Old 09-18-2018, 07:22 PM   #29
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Originally Posted by evomike View Post
the newer "eco friendly" paint does not translate to the clear coat, clearcoat is still solvent based. this should not have happened id take it to the dealer and show them, i wouldnt mention you did anything id just say it has this weird spot and see where you get. all new cars should have enough clear coat that you can sand and buff them, something is wrong with your car id take that and a paint meter and check your quarter panel against another new car.
If you’ll notice, I was replying to Ganthrithor‘s comment about the paint being unbelievably shitty on these cars... not to the OP about the clearcoat
NCtoBRZ is offline   Reply With Quote
Old 09-18-2018, 07:41 PM   #30
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Yeah guys, sorry. I was just dumb and did a very dumb thing. Still quite upset, but I will get over it and get it fixed (at some point, can't really justify swinging the cash right now as much as it hurts me) and move on.
TheRealBFKR is offline   Reply With Quote
Old 09-19-2018, 04:19 PM   #31
evomike
Drives: frs
yes but what you are referring to in that post is in fact the clear coat, everything you talk about in that reply references what is actually the clear coat. it has nothing to do with waterborne paint and everything to do with subaru using shit materials and not enough of it.
evomike is offline   Reply With Quote
Old 09-30-2018, 07:37 PM   #32
GrantedTaken
I found a few light scratches on my trunk and roof.
I think a critter crawled over my car.
I washed the surface.
Then I hand compounded (20 seconds max)
Then I hand polished (20 seconds max)
Obviously, I didn't remove much clear by hand,
but there was no paint on my buffing pads.
Something is up with your car.
GrantedTaken is offline   Reply With Quote
Old 10-01-2018, 06:12 AM   #33
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by GrantedTaken View Post
If you polish by hand, you will have Haze.
You need to polish with a random orbital to get glass gloss.
I polished mine by hand but use a very low cut compound (basically just off the shelf Meguiars Ultimate Polish) and it had brought my car back to glass gloss after 4 years of neglect.
This eco friendly bs paint has been around for over a decade, I think it's due to the lack of lead that makes it less durable.
I don't even want to machine apply anything on this car since the panels are quite thin and flexy.
krayzie is offline   Reply With Quote
Old 10-01-2018, 10:29 AM   #34
radroach
Drives: car
I haven't had a problem using Meguiar's M205 (their lightest compound) and a Porter Cable Dual-Action polisher (PC7424XP) on quality cutting pads. Ultimate Polish faired well too, and its fairly aggressive.
OP didn't post the tools he used. There are much more abrasive products out there.
Old 10-01-2018, 10:29 AM   #35
atomicalex
Drives: 2018 BRZ Limited Perf Pack
No, lead has nothing to do with it. Water-base has a little bit to do with it, but there is a bigger contributor.
<-- currently working as an engineer in the paint industry
The problem is the transition to 2-wet and 3-wet processes. Formerly, each coat of paint was cured individually during the paint process. E-coat, color, clear. Three ovens is a lot of line space and a lot of energy consumption. The paint and pretreatment companies came up with a was to reduce the length and number of ovens, which cuts down dramatically on energy consumption and reduces the total line length. It also (in a kind of backwards way) cuts down on paint defects that occur during the painting operation.
However, it results in less total paint being applied and modifies how the paint cures.
This is the issue.
Either get a clear wrap job or just give up. It's going to be a while (5 years) before we get good paint again. It takes time to develop.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
The Following 5 Users Say Thank You to atomicalex For This Useful Post:
8RZ (10-01-2018), BRZyJ (10-01-2018), krayzie (10-01-2018), Tcoat (10-01-2018), TheRealBFKR (10-01-2018)
Old 10-01-2018, 12:19 PM   #36
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I would get a 2 part clearcoat like USC Spray Max 2k clearcoat spray paint. Prep the surface by cleaning it, mask the surrounding area adding an additional 6 inches outside the work area so you can blend it. Spray it and then buff and polish it to blend in with the rest of the car. Shouldn't be to difficult if you know what you're doing.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
Old 10-01-2018, 12:23 PM   #37
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
A) he buffed through the clearcoat by hand.
B) he has already had a body shop fix it and now has issues with the fix.
C) too
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Old 10-01-2018, 12:34 PM   #38
This is the issue.
Yep. It all goes back to the international agreement on VOC reduction back in 2011. The problem is they changed the paint and coating but not how it is applied and cured. Several manufacturers (surprisingly Ford is a leader in this) have updated the process and have fewer issues now but some older plants such as Gunma are still a ways away from improving the process. They should have all their ducks in a row just in time for the rules to change again.
atomicalex (10-01-2018), krayzie (10-01-2018)
Old 10-01-2018, 12:35 PM   #39
TheRealBFKR
C) too
Ha, I think I am going to leave the fix be. Going to go crazy being this meticulous about paint on a DD
The Following 3 Users Say Thank You to TheRealBFKR For This Useful Post:
humfrz (10-02-2018), SuperTom (10-01-2018), Tcoat (10-01-2018)
Old 10-01-2018, 02:10 PM   #40
humfrz (10-02-2018), TheRealBFKR (10-01-2018)
Old 10-01-2018, 11:28 PM   #41
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Mazda's stuff after they left ford is really good as well, my 16 CX-5 has been buffed several times to take some odd scratches out on the rear and still has some nice clear-coat depth in those parts. and it's paint is still it's glorious soul red color.
Old 10-02-2018, 12:02 PM   #42
brandonblt2
C) too
Didn't see that he had a body shop do work on that repair. Personally I would just fix it myself but I've done similar work before.
But yea I would just have it resprayed by a professional if you're new to painting and repairs.
TheRealBFKR (10-02-2018)
A cautionary tale for DIYer's WNDSRFR Engine, Exhaust, Transmission 27 06-26-2017 04:53 PM
Traded my FR-S for a Mustang GT: A cautionary tale Reason FR-S / BRZ vs.... 191 04-06-2017 12:40 AM
a tale of two dealers perryair Issues | Warranty | Recalls / TSB 20 05-06-2016 12:30 AM
Cautionary tale (not my car) boost can be a huge PITA too, its not all red roses..... Sportsguy83 Forced Induction 208 10-11-2014 12:30 AM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 08:34 PM
