Old 05-20-2018, 01:13 AM   #29
Tokay444
I should have known.
Old 05-20-2018, 02:41 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is Thunderhill west 2 inches of drop on 245's. Thunderhill numbers their corner's strangely so turn 2 is the left hander after the left kink off the straight and the double apex right. The front right would rub on turn 2. Never noticed any harsh bottoming on this track and the car felt stable, even over the turn 3 curb which is about 70mph. I am not saying it is ideal, and I plan to raise the car a bit. It was originally setup at a little over 1.5 inches of drop so it settled quite a bit.
[ame]https://www.youtube.com/watch?v=VugfHjSskxE[/ame]
The Following User Says Thank You to NoHaveMSG For This Useful Post:
GoZ21 (05-20-2018)
Old 05-20-2018, 07:31 PM   #31
GoZ21
GoZ21's Avatar
Drives: 2013 Asphalt Frs
well assuming you read the initial post, which i hope you did before commenting, you might have seen that height adjustability and durability were the only two requirements for a reccomendation and that this was also a daily (No need for “performance” in a 35 mph). Low cars dont have good ride quality and need supporting mods most of the time which I am BUDGETING for, however thats not a concern nor was it the question asked, I simply asked for reccomendations on coilovers in which case you have none, so no need to talk down on my personal style preference, thanks
GoZ21 is offline   Reply With Quote
Old 05-20-2018, 07:36 PM   #32
GoZ21
GoZ21's Avatar
Originally Posted by churchx View Post
Planned drop of >2"? That is almost halving stock ground clearance of 4.9" and if it had been stock shocks, it would leave 0.5" bump travel & ride on bumpstops (from ~2.5" bump travel including bumpstops & ~ 3.5" droop travel). Coilovers can do better for this case, but ..
I guess it's not worth to give any advises based on performance/handling/comfort & compliancy at this point. Extreme lowering car for very slammed looks is obvious priority to everything no matter illeffects.
I predict though that it won't be as simple keeping budget low though, as at higher drop levels much more parts need to be changed then just coilovers.
Lca’s with lower mounting points and supporting mods will definitely be included in the build thus the lower budget for coils, really appreciate you pointing out both sides tho something most people dont do lol
Old 05-20-2018, 07:37 PM   #33
GoZ21
GoZ21's Avatar
what is your setup? coils/lca/traction arms etc?
Old 05-20-2018, 08:26 PM   #34
churchx
churchx's Avatar
Drives: 2014 GT86
GoZ21: as minimum i suggest:
1) getting this whiteline front roll centre/bump steer correction kit to fix geometry
2) getting camberbolts front (eg. SPC 81305 and/or Whiteline KCA416) and LCA for camber adjustment addition
3) diff riser, so that cv joint angle is not that big, to reduce it's wear
4) depending on struts/coilovers height adjustment type, also maybe these.
.. or actually none of the above, but limit lowering to suggested by many with clue in suspension reasonable drop within 1", that won't fsck up geometry, will save you money, will leave enough ground clearance to not scrape car on many speedbumps and steeper driveways and will leave enough suspension travel and will not require uncomfortably stiff spring rates.
These cars are not deserving to make them worse :/
The Following 3 Users Say Thank You to churchx For This Useful Post:
GoZ21 (05-20-2018), Leonardo (05-20-2018), smg1138 (05-20-2018)
Old 05-20-2018, 11:10 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Tein Flex Z's
RacerX rear LCA's
RacerX rear toe arms
17X9 +38 with 245/40's
-3 Camber in the front, -2 in the rear.
GoZ21 (05-20-2018)
Old 05-21-2018, 03:13 AM   #36
Brzxton
Drives: 2015 Subaru Brz
If you are looking to get recommendations for lowering you car for a flush or stancy look i would highly recommend asking elsewhere. If you are looking for coilovers and setups for the track, however, this forum is a great place to refer to. I personally have more of a stanced car and have pbm coilovers 18k f/r (dont recommend if you want comfort) but i will be switching to some broadways pretty soon, stance lca’s, pbm diff and subframe risers, and pbm toe arms. Have -4 in the rear and -7 in the front. As for your original question, pbm’s are good if you are planning on getting lower control arms because they dont go very low in the rear. Imo i think spending the extra $600 and getting some broadways with custom spring rates would be the way to go. Just shoot them an email with your needs and how much drop you want and how comfortable you want the ride and they will hand build them just for you.
Brzxton is offline   Reply With Quote
The Following 3 Users Say Thank You to Brzxton For This Useful Post:
GoZ21 (05-21-2018), solidONE (05-21-2018), Tokay444 (05-21-2018)
Old 05-21-2018, 05:32 PM   #37
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Camber kit? o_O
Flex Z & Flex A sets include own camber plates.
Originally Posted by cjd View Post
I'd venture to guess the thought was to add rear LCA.
Getting all that stuff aligned will take some funds too.
I was thinking camber bolts for the rear and front to help clear endlinks for front and even out the rear camber left to right for the rear... Though, seeing he is trying to "stance" the car, some "drop" rear lower arms is probably a even better idear.
Intent > Content
Old 05-21-2018, 08:21 PM   #38
churchx
churchx's Avatar
Drives: 2014 GT86
solidONE: camberbolts for twins are for the front. No camberbolts for rear, where LCAs (or less commonly used options of UCAs or UCA eccentric bushings, with former non option due tight budget, and later - due PITA to adjust due press-in nature) are only camber adjustment options.
Old 05-22-2018, 12:47 AM   #39
solidONE
solidONE's Avatar
I'm currently using, and have been using for a couple years now, H&R camber bolts on the rear control arms. They've given about -0.5 to +0.5 of adjustment on either side. just enough to even out the camber using stock lower control arms.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
GoZ21 (05-22-2018)
Old 05-22-2018, 01:13 AM   #40
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm? First time hearing about that. Can you post part number or link to those? I have LCAs, so no need for them, but still seems interesting to find out.
Old 05-22-2018, 01:57 AM   #41
solidONE
solidONE's Avatar
I'm sure I've posted before multiple times about it. I'm definitely not the first to try it. H&R TC112 I've see other members here use the SPC bolts with similar success.
http://www.ft86club.com/forums/showthread.php?t=33415
Intent > Content
churchx (05-22-2018)
Old 05-22-2018, 04:07 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. Somehow missed that thread and was under impression that LCAs/UCAs/bushings are only options for rear. But from it it seems that there are no listed from manufacturer as "native" rear camber bolts somewhat fitting by size, only modified/reused front ones or from other cars?
coilovers
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 12:34 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
