#29 |
Drives: 13 White MT FR-S
What are the symptoms of an axle that needs to be refreshed? How am I on the original axles with probably close to 130k miles (original), never being touched and being a track only car for last 4 years? I have actually been watching a adapter for 350z axles being developed for our cars, and will hop on that asap.
#30 | |
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#31 | |
Drives: 2017 BRZ
#32 |
Drives: 2013 frs base
#33 | |
This guys is pretty active on the 86 drift FB page, and is saying he is going to get some going to sell.
| The Following 2 Users Say Thank You to ML For This Useful Post: | gt5759 (10-05-2022), RedReplicant (10-05-2022) |
#34 | |
Drives: 2017 BRZ
If the balls fell out of the inner joint it was because it was assembled incorrectly, overextended to the point it bypassed the wire clip/retainer at the end of the cup or you broke/cracked the cage in the joint - done that too, usually only in high hp cars. Just my opinion's here, not poking fingers. When disassembling the inners make sure to not damage the wire retainer at the front of the cup and make sure to not damage the c-clip on the end when you take it out and remove the center piece that's splined. When re-assembling, make sure all the balls stay in place in the cage when sliding into the cup, usually grease will hold them place. Then make sure everything rotates freely before sealing up the boots. Little things to pay attention to - the ball cages are directional and the forged center piece that is splined and slides over the bar, those are directional as well. The outers come apart like any Rzeppa joint does. I clamp the shaft in the vice, use flat faced bar or punch, hit the center closest to bar to pop it over the wire clip on the end, it's the same style clip that helps retain the cv axle in the differential. It takes a few good hard whacks with a 5lb sledge. Other little side notes. Make sure the new cv boot clamps you install don't have anything sticking up that can chafe the boots and cause a tear after tightening them down - if the folds in the boot can touch a sharp edge or raised edge, fix it. I also have never had a cv fail from over being over packed, not really sure that's possible but might be wrong? Hoping this my help a few people |
| The Following 4 Users Say Thank You to gt5759 For This Useful Post: |
#35 | |
Drives: Fr-s
I'm convinced the exhaust completely cooks the driver's inner cv joint. Protip, take pics when you pull it apart because the cages can go in backwards.
#36 | |
Your advice is very helpful. Well worth 2 cents. I think that I had the basic assembly right. I drove the car around town for a week and then on the interstate for 2 hrs to get to the track without problems. The problem seems to be the heat generated by track driving. My right axle (the first one I packed) did fine. It was the left side that failed x2. After the 2nd failure, the axle held together and I was able to put a clamp on it and drive 2hrs home. I used the wd40 tube vent on the axles but I'm thinking too much grease didn't allow for air/grease expansion once things got really hot. For the outer joints, I flushed them out with solvent and compressed air until the were clean. Just this week I saw a video describing dis/reassembly. I've got oem new axles coming tomorrow. I'm going to clean and lightly repack my current axles and try them at VIR later this month. I'll carry 2 new spares and let y'all know what happens. |
| The Following User Says Thank You to blsfrs For This Useful Post: | gt5759 (10-06-2022) |
#37 |
Drives: 2013 FR-S, 2017 BRZ
*typically* when the boot explodes, it's because it wasn't vented properly and the heat causes the air inside to expand, then they swell and catch on something under the car.
Last time I looked at mine, the boot was real close to something on the subframe. |
#38 |
Someone needs to do a video of that. I'm going to take the temperature of the cv cups after a session or 2 just to see how hot they get.
#39 | |
The first time I rebuilt mine and installed the PBM differential risers, I could see marks on the bottom of the subframe where the boots had swelled and were rubbing on the subframe. I redrilled the holes on the PBM mount to reduce the crazy driveshaft angle and lower the diff a bit away from the subframe, vented the boots with a WD40 straw, and the marks went away after that. |
| The Following User Says Thank You to Matt93SE For This Useful Post: | blsfrs (10-14-2022) |
#40 |
This weekend, I had a great time at NASA Mid-Allantic Oktoberfast at VIR. In the last session, I had a fun time playing cat and mouse with a 2nd gen. He was pretty much stock. I could haul him in through the turns but, needless to say, he pulled away on the straights.
I did temperature checks on my CV's. After the morning runs (45*-50* ambient) I got 195*-200* on the left CV and 165*-175* on the right. Morning temp on the bottom of the diff was 195*. I did 2 afternoon checks on Saturday, ambient 75*-80*. Early afternoon was 235* on the left and 224* on the right. After the last session on Saturday, Left 245* and right 225*. My tailpipe is wrapped. I've seen the shields folks have made. Has anyone tried reflective tape on the CV cup? |
| The Following User Says Thank You to blsfrs For This Useful Post: | gt5759 (10-25-2022) |
#41 |
Drives: Fr-s
I'm actually surprised it's that close. I would have expected a higher delta between the two.
Here is what I'm planning on adding to shield the heat. Design Engineering 010450 Titanium Pipe Shield 6" x 1' Exhaust Heat Shield https://a.co/d/9VmdMNG
#42 | |
| Understeer Issues - Toe Alignment Issues? | NutGud | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-29-2021 09:45 PM |
| DSS Axle Nuts | Beachin86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-27-2019 08:30 PM |
| WTB: axle | BatStig | Canada Classifieds | 0 | 07-14-2019 07:09 PM |
| OEM Axle + Axle Nut | vroom4 | Brakes, Suspension, Chassis | 3 | 02-02-2016 02:12 PM |
