Old 06-05-2018, 02:45 AM   #29
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by 86TOYO2k17 View Post
Yes the Fluidampr is 5.8lbs but supposedly only 3.8lbs rotational (idk how that works) I saw a dyno comparing vs stock and light weight, and it actually lost about 1-2tq downlow and gained 1-2 top end.
Either way it seems to “protect” the engine from harmonics better then stock which seems beneficial if you are modded. Stock I think is 5.1lbs?
The DSS driveshaft is 2.75” diameter 12.1lbs, havnt found stock driveshaft specs from looking at it today (forgot to measure it...) it looks 2.75” for 2/3rds then the joint then 3” for 1/3rd of the driveshaft and 24.2lbs?
Assuming a 200 crank hp 170 whp 15% drivetrain loss. What % if any of that is the driveshaft and does lightening it reduce the loss?
The fluidampr has an inner ring suspended in a silicon fluid. It's a fluid damper rather than a semisolid damper. My guess is they don't count that inner disk as rotating weight as a marketing thing, even though the viscous forces would likely cause it to rotate anyway. I haven't looked at it too closely.
Not going to try and guess gains, especially since it's 1:45 am here and waaaaay past my bedtime lol. I'll get you real math-like numbers later.
Old 06-05-2018, 02:52 AM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Impureclient View Post
Since grilling steaks came up I must add that pan frying a steak is a very unorthodox but can produce some great results.
I have almost stopped grilling and have been pan frying all my steaks lately.
I watched a clip of that English cooking guy who swears a lot pan frying and after going pan, I'm hooked.
Is that pansexual because I've heard that word thrown around recently? I think I'm pansexual and I don't care who knows.
You should try a salt slab instead.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Sapphireho (06-05-2018)
Old 06-05-2018, 02:53 AM   #31
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Don't they crack under heat?
Old 06-05-2018, 02:56 AM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My friends wife bought one and has only used it a couple times. So far so good.
Old 06-05-2018, 03:17 AM   #33
Captain Snooze
Because compromise ฎ
Captain Snooze's Avatar
Drives: Red Herring
Don't forget the oil.
Old 06-05-2018, 04:08 AM   #34
Kodename47
Kodename47's Avatar
Drives: UK GT86
Has the crank pulley not changed for the MY17? If so, does Fluidampr have one for the facelift cars?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2018, 05:07 AM   #35
churchx
churchx's Avatar
Drives: 2014 GT86
Haven't heard of crank pulley being among changes. 99% sure that old pulley will still fit. ATIs one seems more interesting to me though, as it's also underdriving/smaller diameter. So less power spent on turning accessories, yet more dampening then solid lightweight alu ones.
Old 06-05-2018, 11:05 AM   #36
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
For underdriving the peripherals (e.g., alternator, water pump) you need larger diameter pulleys, not smaller ones.
Old 06-05-2018, 12:00 PM   #37
RayRay88
Drives: 2017 86 860 Special Edition
Inb4 math and physics can’t accurately model real life.
RayRay88 is offline   Reply With Quote
Old 06-05-2018, 12:27 PM   #38
twag4
Drives: frs
This is incorrect. The crank pulley being smaller means the other components spin at lesser RPM compared to engine rpm.
twag4 is offline   Reply With Quote
The Following 3 Users Say Thank You to twag4 For This Useful Post:
Capt Spaulding (06-06-2018), churchx (06-05-2018), NoHaveMSG (06-05-2018)
Old 06-05-2018, 01:10 PM   #39
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It's kind of like when you are stirring a pot of freshly made stew. The fluid is all rotational and physics-y, but all you care about is the soft chopped up potatoes, carrots, and beef. They add variables to the rotational mass right? I mean, they add mass regardless because the beef and veggies are converted to energy which is then either expended or stored in the body. But then it's sooooo tasty. But if you don't use a wooden spoon it's just not the same. Oh and fluid dampers help, right?
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
chaoskaze (06-06-2018)
Old 06-05-2018, 01:47 PM   #40
norcalpb
norcalpb's Avatar
I consider the fluidampr to be a preventivive mod, like oil cooler, baffle plate, fuel door etc.
Old 06-05-2018, 02:20 PM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is not how you do it. You keep the crank pulley same size and change the size of the other pulleys. You want different underdrive ratios per component. You might also need to not underdrive certain components. For example, I underdrive the alternator and not the water/coolant pump. You also need larger pulleys and not smaller. Let's not misinform people.
Old 06-05-2018, 02:24 PM   #42
humfrz
Smart move ……. since you tend to get all tangled up in your underwear late at night …..
humfrz
carbon fiber, driveshaft, dss, fluidampr, pulley
Fluidampr Damper Pulley 571101 Sale!! Mike@CZP Engine, Exhaust, Bolt-Ons 156 06-01-2018 01:24 PM
Lightweight crank pulley vs OEM vs Fluidampr by MotoIQ CSG Mike Engine, Exhaust, Transmission 49 11-20-2015 12:35 AM
Fluidampr Crank Pulley + NonStopTuning Accessory Pulleys | Group Buy Offer NonStopTuning Groupbuys 6 11-07-2015 08:51 PM
