Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 07-28-2023, 10:54 PM   #29
AK2112
AK2112's Avatar
Drives: 22 BRZ
like i said. rabbit hole. it's a 3-saturday project, minimum...
better stock up
AK2112 is offline   Reply With Quote
Old 07-28-2023, 11:28 PM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
don't forget your shotunning tool.
Old 07-29-2023, 03:25 PM   #31
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Have to put the back seat down.
At least it's an option. See you fit that in a Lotus.
Old 08-02-2023, 09:38 AM   #32
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks, I passed that along to my friend and gave him the drive. He returned it to me, loaded -- and mention ed that during the process the drive got rather hot. Odd? Symptomatic of the massive loading all at once? I do not know.
Next time we go somewhere, we'll try it out; I presume wither the drive in place, we'll discover a selection on the touchscreen that accesses the contents of the drive.
Originally Posted by AK2112 View Post
this 100 second long video will explain how to format a large drive to fat32
since formatting will erase everything on the drive, you'll want to put the music from the drive, onto your computer prior to formatting. once the music has been transferred to your computer, format the usb drive as shown in that video and then go ahead and add whatever music you want back onto the newly formatted drive.
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 08-02-2023, 10:40 AM   #33
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Is there a maximum file bit rate for the OEM system on this car? Can it read Flac or Apple lossless files? And is the capacity limit solely that 5000 tracks, or is there also a maximum usb drive size you can use? (I have a large library of lossless tracks I really don’t want to have to downsample, but of course they are much bigger than standard MP3s.)
I’ve been using Amazon Music Unlimited. I guess there is no way of playing tracks downloaded from that on the car without going through their own music app on an Android or Apple phone (still using a Windows phone currently)?
Sport-Tech is offline   Reply With Quote
Old 08-02-2023, 10:46 AM   #34
Spektyr
Drives: GR86
Most USB drives will heat up under use, some more than others. Anytime you use electricity to do "work", there's going to be heat as a byproduct.
In the car you won't notice it because the drive is only being read at a slow rate. It only takes a few minutes to write several hours worth of music to the drive, but several hours to listen to it. Each "bit" of data costs a tiny amount of heat, so when you try to do them all at once it builds up faster than the drive can cool off.
I don't recall the menu in the touchscreen for the USB audio, but there are several "tabs" across the top (about a quarter of the way from the top-top). USB is far to the right and may require arrowing over to get to it. It's something like "USB" or "Media" iirc.
Spektyr is offline   Reply With Quote
Old 08-02-2023, 11:51 AM   #35
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks, we'll try it. I guess we don't need to keep a fire extinguisher handy in the car (although not a bad idea besides eating into trunk space)?
Old 08-04-2023, 12:56 PM   #36
Spektyr
Drives: GR86
Don't even need trunk space:
https://www.checkerdsports.com/produ...at-mount-combo
Old 08-05-2023, 04:13 PM   #37
soundman98
soundman98's Avatar
$100 for a small piece of powdercoated sheet metal with 2 clips and 1 bend in it?!?
there's turning a profit, and there's rape.
also, check some video's on the e50. i've put one in all my vehicles, and keep one at work, but don't consider it a fire extinguisher so much as a 'fire delayer'. it's at least enough to 'cover my 6' on my way out of the situation, but published video testing doesn't support the idea of it actually eliminating fires.
Old 08-06-2023, 03:48 PM   #38
Spektyr
Drives: GR86
It's the bracket, the hardware, and the E50.
Cheapest I can find the E50 is $90, so I'm not sure how the math you're doing works.
Old 08-06-2023, 06:25 PM   #39
soundman98
soundman98's Avatar
ah, i could've sworn they were $50 each when i picked them up.
Getting Sirius XM in the NEW Headunit. applekash Electronics | Audio | NAV | Infotainment 18 06-09-2015 10:39 PM
frozen sirius radio tjohnson104 Electronics | Audio | NAV | Infotainment 3 09-24-2013 04:12 PM
Sirius XM - Straight Up Jertronic Electronics | Audio | NAV | Infotainment 2 08-15-2013 12:31 PM
Sirius antenna abutterman Electronics | Audio | NAV | Infotainment 10 12-24-2012 05:15 PM
Sirius(ly) Irritated poudre BRZ First-Gen (2012+) — General Topics 12 07-16-2012 12:06 AM
