Old 06-05-2021, 01:10 AM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
In preparation for the FMIC intercooler piping, I made a smaller reservoir. This is necessary. The crash bar should add more clearance, but the reservoir had to go. It is huge. More pictures in My Build.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
DustinS (06-05-2021)
Old 06-05-2021, 05:48 PM   #30
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
How’d you fabricate the bracket(s)?
Drifter X is offline   Reply With Quote
Old 06-05-2021, 07:43 PM   #31
Irace86.2.0
It is just aluminum bent and hammered with a rubber mallet in a vice to shape. I drilled some holes in the ends and cleaned up the edges. Nothing fancy.
Old 06-11-2021, 02:58 AM   #32
Irace86.2.0
Few more pics with and without the crash beam. I’ll add another when I get the new Drift Armor crash beam.
Brz-123 (06-11-2021)
Old 06-11-2021, 03:02 AM   #33
Irace86.2.0
Just a mock up of the FMIC, but not in any way is it in a final position. Just more showing the size.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-12-2021), BrahmaBull1990 (06-11-2021), Capt Spaulding (06-11-2021), WC-BRZ (06-11-2021)
Old 06-11-2021, 10:21 PM   #34
Irace86.2.0
Picked up the engine today. Getting more serious boys! Pulled the spark plugs. Looks clean. I haven’t pulled the valve cover off, but it looks clean inside.
The Following 10 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-12-2021), BrahmaBull1990 (06-12-2021), Clash0901 (06-12-2021), Drifter X (06-12-2021), Dzmitry (06-14-2021), NoHaveMSG (06-11-2021), Petah78 (06-13-2021), RToyo86 (06-11-2021), Spuds (06-13-2021), toast (06-14-2021)
Old 06-12-2021, 05:29 PM   #35
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I can't wait for the results on this! I sold my 2jz BRZ but I kind of want a k swapped one. I just know it will not cost much less so I probably won't do another, but K turbo swapped something would be cool. Maybe an e30? O.o
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
The Following User Says Thank You to Clash0901 For This Useful Post:
Irace86.2.0 (06-12-2021)
Old 06-13-2021, 08:15 PM   #36
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ok, I need to point out something that has probably been glossed over here. Now, doing all the work himself is impressive enough, but what I find crazy about this is Irace is doing it all in a 1 car garage that seems to double as his fitness room...
Spuds is online now   Reply With Quote
The Following 4 Users Say Thank You to Spuds For This Useful Post:
BrahmaBull1990 (06-15-2021), Dzmitry (06-14-2021), Irace86.2.0 (06-13-2021), NoHaveMSG (06-14-2021)
Old 06-13-2021, 10:17 PM   #37
Irace86.2.0
I little more progress stripping the motor. Everything looks clean. I removed the top, oil pan and timing cover in preparation for installing the oil pump and 50 degree VTC when I eventually get those items.
I may clean and paint the longblock and then do a wrinkle coating for the valve cover. Either red or black for the cover. Either silver or grey for the longblock. I need to weld on a bung for the breather that will go to a catch can, but I want to see what Kpower comes up with for a solution to the rear of the engine.
The Following 6 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-16-2021), BrahmaBull1990 (06-15-2021), Dzmitry (06-14-2021), jflogerzi (06-14-2021), NoHaveMSG (06-23-2021), WC-BRZ (06-15-2021)
Old 06-15-2021, 08:19 AM   #38
Petah78
Drives: 2022 BRZ sport-tech
Nice progress. Keep the updates coming!
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Irace86.2.0 (06-15-2021)
Old 06-15-2021, 04:51 PM   #39
WC-BRZ
Drives: Black BRZ
Easily my favorite thread on the entire forum right now
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Old 06-15-2021, 09:50 PM   #40
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I concur. Such a cool build; thanks for logging all this. Do you have any videos shot with a walk around or anything?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Capt Spaulding (06-16-2021)
Old 06-15-2021, 11:49 PM   #41
Irace86.2.0
I might make something when the engine is fully mounted with everything test fitted before installing, so people can see my routing and configuration for my lines. I’m terrible at contributing to YouTube.
The Following 5 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-16-2021), BrahmaBull1990 (06-16-2021), Capt Spaulding (06-16-2021), Jdmjunkie (06-16-2021), WC-BRZ (06-16-2021)
Old 06-16-2021, 12:50 PM   #42
Petah78
Is the K power swap kit even available for purchase yet?
worst.build.ever.
KPower Industries K24 swap PulsarBeeerz Engine Swaps 1759 05-13-2024 02:32 PM
Irace86.2.0 Build Irace86.2.0 Member's Car Journals 195 03-25-2024 12:29 AM
Turbo or swap Fastend Forced Induction 35 06-11-2020 07:12 PM
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
IRACE86's Build Irace86 Member's Car Journals 25 01-10-2017 04:35 PM
