Old 06-02-2019, 02:10 PM   #29
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I had this exact same problem with similar negative fuel trim logs and turned out to be a bad coil pack. Since I was around 80k I just did all of them. Reset all the DTCs and it was back to normal. Might want to look into that. I didn't have any misfires either, which was weird. May have just been on the cusp of completely failing.
Jesse36m3 is offline   Reply With Quote
Old 06-02-2019, 07:23 PM   #30
toast
Drives: 14 BSP Edelbrock BRZ
That makes as much sense as anything.
For your catch can, I would run the CCV (driver side) to a vacuum port upstream of the turbo. I had dual catch cans and even when boosted never saw anything on the CCV side. I would run the PCV outlet to the catch can where you currently have the CCV, leave the other port blocked then run the top outlet to a check valve and then to a port on the manifold.
toast is offline   Reply With Quote
Old 06-02-2019, 07:34 PM   #31
incutebus
Drives: Boosted
So my tuner sent me a revision so hopefully it'll fix the issue. My car only has 8k miles so I don't think the coils or spark plugs would be out. Only time will tell, will update after crusing at 80 again.
incutebus is offline   Reply With Quote
Old 06-02-2019, 07:38 PM   #32
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by toast View Post
The crankcase vent is run upstream of the MAF in stock configuration, so it is always pulling in unmetered air.
The PCV valve at the back of the block goes to the manifold so sees vacuum anytime you aren't at full throttle or seeing boost. The ventilation port incutebus has his catch can connected to under the A/C is not valved so air flows both ways. When the manifold has vacuum it suck air from the PCV which is sucking the air from the block (with fuel and oil vapor) which inturn is sucking air through the open port from the metered air from your intake pipe.
Originally Posted by incutebus View Post
So... about my catch can setup
You need to connect your vent to air catch can to the PCV valve at the back of your block and connect the vent you currently have it connected to, to the nipple on your intake that you were asking about.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
incutebus (06-03-2019)
Old 06-08-2019, 03:24 PM   #33
incutebus
Drives: Boosted
So James just told me that there's no fix for the afr leaning out. Told me that jdls kit is just like that and my laf is going crazy and it's something I have to deal with. I find that pretty odd..
Old 06-09-2019, 09:31 PM   #34
incutebus
Drives: Boosted
Any other suggestions? I'm getting pretty concerned with my afr and fuel trims, it tends to buckle much more consistently after a pull.
Old 06-09-2019, 09:47 PM   #35
incutebus
Drives: Boosted
Fuel trims just cruising with some buckling but notmuch
https://datazap.me/u/incutebus/log-1...0&data=3-4-6-8
Old 06-09-2019, 09:50 PM   #36
incutebus
Drives: Boosted
Catching a big buckle in action
https://datazap.me/u/incutebus/log-1...og=0&data=2-22
2017 T86 concerns GTspeedster Issues | Warranty | Recalls / TSB 12 03-29-2018 08:34 AM
OFT Observation and concerns Kayysonie Software Tuning 30 12-07-2016 12:55 AM
e85 concerns Lantana frs Engine, Exhaust, Transmission 6 06-29-2016 03:02 AM
Some Concerns?? KevinYeh BRZ First-Gen (2012+) — General Topics 14 06-30-2014 04:03 PM
K&N air filter .... any concerns ..?? humfrz Engine, Exhaust, Transmission 3 11-26-2013 01:25 AM
