#29 |
Drives: Scion FR-S 10 Series
I don't care to much about numbers, that torque curve looks like a blast!
Also with reving a 8k are you on stock cams? |
#30 |
Drives: 2013 Subaru BRZ
Very interesting and great work.
We know the current price of the product is high right now but is there a price point target in the future that would make this part a little less controversial? |
#31 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Great job following up with good dyno data.
Definitely reinforces my theory that after you've done the usual suspects for power (E85, Tune, Headers) that the best increase after that is really only upping your FD to a numerically higher FD.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#32 |
Drives: JRSC BRZ SOLD
Very interesting results! The area under the curve is noticeable. If I could make one suggestion for the future as you are clearly going all out. Ditch the TRD accordion coupler for a smooth silicone tube. I ran the STD TRD coupler and silicone coupler back2back X2 when I had the TRD intake. The tube always showed more MAF usage past 6500rpm. Not a tremendous amount but enough to warrant leaving it in. I used a 70mmID/76mmOD coupler 6" and trimmed as necessary.
#33 | |
Drives: 2017 toyota 86
Pretty sure the 8k rev lower number line is the after. |
#34 | |
This has been discussed, tested, and manufacturers have tried to do the R&D and come up with all kinds of solutions. A lot of money to be made for an NA manifold that actually produces gains. The best that has been come up with is lengthening OEM runners (billet blocks) to shift the powerband. Also going aluminum will cause more heat soak vs plastic manifold when actually getting on it beyond just 1 or 2 dyno pulls. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | RT-BRZ (02-25-2021) |
#35 |
#36 |
Technically you are correct.
"Very interesting results! The area under the curve is noticeable." I guess could technically mean noticeably bad. But reading it, at least to me it came across as you implying the area under the curve looks impressive. Apologize if you meant the former not the later. |
#37 | |
Drives: Crapcan
https://www.ft86club.com/forums/show...&postcount=335
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Jdmjunkie (02-25-2021) |
#38 | |
No, Aluminum conducts thermal energy better than plastic. That means it heats up faster and looses heat faster than plastic. The plastic IM will get just as hot... One of the members here took their car to the drag strip. With hot staging lanes and hot idles with both manifolds MY13 and MY17. He measured IM surfaces temps afterward on each setup. Both where 143-145° after passes.. |
#39 | |
But maybe they'll be the one to crack the code. He does make a valid point about the aluminum cooling faster at WOT. However you'd need data to show how much hotter it gets off throttle vs how much faster it cools on throttle, vs how much of that heat being shed into the air raises the IATs. The main concern I would have with manifold temps is just basic thermodynamic in the engine bay, temps rolling off to other components and systems in the engine bay heating up excessively and everything snow balling. Also how much more does an aluminum manifold weigh vs OEM plastic one? Any gains would need to offset all of these down falls. and so far no one has been able to produce any gains as of yet let alone enough to over come the down falls not to mention justify the cost. Billet blocks is/was an interesting solution by increasing runner length to shift powerband, but beyond that the manifold already has more than enough flow capacity and a pretty good straightforward efficient design, not a lot left on the table to optimize. |
#40 | |
But what about all other temps in the system and what about after say a track session with a lot of on and off throttle, not just a scenario perfectly designed to allow the aluminum one to perform as optimal as possible from a heat soak scenario IE only WOT the entire time in a straight line. |
#41 | ||||
Drives: 2015 FRS
There is a reason race cars (NASCAR for example) qualify on 0W20 or 0W30 and race on 20W50 or something similar. It makes alot more power. The less HP you have, the MORE your dyno results are affected by engine oil viscosity and temperature.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
| The Following User Says Thank You to prandelia For This Useful Post: | NoHaveMSG (02-25-2021) |
#42 |
Drives: 2017 86 860 Special Edition
All of this is very interesting, but also very inconclusive.
Would need to see more of an A >B swap out back to back to make any sort of meaningful conclusion. Either way kudos for putting in the legwork and actually posting numbers. |
| Changing 2013 Intake Manifold to Red 2018 Aluminum Intake CARB Legal? | MJones_RB | Southern California | 7 | 11-09-2020 06:42 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
| FBM Intake Manifold | Fonzi | Engine, Exhaust, Bolt-Ons | 1 | 03-11-2016 07:36 PM |
| Intake Manifold | Fonzi | Engine, Exhaust, Bolt-Ons | 0 | 03-03-2016 08:29 PM |
| Intake manifold | viking | Engine, Exhaust, Transmission | 6 | 09-23-2014 11:08 PM |
