 hksv2
But it s forced induction so tecnically the engine isn t only sucking.. The charger is doing its blow job even when valves are closed
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
humfrz (02-28-2022), NoHaveMSG (02-28-2022)
Old 02-28-2022, 02:39 AM   #42
humfrz
Hey, I reckon I know more about physics than YOU do!
I fall down at least 3 times a day and have to crawl over to something to get myself upright again. Yep, I KNOW about physics -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
bcj (02-28-2022), NoHaveMSG (02-28-2022), Ultramaroon (02-28-2022)
Something is wrong S/C Smaay Forced Induction 25 01-09-2020 10:52 PM
E85 gone wrong MGPAX Software Tuning 34 03-17-2016 10:53 PM
What did I do wrong? Hags86 Tracking / Autocross / HPDE / Drifting 8 02-25-2015 01:36 PM
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
