Old 10-04-2021, 03:07 AM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
Every tire is a compromise.
If escaping the area is a constant significant concern, runflats are a fair compromise. But one you didn't raise originally-- you first said the flats were local, and after everyone was moving back and shifting debris.
I would also suggest that you consider running some sort of flat prevention goop in the tires as well. It will make them heavier, and shops generally charge more to deal with the mess, but poses the advantage of sealing around small leaks from screws, so one doesn't lose all the air out of the tire.
Old 10-04-2021, 08:51 AM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder though for how many people "escaping area" is essential/common enough issue. Dying while changing punctured tire also was brought up later on, initially it was "inconvenient"
Old 10-04-2021, 12:50 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Speaking of the dire need for adult literacy programs:
... you first said the flats were local, and after everyone was moving back and shifting debris.
I said the opposite of that.
Originally Posted by extrashaky View Post
I use my BRZ as a daily and long distance driver across the hurricane zone along the Gulf Coast.
Old 10-04-2021, 07:14 PM   #32
soundman98
soundman98's Avatar
i failed english, so ha!
Old 10-04-2021, 07:27 PM   #33
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I got a C- in Spanush!?
Serious note, runflats are a compromise. I have no experience with having a flat with them, but I'm sure you really want to "get out of danger" you would need rims like a real humves that have aluminum or magnesium runflat inserts.
extrashaky (10-06-2021), soundman98 (10-04-2021)
Old 10-06-2021, 03:41 PM   #34
Sasquachulator
Pavement Grey
Me fail english?
Thats unpossible!
The Following User Says Thank You to Sasquachulator For This Useful Post:
soundman98 (10-06-2021)
