#29 | ||
Drives: 2020 BRZ Limited
The rear STB reminded me of an old luggage handle after I installed it and for some reason that just kind of stuck with me. The rubber mat wasn't going to work with the STB and/or the sub without some serious plastic surgery and I gave it to a friend of mine. Searched out carpet kits to go over the OEM felt and didn't find anything I liked so decided to make my own. Went to the fabric store and saw this outdoor rated plaid and that luggage handle thought came back. Huh... I'm gonna do a Burberry trunk. When it came time to install the OEMAudio+ sub, I did a test fit, and the fitment was perfect. The satin black colour was... not a great colour as an accessory to the Burberry trunk. Tiffany Blue. My trunk needs a Tiffany Blue sub as an accessory. And there is the "logic" behind my trunk. ![]() Quote:
And you really do need the rear side braces in your life.
| The Following 2 Users Say Thank You to therealstoly For This Useful Post: | Racecomp Engineering (12-03-2020), ZDan (12-04-2020) |
#30 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
This post cost me $180 for those rear side member braces. Installed yesterday, pretty easy. Drove today with all season tires. Car feels good, I have the whiteline inserts already. Need to wait to the spring with my summers to really push the car. Plus it was like 34 degrees on my local mountain twisties, with some ice patches. So could not really push the car as I do in the summer. No NVH, but my tires have some miles and are getting louder.
| The Following 2 Users Say Thank You to Ernest72 For This Useful Post: | Ohio Enthusiast (12-07-2020), therealstoly (12-07-2020) |
#31 |
Drives: '13 BRZ Limited / 76' 914 1.8T
After chatting with Stoly I was inspired to pick up the Cusco Power Brace Rear Side 965 492 RS as I'm running out of cheap mods to do and he recommended it.
Should you spend the $180 on them? Hard for me to say. Likely worth it paired with the RMB - but I'd do the crossmember bushings first as that was a clear upgrade.
Automotive photo and video
www.mikespock.com |
| The Following 2 Users Say Thank You to Spocknasty For This Useful Post: | Ernest72 (01-09-2021), therealstoly (01-08-2021) |
#32 |
Drives: 2017 Toyota 86 (860 SE)
That sort of illustrates my main line of internal debate at the moment: Braces, or bushings/inserts? It seems that they address similar issues with similar results in many cases. My theory (until one of you tells me I'm wrong, at least) is that the braces will induce less NVH since they keep the original bushings, but add weight. While bushings/inserts will make the car a bit more buzzy/rattly, but stay lighter.
Does that seem like a reasonable pro/con statement? I've only done Whiteline diff inserts at the moment (an impulse by that I'm very pleased with), but would like to plan my next moves more intentionally. |
| The Following User Says Thank You to Cephas For This Useful Post: | therealstoly (01-08-2021) |
#33 |
Drives: 2018 BRZ
Bushing/inserts are also much cheaper than braces. I've done plenty of bushings and inserts and don't mind the added NVH. I find it pretty mild.
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | therealstoly (01-08-2021) |
#34 | |
Drives: '23 BRZ
Additional bracing is only going to augment chassis stiffness so much. It's not like the original designers did not know how to design in a reasonable amount of stiffness for a minimal amount of material/cost/weight. I would guess that most of these add-on stiffeners are not terribly efficient in terms of %age increase in stiffness vs. added weight and $$$.
Strategically replaced bushings or added bushing stiffeners, on the other hand, can easily and cheaply result in greater overall stiffness. So far I've only added the poly Whiteline rear subframe bushing stiffeners, after noting some rear wiggliness in left/right transitions at the track. Seems to have made a difference, more stability in quick transitions. But that's a subjective impression... Worst case though is next to no improvement, but very little $$$ spent and roughly zero weight added ![]() Quote:
| The Following 5 Users Say Thank You to ZDan For This Useful Post: | Cephas (01-08-2021), DarkPira7e (01-08-2021), NoHaveMSG (01-08-2021), Racecomp Engineering (01-08-2021), therealstoly (01-08-2021) |
#35 |
Drives: 2018 BRZ
I would imagine that there can be two sources of "non-stiffness" in a car - relative movement between different parts and actual movement of a part (i.e. flexing/bending).
Bushings and inserts can help improve the first case, and braces can help with both cases (by tying two or more parts together and by stiffening parts). I'm not sure if the second case is really that relevant to a modern car built for stiffness such as the Twins, but I may be wrong. BTW, I stumbled in the past on subframe bushings that were made out of aluminum and provided an interference crush fit when mounted and the bolts tightened ("squeezing" the aluminum to the exact shape of the gap between the sub frame and the chassis). I can't find it now (only hit aluminum bushings for BMW platforms), but I would imagine these would be the most extreme bushing/insert, with OEM rubber bushings on the opposite side of the spectrum, and aftermarket poly/delrin bushings being somewhere in the middle. |
| The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | Cephas (01-08-2021), therealstoly (01-08-2021) |
#36 | |
I'd choose the bushings over the subframe brace as even with the brace you've still got rubber bushings all around that can flex and the brace is only connecting two points. I've got a short commute and with the car going up in miles I might be moving on to a new car soon, so I may experiment with different braces and bushings to give feedback to the forum. NVH be damned.
www.mikespock.com |
| The Following User Says Thank You to Spocknasty For This Useful Post: | therealstoly (01-08-2021) |
#37 | ||
I don't have any bushing upgrades, however, based on what everyone that does has said about the before/after differences, it seems reasonable to theorize that both braces and bushings deliver similar results for similar areas of the chassis. There was a thread I can't seem to find again whereby someone was making an inquiry about sway bar lateral braces and one of the replies raised a question I'd not thought of and that was how many braces are originally R&D'd for one platform and then tweaked to fit different platforms without going through R&D again? Doesn't take much of a stretch of the imagination to see this as a real possibility and could very well contribute to some of the negativity bracing often gets, both in reputation and results. It never occurred to me to weigh the braces as I got them, however, they are all very light on their own. The bulkiest brace is the front member brace and it can't weigh more than five pounds, if that. Bushings would, of course, be lighter, but at 6lbs/gallon for fuel, I probably didn't add more than two or three gallons worth of weight total for a much stiffer chassis. There will always be those that view adding lightness as an elevated artform, and I respect that, but for most of us I wouldn't think the weight of the braces has much validity factoring into the pros/cons. |
| The Following 2 Users Say Thank You to therealstoly For This Useful Post: | Cephas (01-09-2021), Spocknasty (01-08-2021) |
#38 | |
Drives: Crapcan
There are many solid subframe bushing options for this car(didn't quote your other post mentioning this). I am running the SPL setup. I haven't seen anyone say that.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ohio Enthusiast (01-08-2021) |
#39 |
Drives: 2018 BRZ
Bushing replacements, yes. Bushing inserts are much easier to install, pretty much on par with braces - remove bolts, put insert/brace, put bolts back.
For the more intensive bushing replacements, I can see a benefit of doing equivalent bracing or parts swap instead (would be more expensive to purchase, but simpler to install DIY and cheaper to install in a shop). |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | therealstoly (01-09-2021) |
#40 | |
Drives: Crapcan
Yeah I would far above recommend a diff brace over replacing the rear diff bushings. That is one of the few braces I would actually recommend though the NVH from it is brutal. Worse then my solid subframe bushings.
#41 |
Drives: '23 BRZ
Have not noticed any. Could be more road noise but currently still driving around with rear seatback and trunk base/carpet removed from track season (done to get down to my minimum weight!). Even as it is now I don't find it *too* noisy on the highway. But I dailied an S2k for 10+ years with a 100 mile round-trip commute for a lot of that. So this is kind of a luxury car in terms of road/wind noise on the highway for me..
| The Following User Says Thank You to ZDan For This Useful Post: | therealstoly (01-09-2021) |
#42 |
Drives: Corolla GT
I have done the WL subframe inserts and they are the only upgrade so far and they do induce more noise in the cabin while driving. Exhaust is also stock, so there is no drowning of the noise the inserts generate.
No added harshness or vibration. There must be a reason why STI added only upper ones on the BRZ STI. A good combo maybe STI upper (front ones only) and member brace to minimise all noise may have almost the same effects? One thing though, the rear definitely feels so much better with the inserts, at the cost of some understeer, very much planted and more grip on tap. |
| The Following User Says Thank You to Thefalls For This Useful Post: | therealstoly (01-09-2021) |
| TB Performance Bracing Review | Zach3794 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-11-2013 10:23 PM |
| Cusco: Toyota 86 / Subaru BRZ Suspension & Bracing !! | Speed Element | Brakes, Suspension, Chassis | 42 | 06-14-2013 03:20 PM |
| CUSCO Chassis Bracing & Suspension IN STOCK Free Shipping LOWEST PRICES on FT86Club!! | CygnusPerformance.com | Brakes, Suspension, Chassis | 27 | 05-16-2013 08:06 AM |
| Cusco And Beatrush - The All Japan Strut Bracing Thread! | RallySport Direct | Brakes, Suspension, Chassis | 1 | 02-12-2013 06:47 PM |
| TB Performance Chasis Bracing Review | xclusive_brett | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-05-2013 11:46 AM |
