Old 05-05-2019, 09:58 AM   #29
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by Mr.ac View Post
Well that is a pickle. The horror stories all come from Toyota mechanics working on Subaru engines.
There are plenty from Subaru's dealing with "horror" stories too. About 20% of the post recall issues on the spreadsheet are Subaru's, 1 in 5, which is about the same as the 2013 BRZ's to FRS ratio.
I am NOT convinced it's a mechanic issue.
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
gravitylover (05-05-2019)
Old 05-05-2019, 02:23 PM   #30
Turbo
Drives: FR-S Turbo
Except that the publicly available recall procedure updates quite clearly indicate it is.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Tcoat (05-06-2019)
Old 05-05-2019, 04:38 PM   #31
Gunman
Updates are an attempt to mitigate the failures, but I'm still not convinced it it 100% mechanic related. After watching everything that was done with my car, and the lack of excess sealant, there is something else going on as well.
Old 05-06-2019, 12:07 PM   #32
Turbo
Drives: FR-S Turbo
You mean, like, applying tri-bond in areas where it can block oil flow out of the timing cover? Or having pieces of old gasket material make their way into the oil pan where they later block oil flow by clogging the strainer or oil passages?
That's all covered off in the procedure updates as well.
Tcoat (05-06-2019)
Old 05-06-2019, 01:20 PM   #33
toast
Drives: 14 BSP Edelbrock BRZ
'After watching...' You actually watched them reassemble your motor?
toast is offline   Reply With Quote
Old 05-06-2019, 01:21 PM   #34
Gunman
Beyond just that. In my case, one piece of sealant was found partially blocking one passage in the cam carrier. Oil pan was dropped to check the pickup, and the pickup tube was boroscoped from the timing cover side, and nothing was found. Error codes were for the RH intake timing area, and they replaced cam sprocket (twice), ecm, intake cam, cam carrier, head...and the problem remained.
Old 05-06-2019, 06:36 PM   #35
Turbo
Drives: FR-S Turbo
But is this not all related to technician error?
Getting sealant into the oiling system is a technician fault. Having that sealant blocking oil flow up by the cam carrier could easily have disrupted oil flow to the variable valve control system, right?
And I believe that would cause the VVT system to malfunction since it operates off of oil pressure, doesn't it? And that chain of events would trigger the CEL cam timing codes since the cam isn't doing what the computer thinks it should be doing and likely damaged the VVT system inside by running it dry.
I would think they should have just replaced the VVT unit itself instead of everything that they did.
As an aside- Personally, if I had the recall done and afterwards they found sealant blocking (or partially blocking) an oil passage in the heads I would demand a new engine, and involve a lawyer if necessary. There is a 100% chance that lubrication failure did permanent damage that will (at best) shorten the lifespan of the engine a bit and at worse cause a major failure just far enough removed from the recall fix that you will be shit-outta-luck having them cover the repair when it does happen.
Tcoat (05-07-2019)
Old 05-07-2019, 07:10 AM   #36
Gunman
I'm only basing my thoughts, on what I have personally seen. i believe there is something going on, beyond just technician error.
Old 05-07-2019, 08:14 AM   #37
There is. It is a poor design choice to use sealant so close to oil passages. Even a contentious tech that applies just a small dollop to the wrong place can partially block a passage. It wouldn't take much. The removal of the old sealant is more on the techs but even then all they have to do is miss one piece about twice the size of a pin head for it to block a bearing orifice and run it dry. The techs are taking the flake but in reality the design, use of the sealant and initial very poor instructions were setting them up for failure.
If you think it is something beyond the sealant I would be interested in your theory since there is piles and piles of evidence pointing at the removal and/or improper installation of the new stuff to be disregarded in favour of some mystery cause.
Turbo (05-07-2019)
Old 05-07-2019, 08:17 AM   #38
Easy
This ^
Turbo (05-07-2019)
Old 05-07-2019, 08:43 AM   #39
maslin
Benz Tech
Drives: 2017 BRZ Premium
I’ve been glueing engines together since 2006, Mercedes has been doing it a whole lot longer than that. I’ve never blown one up, never wiped a cam, nothing like that. Never even seen it happen to someone else.
Plenty of bulletins out there for over application, warnings in work instructions to clean thoroughly and not drop pieces down holes. You try to be as careful as possible, but I’m sure I’ve left plenty of strips of the stuff in there.
If it drops to the pan it will either get stuck in the strainer, not a big deal until there’s a lot of it there. Or blown though the pump to the filter, also not a big deal until there’s a lot in there.
The concept isn’t the problem. Engines that haven’t been worked on aren’t blowing up going down the road, and they’re all glued together the same way before and after the recall. Or at least they should be.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
Tcoat (05-07-2019), Ultramaroon (05-07-2019)
Old 05-07-2019, 08:53 AM   #40
Sorry wasn't clear. It isn't the basic concept it is the application of it to that particular engine. The methodology appears to be different from others and that is what is messing with them.
And yes engines that were not worked on HAVE been blowing up for the very same reason going right back to 2013. It is well document on here way before the recall was ever even announced. In many of the factory fresh engines that blew they found sealant blocking passages so even the robots applying it couldn't do it right for a period of time. I am not saying that "gluing engines" together is bad overall just that this particular engine seems to be abnormally susceptible to even the slightest error. This is a result of some poor engineering not just careless or "dumb" techs.
Old 05-07-2019, 09:07 AM   #41
maslin
Benz Tech
That makes sense. I was aware of the early engine problems, seemed like they had the figured out pretty early on.
Even better idea. Call up GE, produce a 3D printer sized robot. Fixtures to locate a known component, programs for every piece that needs sealant. Might take 20 years to pay off, but that no worse than a $80k alignment setup.
Machine shop buddy said they hired a robot and fired 4 employees. It’s the way of the future
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (05-07-2019)
Old 05-07-2019, 09:22 AM   #42
Ichima
Drives: 13' Lightning Red Brz
Hey TCoat,
It seems you have pretty good advice in regards to our vehicles. I have been dealing with the dealership since February about my vehicle via the recall. Just 3 weeks ago they have taken fault because a Subaru Rep came and deemed it their fault after inspecting my car. He noted there was clogged oil passages due to old RTV in the oil pan and oil passages. The dealership repairing my vehicle now is only replacing the camshafts, intake and exhaust valves, oil and filter, and a rod bearing (not sure which or how many, they are not being transparent with me). Do you have think this work may seem sufficient, mind you i had driven nearly 400-500 miles after the recall and noticed the issues maybe 50miles in. They told me I was shit out of luck at the beginning and this was my only vehicle to get to work daily.
Ichima is offline   Reply With Quote
The Following User Says Thank You to Ichima For This Useful Post:
Tcoat (05-07-2019)
Bad luck Botev1912 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-24-2017 03:18 PM
Bad Luck? LANEY487 Scion FR-S / Toyota 86 GT86 General Forum 19 06-13-2014 02:05 PM
Bad luck! :( Beeboo4life Scion FR-S / Toyota 86 GT86 General Forum 45 04-25-2014 08:37 PM
Am I out of luck?? DNAist CANADA 21 04-13-2014 11:07 PM
This car really is bad luck Linniea Scion FR-S / Toyota 86 GT86 General Forum 36 12-07-2012 11:31 PM
