Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-22-2022, 06:10 PM   #29
saluki89
Drives: 2020 Outback XT, 2022 BRZ
Picked up wheels/tires/transponders from Tire Rack yesterday, installed them today.
Drove for about 45 minutes/25 miles before the TPMS light popped up. I’ll need to schedule a visit to the dealer so the new ones can be registered to the car. Will post an update as soon as I can get in.
saluki89 is offline   Reply With Quote
The Following 2 Users Say Thank You to saluki89 For This Useful Post:
azndavepgh (01-22-2022), MikeNSX2 (01-23-2022)
Old 01-23-2022, 11:44 PM   #30
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
After installing my new wheels, my TPMS light came on after driving for only 15 miles.
MikeNSX2 is offline   Reply With Quote
Old 01-24-2022, 08:14 AM   #31
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Does the setting works?
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
AK2112 (01-24-2022)
Old 01-24-2022, 11:31 PM   #32
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Originally Posted by Stonehorsw View Post
I’m curious. How close to the old wheels and tires are you guys when you use the TPMS reset? Could it be the old sensors are too close and confusing the car?
Kona61 is offline   Reply With Quote
Old 01-24-2022, 11:35 PM   #33
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Unfortunately, I think it's fair to assume that if something isn't clearly documented in the Owner's Manual then it doesn't work.
Thanks Subaru and Toyota...
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
Kona61 (01-25-2022)
Old 01-25-2022, 12:19 AM   #34
Up4speed
Drives: 2023 BRZ Limited
Unfortunately, I think it's very clear that it says that you are supposed to go to the dealer, so they can register a second set of tires.
I was hoping that there was a tool that I can use, that I already have, or I can buy for a reasonable price.
The tool that I have that has the highest chance of success would be my Launch X431 Pro, but I don't have any more software updates allowed, it expired in November (unless I pay another $400), so it won't have any 2022 model year info in it. So, the only chance is if Subaru has used the same programming in the past, and my tool would still work.
If that doesn't work, I was hoping to buy a $50-$100 TPMS tool to do the job.
I probably won't have to install that set of tires for at least a year from now, so I have some time to figure it out by then.
Up4speed is offline   Reply With Quote
Old 01-25-2022, 01:41 AM   #35
saluki89
Update:
Took car to dealer, they were able to manually program/enter the TPMS devices from Tire Rack. I can now chose between the ones that came with the BRZ and the aftermarket ones. It took driving a few miles before the tire pressures began showing on the dash, but all seems to be working.
The Following 4 Users Say Thank You to saluki89 For This Useful Post:
azndavepgh (01-25-2022), glamcem (02-01-2022), groucho (01-25-2022), MikeNSX2 (01-25-2022)
Old 01-25-2022, 01:47 AM   #36
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Awesome! Thanks a lot for confirming
Can you please confirm which exact sensors did you order / receive?
Do you have photos of the sensors, or were the tires and sensors already mounted on the wheels?
Old 01-25-2022, 11:10 AM   #37
saluki89
Sensors were already mounted when I picked up the wheels/tires. The invoice shows them to be Pacific 315Mhz 4NM, part number S169 1230. They were $42/ea.
Hope this helps!
The Following 3 Users Say Thank You to saluki89 For This Useful Post:
groucho (01-26-2022), MikeNSX2 (01-25-2022), timurrrr (01-25-2022)
Old 01-25-2022, 11:17 AM   #38
MikeNSX2
Hope this helps!
Same sensors that I got from Tirerack.
After getting to the dealership, how long did it take them to register the new sensors?
I am going out on Thursday of this week or early next week for my dealership to register mine.
Thanks.
Old 01-25-2022, 12:17 PM   #39
MyHybridBurnsGasAndTires
Drives: what
did they charge you for it?
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 01-25-2022, 01:48 PM   #40
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Update:
Great to hear it worked. Did they drill you with labor hours...?
SpectreRT is offline   Reply With Quote
Old 01-25-2022, 02:05 PM   #41
Polishrob
Drives: 2022 BRZ
It seems like TPMS 5 is not backwards compatible with the new BRZ.
Got some Series Blue wheels for winter and both Costco and Subaru could not pair it to my 22 BRZ.
Polishrob is offline   Reply With Quote
Old 01-25-2022, 02:08 PM   #42
saluki89
Didn’t charge me, they were great about it!
Since I was the first one, they needed a bit of trial and error to make sure the programming took. Probably was an hour to hour and a half, the main issue was they couldn’t get the psi readings on the car to show. On the way home, after about 10 minutes they finally popped up on the dash.
Intermittent Wipers backwards Runner10 Issues | Warranty | Recalls / TSB 34 09-18-2024 06:22 PM
Schrader 33500 TPMS EZ Sensors compatible with Rays wheels? Infinity Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-07-2020 06:08 PM
Carsguide: the refresh is a step backwards Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 30 03-21-2017 05:31 PM
Someone's backwards response to me on Reddit Linseal Scion FR-S / Toyota 86 GT86 General Forum 14 07-29-2013 02:35 PM
How to make the dealership bend over backwards? Kiteless Scion FR-S / Toyota 86 GT86 General Forum 48 10-30-2011 06:05 PM
