Old 03-24-2022, 01:51 PM   #29
cfedsasd
Drives: best
The correct solution to this situation is to replace the fuse. When you install a fuse designed for a lower voltage, the machine refuses to use it and does not close the circuit. Try buying a fuse set and installing the same fuse or one rated for a higher voltage. Usually, this procedure has helped me with a lot of breakdowns. As for the living room light, I can advise you similar bulbs https://www.vont.com/product/vont-bu...s-smart-bulbs/. I recently bought one of these, and I'm still thrilled. I could not have imagined that it would be convenient to control the lights with my phone.
cfedsasd is offline   Reply With Quote
The Following User Says Thank You to cfedsasd For This Useful Post:
soundman98 (03-24-2022)
2013 BRZ Reverse Light (Reverse & Reflector) kberkel Exterior Parts (Aero, Lighting, Etc.) 0 08-14-2016 02:14 AM
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 11:01 PM
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 11:25 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
