Old 06-30-2011, 02:03 PM   #29
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Maxim View Post
Personally I think the car will probably wind up right around 2800, not 3000.
It's certainly NOT going to be 2500 like some people are hoping.
It's anybody assumption at this point. We can just speculate and hope until they announce the specs.
Old 06-30-2011, 02:06 PM   #30
Maxim
Drives: 2010 GTI 2dr Tornado Red
Originally Posted by madfast View Post
D, none of the above. it should slot in between the miata and S2000, in terms of weight and power. i dont know why the RX-8 was brought into the discussion because quite frankly its in a larger car class.
Maxim is offline   Reply With Quote
Old 06-30-2011, 02:19 PM   #31
bofa
Drives: Ms. Daisy
^ hah okay that pic made me lol
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-30-2011, 02:28 PM   #32
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
D, none of the above. it should slot in between the miata and S2000, in terms of weight and power. i dont know why the RX-8 was brought into the discussion because quite frankly its in a larger car class. looking at the spy shots, the FT's rear seats look close to unusable. either that or the test drivers put their seats all the way back... so while its officially a 2+2, we can almost treat it as a 2 seater... i mean its 8" longer than a miata. how can a normal sized adult fit back there comfortably???
LOL, I was saying that in a PM with someone earlier.
Volvo C30 is a good comparison it's a hothatch, almost same dimensions, 2+2 it fits me in the back very snugly, it's about 7" taller than the FT but imagine it a coupe with a fierce slope from b to c pillar like the FT, lets not forget at this point the FT is still has a trunk and not liftback, a 12 year old might have some issues back there and little room in the trunk..
*added the asians driving in the spy video were kinda small, you could see that when they got out of the car, and for the car being 50" tall, those guys looked small to the car. I'm a 190lb, 6'1" fellow.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 06-30-2011, 02:31 PM   #33
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
On a side note...anyone notice the artist's rendition of the FR-S based on the camo car?
Looks pretty good:
r4m3n is offline   Reply With Quote
Old 06-30-2011, 02:35 PM   #34
PAImportTuner
Drives: U Mad?
Looks pretty good:
The took the MKIII NYS concept FRS and added the features of the prototype. That's why it looks so good, plus the front of the prototype looks great it's the horrid gummy bear, round, rear end that does not match the front sharp lines. BUT the camo could be hiding things in the rear, though doubtful.
Old 06-30-2011, 02:40 PM   #35
bofa
Drives: Ms. Daisy
Hmm.. wasn't there a white guy as the passenger? Will have to go back and check... but he looked to be around the 6' mark. I'll just be happy to have back seats again, and hope to not need them anytime soon.
BRZ before hoes
Old 06-30-2011, 02:49 PM   #36
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Latest Celica 2425 lb (manual)
Current Tc 3060 lb (manual)
These are the closest related vehicles, although wrong wheel drive. Let's hope it falls somewhere in the middle...but I doubt it will.
GenkiElite is offline   Reply With Quote
Old 06-30-2011, 02:50 PM   #37
PAImportTuner
Drives: U Mad?
Keep it wrapped up then, lol.
Old 06-30-2011, 02:52 PM   #38
bofa
Drives: Ms. Daisy
BRZ before hoes
Old 06-30-2011, 02:54 PM   #39
Maxim
I'll see your Obama and raise you a
Old 06-30-2011, 02:58 PM   #40
PAImportTuner
Drives: U Mad?
LOL
Old 06-30-2011, 03:03 PM   #41
Maxim
See what I did there? Back to the having children issue! I are clevers.
Old 06-30-2011, 03:42 PM   #42
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Uh the current NC Miata is on the RX8 chassis. So... :
Huh? So what? Sharing some chassis components doesn't mean all the other elements (larger body etc) work don't add up to make a big difference - they clearly do as the Miata is several hundred pounds lighter than the RX-8 despite that sharing.
Also the 1st gen Tiburon was a cheap sheet metal, plastics, very cheap overall everything you're talking about Hyundai like 15 years ago. And it didn't have RWD which add another 200lbs easily, AND it didn't need the same saftey features with 6+ airbags. Add that with bigger wheels and tires, heavier 6spd and you got over 2800+lbs easily.
You seem to conflate a cheap car with a light weight one for some reason... funny b/c cheaper cars use heavier not lighter materials for the engine, chassis etc. Sheet metal on the Tib is no different in thickness than any other standard vehicle. If you read my comment through you'd see I made a 150 lb allowance for updating to new safety standards when I stated that 2700 lbs might be doable. Forgot about the RWD weight penalty though - if it truly amounts to 200 lbs that will make a big difference.
Sport-Tech is offline   Reply With Quote
FT-86 on Option magazine cover Axel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 04-02-2012 08:51 PM
Road & Track says 2013 Champion Scion FR-S / Toyota 86 GT86 General Forum 6 09-08-2010 11:33 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
