Northern California NorCal
Old 01-07-2020, 02:34 AM   #29
Saviorself
Saviorself's Avatar
Drives: 13' BRZ
Can you just “upgrade” and rebuild the engine instead of having to do the recall?
Saviorself is offline   Reply With Quote
Old 01-07-2020, 09:06 AM   #30
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
You'll probably have to provide a lot of documentation/proof that the valve springs have been replaced. If you're planning on rebuilding the engine, just get the recall done first. Stupid, but looks like the only option at this time if you want to register your vehicle.
shiumai is offline   Reply With Quote
Old 09-27-2020, 04:36 PM   #31
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
Just found out today I couldnt renew my registration on my '13 due to the same issue in California.
My registration is due on 10/28/20. Does this mean I have 1 month to get my vehicle repaired and registered?
I'm not sure what to do at this point as I was not planning to get it repaired
itisthumper is offline   Reply With Quote
Old 09-27-2020, 04:49 PM   #32
shiumai
shiumai's Avatar
Do what just about everyone else did in CA. Get the recall done or you can't register it. You've had over a year to get it done. Numerous threads like this one have been stating that the recall is mandatory in CA for a while now.
Old 09-27-2020, 04:52 PM   #33
norcalpb
norcalpb's Avatar
Yes after 10/28 you won’t be able to legally drive the car. You may be able to get temporary registration but they may not give that to you with the TSB still being open on your car.
Also, there are fees that you have to pay if you don’t register the car as inoperable.
Old 09-30-2020, 02:47 AM   #34
sftateofmind
Evening Primrose
sftateofmind's Avatar
Honestly, it doesn't take long to get done. Find one of the better dealers to do it and you should have your car back in 1-2 days. Serramonte kept hounding me to get it done and finally when I went to renew my regs I got the notice that I needed to provide proof of getting it complete.
When your recall is done make sure to get the salmon/orange certificate as proof (or get one from your friendly dealer), send it in with your payment and then you are all set to wait for your tags to come in.
DMV has been slow af processing things. I didnt get my tags for 2 and a half months after I sent everything in. Sooner the better.
sftateofmind is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
