#29 | |
Drives: 2017 BRZ w/PP
oh duh im a moron |
#30 |
Still STX
I got an email from Doug Gill confirming the STS thing was just a typo in the column header of the draft rules. The twins are still in STX for 2020.
Barry |
#31 |
Drives: 2013 brz, factory five 818
Hey guys, so I just picked up a 2013 brz limited this past summer from a friend. I spend most of the summer just driving the car and enjoying it being so busy. This next year I'm planning on getting back into autocross and am just looking for input. Definitely thinking going the stx route, in your guys opinion, what's the best thing to do first on these cars, let's say you have $2,000 for this year what are you spending it on? I have a catback exhaust on the car and a k&n drop in filter. As well as a larger (i forget which sway bar at the moment) and tires I will be going the 71's as I work for bridgestone, tires are dirt cheap. Also I currently have hawk hp+ pads all the way around with decent life yet. So other than that, where are you putting the money? I'm trying to be smart on my spending as I have another project car, (factory five 818) I'm trying to finish this year as well.
#32 |
Coilovers and alignment, lots of discussion in this thread, last years thread, and the overall stx thread.
#33 |
Cool cool yeah I've been combing over everything and just trying to prioritize for this year. I feel like on these things, it can get real crazy real quick when you start to add up the modifications. Almost more so than any other Subaru ive owned.
#34 |
This has been posted elsewhere but fuck it lets throw it in this thread too; budget recipe for an STX build imho
17x9 Wheels Tirerack brand, ~$668 245/40/17 RE71R Tirerack $742 Mounted and balanced from TR to my door ~$1410 + taxes ProParts STX Megan Coilovers (comes with camber plates and front end links) ~$2k shipped with taxes iirc Whiteline rear subframe inserts ~$50 SPC rear LCA's + Diftech bushings ~$300 (or Whiteline LCA's) Perrin 22mm Front Swaybar ~$240 Header $700 name brand short tube header (UEL for da torques n burbles, Tomei/JDL/etc.) OpenFlash Tablet $500 Total: $5,200 Buy used and you can cut your total down to <$4k (wheels, first set of comp tires, coilovers, header, OFT). People will prioritize differently "gotta have X, Y is crap don't buy that" and there are absolutely more expensive parts with measurable gains, but I think that they're in the noise unless you're capable of extracting 99.99% of the cars potential and you're trying to beat someone also capable of extracting 99.99% of the cars potential. I could easily make a build list >$15k (without resorting to $10k Penske dampers or $4k wheels), but I don't think it's worth it, if I get beat with the above basic parts it's probably because I got outdriven, not outspent. That being said I'm probably going to plop down $700 for a Karcepts front sway bar (because I don't think my 20mm bar is stiff enough and I can afford to spend an extra $500 on a swaybar) and a $900 set of A052's, might even go for a catback if the right one pops up coincidentally when I find some cash burning a hole in my pocket. |
The Following User Says Thank You to strat61caster For This Useful Post: | e1_griego (08-26-2020) |
#35 | |
so ive seen people run both whiteline and perrin. whats the difference between the 2 if they are both the same size? |
#36 |
Whiteline doesn't publish stiffness numbers, hole location/arm length, metal choice, construction, heat treating, bend radius could all affect stiffness. They're likely close but I would not claim they are identical so I'm just picking Perrin based off the advice of a few different people and the fact that they publish a real spring rate for their bar.
#37 |
Drives: '15 STX
That's not a IMO build, that's the current national champ build. Teddie's car is a carbon copy of my old car and Jeff Wong's original build. Some parts are slightly different but they all serve the same purpose. And she didn't have the rear LCA's either.
The Whiteline bar is stiffer than the Perrin because bar angles, so you're basically stuck on full soft or it pushes. Depending on your coilovers rates. |
The Following User Says Thank You to tony_r For This Useful Post: | strat61caster (01-13-2020) |
#38 | |
FRS CoG is pretty low, I think back in the early development people tried slamming the car. As a result, one of the impacts was snapping axles. Available shock travel I think is often overlooked as a pretty key important setup tool. One of the reasons I chose remotes on my MCS was the available travel in the rear + not having to run bump stops. End result is the car can do stupid stuff like this and not get upset: ![]() Hole location so the effective rate is different between the two. Personally, besides the subframe bushings I think Whiteline products are absolute garbage. When I first setup my car, I had a whiteline bar on my car. I couldn't figure out forever why my car would contact the right (passenger) LCA and not the left. The bar was actually extruded 0.5" further on the right than the left. Whiteline factory wasn't even aware of the design flaw until I pointed it out to them.
Kyle H. - #89 STX
#39 |
+yokes yes
But some schmuck will claim only heitkotter could win on Megan's ![]() |
#40 | ||
You'll see 3 cars: Ray - who is on KW v3s Me - MCS 2Way Remotes Bryan: ProPart Megan [ame]https://www.youtube.com/watch?v=qLZgiePJnws[/ame] Per Bryan's comment from what HE saw watching: Quote:
Kyle H. - #89 STX
The Following 3 Users Say Thank You to M0nk3y For This Useful Post: |
#41 |
ok looks like ill be going perrin 22mm front and keep the performance pack rear sway. that is unless being a 6k springs mean i should go smaller. also will i need adjustable endlinks? im lowered 1" and i know perrins endlinks are non adjustable
#42 |
End links highly recommended, might even be necessary as some coilovers relocate the mounting point such that when lowered the stock end links can cause issues being too long. The bar itself is rarely an issue though (unless you have monk3ys unfortunate problem with whiteline) so if that's all that's going in stock links are probably fine in the short term assuming it's fine before the bar.
Stock links won't allow you to split the mounting holes without preloading the bar, gotta pick soft or stiff. Same with Perrin which seems nice for a set it and forget it DD, a waste of money if you want to dial in a setup. |
SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
