Old 07-03-2018, 08:55 AM   #29
ermax
ermax's Avatar
I spun a bearing on my 2013 (11/2012) at 86K miles. Oil level was to the top dot and was changed 4000 miles prior with 5w30. When it blew I was doing a pull to redline in 4th on the interstate. Leading up to that I had been driving it like a normal person so the oil temps weren't high at all. On tear down I was actually impressed with how little carbon buildup there was. Looks like the dual injection really does work. A little blast with some carb cleaner and it was like a mirror. Didn't have to use a brush or anything. I don't needlessly redline just for the hell of it but I do drive it hard and it sees redline at least 10 times a day. When I am cruising I keep the revs low though.
I've never bought into the whole drive it like you stole it or else it will not like to be driven like it's stolen concept.
The DI seal issue was related to detonation on high transients. That was fixed with software a long time ago. If you don't have the the fix then redlining is actually not a good idea. That is exactly the scenario that was causing the detonation and blowing seals. My DI seals looked fine but I'm changing them anyways while I have it all apart.
The Following 5 Users Say Thank You to ermax For This Useful Post:
Capt Spaulding (07-08-2018), humfrz (07-03-2018), Teseo (07-03-2018), Tristor (07-03-2018), VoltsFRS2013 (07-06-2018)
Old 07-03-2018, 09:26 AM   #30
Submarinesonce
Drives: Frs
I like to redline it pretty often just to make sure the shift light is still working.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
The Following 7 Users Say Thank You to Submarinesonce For This Useful Post:
ermax (07-03-2018), humfrz (07-03-2018), Lantanafrs2 (07-04-2018), NoHaveMSG (07-03-2018), Overdrive (07-06-2018), Silviacrazed (05-08-2020), Ultramaroon (07-03-2018)
Old 07-03-2018, 06:29 PM   #31
Snake
Drives: ADM Toyota 86 GT
Get it up to operating temperature then flog the sh*t out of it. Worked for me on my last two cars, never had a problem with them. Both high revving naturally aspirated 4 cylinders that see a lot of the track. Neither have used a drop of oil or given me why trouble.
Sent from my RNE-L02 using Tapatalk
Snake is offline   Reply With Quote
The Following 2 Users Say Thank You to Snake For This Useful Post:
Tristor (07-03-2018), vagthomas (07-17-2018)
Old 07-03-2018, 06:50 PM   #32
mkivsoopra
Maybe they're similar in the sense of "zoom zoom boom!"
mkivsoopra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
Ultramaroon (07-03-2018), weederr33 (07-03-2018)
Old 07-03-2018, 06:58 PM   #33
Ultramaroon
not playing cards
Ultramaroon's Avatar
Can never be too sure.
Old 07-03-2018, 07:34 PM   #34
NRXRaptor
I do burnouts in the garage before I set off. it helps to get engine and tire temps up quickly and I get to check my carbon monoxide sensor multiple times a day. you can't be too safe
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
humfrz (07-03-2018)
Old 07-03-2018, 07:35 PM   #35
ST185RC
Drives: White Out FR-S
Originally Posted by VoltsFRS2013 View Post
do not shoot me, the title was meant to grab your attention.
A lot of people I've been talking to lately keep comparing the motor in our cars to a rotary in the sense that revving it high (near redline or at redline) multiple times during driving is necessary to keep the car in good condition.
Curious to see what you guys think about this. I granny my car a lot, going near redline for me feels a bit awkward especially in the AT's long ass gears.
Apples to oranges comparison. For one, the rotary has essentially 1 plus each rotor of moving parts. A basic 4 cylinder has the minimum of at least 20 moving parts.
that being said, redlining either has greater wear and tear thanks in-part by the heat generated.
Granny driving a car and lugging it isn't the best thing you can do for a car either. My pet peev are granny drivers who think their granny driving is saving the car and planet when they don't maintain their car and are actually making the car worse and the planet worse by polluting it with poor maintenance.
I drive my car within the specifications and that's good enough. I don't lug the car, i don't redline the car. I just drive it to get the most out of the RPM range.
ST185RC is offline   Reply With Quote
The Following User Says Thank You to ST185RC For This Useful Post:
Old 07-03-2018, 08:15 PM   #36
humfrz
OK, just how do you know your air bags will deploy ..??
humfrz
Old 07-03-2018, 08:31 PM   #37
Lantanafrs2
Drives: 2013 frs red
I redline it to pass minivans. Uh oh
Old 07-03-2018, 08:51 PM   #38
Teseo
Drives: frs
Im going to 80k miles, your statement shit out of me. Im starting to belive the spun bearing failures are heart atack for humans, you dont know when or where you will have it
Old 07-03-2018, 09:21 PM   #39
Ultramaroon
not playing cards
Originally Posted by Lantanafrs2 View Post
You probably blew the carbon out of it
Italian tune up
[ame]https://www.youtube.com/watch?v=N44icPfGi1M#t=37[/ame]
Lantanafrs2 (07-03-2018), strat61caster (07-04-2018)
Old 07-03-2018, 09:32 PM   #40
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
You need better friends.
Do not pass GO! Do not collect $200!
Get new friends immediately.
Apex and side seals don't get more efficient on over rev.
Old 07-04-2018, 01:36 AM   #41
Zentec
Drives: 2017 Toyota 86
Break the car in properly. Drive the car properly and enjoy!!
Personally I redline it, I also rev match and have fun in the corners when possible. As for the air bags knowing if they work humfrz <insert sexy girl here>. Squeeze them and rub face in them they sould work just fine.
Zentec is offline   Reply With Quote
Old 07-05-2018, 08:06 AM   #42
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Italian tuneup has been around longer than our FT86
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
The Following User Says Thank You to wrh3 For This Useful Post:
Ultramaroon (07-05-2018)
20B Rotary Staf00 Engine Swaps 77 12-03-2020 09:33 AM
Old Rotary Love MAPerformance Other Vehicles & General Automotive Discussions 6 03-17-2016 07:27 PM
TOMEI POWERED Dissects the FA20 Flat Four I<3myFRS Engine, Exhaust, Transmission 11 02-24-2016 11:15 PM
RX8 out Ran My FRS (Rotary Vs Flat 4) GT-ROKIN FR-S / BRZ vs.... 113 05-17-2014 01:40 AM
Rotary Extinction??? Rotarydisciple Other Vehicles & General Automotive Discussions 53 01-23-2010 09:58 PM
