| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#29 |
Pavement Grey
Why would you buy a car that requires premium and then try to save a few bucks at the pump and use regular?
If you dont want to deal with the required upkeep to keep the thing running at optimal performance, dont buy a car that has a specific level of upkeep.... always put the minimum required octane in the car.....unless you have no choice...and even then try to drive the car gently. I dont get why some people buy something expensive and try to cheap out somewhere else. |
#30 | |
Drives: '04 STi, '12 Mazda 3 Hatch
I watched that Engineering Explained video back when it came out but he's in Idaho and his idea of "high elevation" is half the height of mine so I decided to use 85 in my new Ford T150. |
#31 |
Drives: Pavement MT GR86
If you watched the video you would know he pulled charts out to 10k feet.
Might want to go back and watch it again with a full night's rest.
GR86 MT premium
#32 |
Drives: 2018 Subaru BRZ Limited with PP
#33 |
Maybe he meant e85 😆 🤣
GR86 MT premium
#34 |
You guys don't understand the relationship between octane and explosive energy. Lower octane is more powerful. At 10,000ft it's hard to say if the computer can make enough use of 91's extra resistance to predetonation compared to 87 to make up for its lower energy. My Ford T150 seems to run best on 85 but I suspect the Twin will run best on 87. When I drove my T150 to the coast I switched from 85 to 87 at 5000ft near the CO/UT border
#35 | |
Pavement Grey
The twins are officially rated for 91 minimum. The first gen user manual actually says to use 93 but 91 is fine if 93 is unavailable. So that's what its getting at the minimum....not 89, not 87, not 85....91. |
#36 |
This whole altitude and octane thing is just flying over your head. But that's okay, following instructions is a safe fall back to thinking.
#37 |
Pretty sure you are the one not understanding things. There is more energy in Gas than Ethanol but drag cars don't run 87 they run 115 octane ethanal because you can run higher compression and more advanced timing.
You absolutely will not make more power with 87 than 91 or 93 on a car tuned for 93. no matter the altitude. Run a Data logger and see how much timing is being pulled running shit gas at 8-9-10k feet it'll still be less power than running the required fuel.
GR86 MT premium
#38 | |
#39 | |
As you already understand, a higher octane rating is ONLY there for the sole purpose of avoiding detonation, particularly for high compression engines in sports cars, race cars, etc. Therefore, dropping octane rating isn't giving anyone any kind of power or improving the way an engine runs in any sort of way. If you believe so, it's only placebo. The simple fact is that twins ask for 91 minimum. We don't know the math behind how many octane points you can lower and still run SAFELY based on the altitude you're at. So why risk it. You can certainly perform the test yourself, and it's very possible it will work out, but you're certainly not promoting the engine to run at its peak potential. Just like when you're running 91 at sea level, you're not giving it the full potential that 93 would give. This is just because the twin was designed to run on a fuel that burns slightly slower but avoids detonation - as detonation is highly likely in this engine due to its design. P.S. justinco resides and races at high altitudes (not exactly sure how high). You can look him up on youtube and see how each tune and performance mod made power for him. Power gains were quite similar to those at sea level. So it seems ignition advance would provide far greater benefit than a lower octane fuel. |
#40 | |
Whether ignition needs to be retarded with 87 at 10,000ft is the question, because that would likely reduce power greater than the faster burn increases it. |
#41 | |
But... in the situation you describe, where one is at high altitude, the engine is breathing less oxygen and trying to compensate by reducing the fuel flow. Pressure is reduced, effectively reducing the compression ratio and negating the need for high octane as detonation is less likely to occur. In other words, the safety margin is improved, which doesn't higher octane a necessity. But by reducing the octane rating, you are only accommodating to the fact that your engine no longer needs the high rating with a "reduced compression ratio". It will not produce more power through this. Theoretically, it can with a tune. Just like you can take a twin and tune it up on 91, and still gain more power than the guy that's running 93 on his stock twin. To get back on subject, dropping to 87 may certainly work for a twin at 10K elevation. But it wouldn't gain any power in doing so, but rather lose some, as the higher elevation effectively loses power. I do understand what you're getting at though. I could also be wrong about some of this stuff, so don't take me to be factual. I understand some about the subject from doing my own reading, but I don't know any deep math behind it. |
| Canada: The GR86 Premium is $2000 more than the BRZ Sport Tech??? | JDW2231 | BRZ Second-Gen (2022+) — General Topics | 49 | 01-20-2022 12:12 PM |
| 2022 GR86 Premium MT & AT Comparo | StE92ve | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 121 | 12-08-2021 10:21 AM |
| GR86 PCD | teppey | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 23 | 07-29-2021 11:12 PM |
| GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 28 | 07-18-2021 03:38 PM |
| Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure | keioffice | Miscellaneous | 0 | 03-14-2014 08:10 AM |
