Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-08-2021, 05:14 PM | #29 |
Drives: Crapcan
I don't recall, it was a while ago and I believe it was just some nuts I had in my spare hardware bin.
11-09-2021, 10:13 AM | #30 |
Drives: '23 BRZ
FWIW I installed the 25mm/19mm tubular Eibach sways in the Spring with new factory endlinks (originals were totally rusted/fused). 10 track days since installation and I haven't noted any loosening... I have them set to softer front and stiffer rear settings (~150% stiffer than stock front and rear IIRC).
11-09-2021, 10:27 AM | #31 |
Drives: '13 BRZ Limited
11-09-2021, 10:28 AM | #32 | |
11-10-2021, 01:24 PM | #33 | |
Drives: 18 Brz (Sold) / 22 BRZ
11-12-2021, 11:22 PM | #34 |
I had the same issue with the 20mm Sway and endlinks by WL. We really had to tighten them down to get it from coming loose. But after this all good with 5+ Track days and DD miles as well.
2013 Series 10 FRS #553
04-04-2024, 08:39 PM | #35 |
Sorry to necro this one, does anyone have the spring rates calculated or measured for the 22front 18rear whiteline sway bars?
I am running some calculations on the roll stiffness to compare to stock, and am planning on installing those in April timeframe before season starts. 22brz with stock dampers. |
Similar Threads | ||||
FS: Whiteline 22mm front bar and 16mm rear bar | justint5387 | Brakes, Suspension, Chassis | 7 | 08-12-2019 08:11 PM |
STX handling.. Whiteline 22mm? | Skurj | Tracking / Autocross / HPDE / Drifting | 6 | 08-22-2018 06:15 PM |
FS: Whiteline 16mm Rear Swaybar | smg1138 | Brakes, Suspension, Chassis | 0 | 04-30-2017 06:37 PM |
FS: Strano 22mm Front Swaybar (SOLD) | Gliderx | Brakes, Suspension, Chassis | 2 | 04-30-2016 12:15 PM |
