#29 |
Drives: 2012 Toyota 86
Here are GR86 OEM rear struts and springs with 2013 model top hats. Fitment seemed fine to me.
cant get the pics to embed. link is https://imgur.com/a/kUEgiV6 |
#30 |
Drives: 2013 WRB Subaru BRZ Limited 2.0
So if I were to put the 2022+ strut assemblies in a 2013 brz, would I be able to use the 2013 stock end links? What about if I also added the 2022+ jdm sti springs? Thanks!
#31 |
Drives: 17 Asphalt 86
#32 | |
If your endlinks are 12 years old I'd plan on replacing them! - Andrew |
#33 |
Gotcha, thanks! Yes I need to replace them, just trying to figure out which ones to get. Would you recco stock or adjustable? Only suspension mod I have at the moment are TRD sway bars, and plan to do a slight lower at some point, but probably no more than 15mm. (Sorry slightly off topic, I know)
#34 |
With OEM (or similar) struts and shocks I recommend OEM endlinks....except in some cases an adjustable endlink is helpful with certain adjustable sway bars.
I'm not familiar enough with the TRD bars to make a recommendation though. If you're okay right now with the OEMs you'll most likely still be okay later. - Andrew |
#35 |
Got it, thanks!
#36 |
Drives: 2017 BRZ PP, 2004 WRX
Speaking of endlinks, I really need to get around to changing the fronts on mine after adding coilovers.
My Perrin OEM length ones don't clear the inner fender / body with -4 degrees of camber, so I went back to stock. Perrin's bushing's are wider. Either way, both too long and the swaybar touches the control arm slightly, which I can't imagine is great for handling. I highly recommend the Perrin OEM length ones for use with regular struts and stock / stock-ish ride height. They held up great through 2-3 seasons of autocross and I still have their front ones on my WRX after about 10 years. They'd be a nice little upgrade / replacement along with the 2022+ suspension.
#37 | |
Drives: 2023 BRZ, 2018 Golf R 6MT
-Mike |
#38 |
We have some coming very soon.
![]() Very good quality sphericals. - Andrew |
| Standard Suspension Bump Travel | 86•BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 87 | 07-26-2017 11:33 AM |
| Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel | RJasonKlein | Brakes, Suspension, Chassis | 2 | 01-18-2017 04:33 PM |
| More rear suspension travel | Hyper4mance2k | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-24-2016 08:13 PM |
| RallySport Direct's Mega Suspension Everything Thread!!! | RallySport Direct | Brakes, Suspension, Chassis | 101 | 07-01-2015 11:01 AM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
