| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: 2016 FRS
#30 | |
Drives: Q5 + BRZ + M796
I feel like you are being vague for a reason. Any reason not to spell it out? Judgement? Trying to create a product to sell and don't want to give away your secretes? Kinda confusing.
#31 | |
Drives: 2016 FRS
#33 |
I see. So the adapter was conveniently a necessary spacer.
#35 |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
Excited to see how your hood will tie everything together.
#36 |
Drives: 2016 FRS
Here is a teaser of what it will end up looking like
| The Following 4 Users Say Thank You to srscion For This Useful Post: |
#37 |
Someone has some photoshop skills. The engine bay pic was well done too. Nice execution on the hood.
#38 |
Drives: 2016 FRS
#39 |
Remember me?
Drives: BRZ Series.Blue
would you consider redoing the swap with the engine/transmission moved closer to the firewall to avoid the protrusion? maybe use a different transmission?
#40 |
I don’t think a different transmission is necessary unless the torque limit on the transmission was challenged. The transmission can get moved back, but then it is necessary to make custom transmission mounts, custom driveshaft, custom shifter linkage and obviously redo the engine mounts, while possibly needing to do a custom oil pan to clear the front sway bar and/or steering rack. At that point might as well upgrade transmissions, but then he would need a new adapter/bell housing, new clutch, possibly a hydraulic TOB, maybe a custom flywheel, etc. It seems like his goal was a budget build, which negates a lot of this.
#41 |
Drives: 2016 FRS
No, the modification to the body would be costly, new mounting points would have to get fabricated for a different transmission, a different drive shaft would be needed, the sub-frame would have to get cut. I don't want to ever go down that road.
#42 | |
Drives: 2016 FRS
You're right, I wanted to keep the cost down as much as possible and minimize back end troubleshooting for when things don't work. Luckily I did not have many issues. |
| Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS | ThePurist | Engine Swaps | 0 | 11-23-2017 09:13 PM |
| Toyota left a nice surprise if you're doing a Toyota motor swap.. | Manji | Engine Swaps | 15 | 01-07-2015 02:48 AM |
| Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 02:56 AM |
| Engine Swap | hybrid35 | Southern California | 0 | 01-07-2013 02:04 PM |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
