#29 | |
Iffen I was talken to you, I would have you for ….. for …. just because, you probably weren't using a #2 pencil.![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | davesrave (11-06-2019) |
#30 | |
Also, speedometers typically read high by design. The primary goal is to never read LESS than the actual speed of the car. Most are high by one or two miles per hour but it could be as much as 10%. Road and Track carried a good article on the subject some time ago.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Lantanafrs2 (11-07-2019) |
#31 | |
Drives: 2014 Boxster S; 2015 Macan S
| The Following User Says Thank You to davesrave For This Useful Post: | Dadhawk (11-07-2019) |
#32 |
Drives: car
My fuel economy wasn't affected much, actually improved .2 mpg on the readout.
#33 |
Drives: Looking to buy
Does anybody know if there's a break-in period for this recall where you're not suppose to race the car and treat it as brand new, keeping the rpm under 4k?
Sent from my GM1915 using Tapatalk |
#34 | |
Current ones are more accurate but could be impacted by a change in tire size, just like a speedometer. They are also impacted by tire wear. As the tire wears, it becomes smaller making the odometer reading higher. If the odometer is based on a 24.6" tire (that is new calculated circumference of a P215/45R17 tire) for every 1/8" of tire tread wear you gain 25 feet of measured ground per odometer mile. That means for every 211 miles you travel your odometer would be +1 mile off. Now, I'm not sure if odometers are calculated for medium tire wear so that it balances out over time or not, of if some odometers use a different measurementh other than tire rotation and size.
#35 | |
#36 | |
not playing cards
I would, however, drive straight from the dealership to a jiffy lube for good measure.
#37 | |
#38 |
Drives: 2013 frs red
Dont worry about it.
#39 |
not playing cards
I should've qualified my opinion by admitting how jaded I am. Lantana's right. Pull the dipstick. If there's enough oil and it looks fairly new, meh.
#40 | |
If the odometer calculation is based on new tire circumference, and your MPG was constant, it would "improve" as your tires wear down. Sometime I may look at my mileage, which I have tracked from day one, and see if I can determine a trend up as tires wear, and a reset with new tires. If the odometer is set on a "medium wear" tire then at full depth the odometer would run slow, reach actual, then run fast as the tires wear.
| The Following User Says Thank You to Dadhawk For This Useful Post: | davesrave (11-08-2019) |
#41 | |
#42 | |
It was the same tires, with the old tires having over 69,000 miles on them so they were just above the wear markers. Really though the change isn't significant and varies about as much as any randomly selected 20 measurements in my list. Time of year, driving variances could explain it as easily as tire wear.
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 06:24 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 04:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 08:41 PM |
