Old 05-02-2018, 02:38 PM   #29
I have tried all of the "replacements" above, and surprisingly the cream cheese wrapper gave me the largest HP increase.
Well enough cream cheese opens me up as well so it makes sense.
Old 05-02-2018, 02:39 PM   #30
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I'm my tests, the Wrigley's gum wrapper barely beat the cream cheese, but it has to be Juicy Fruit.
Leonardo (05-02-2018)
Old 05-02-2018, 02:41 PM   #31
There is a driving around San Francisco joke in there someplace.
Old 05-02-2018, 02:44 PM   #32
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I hate SF. I avoid going there at all cost.
Old 05-02-2018, 03:07 PM   #33
humfrz
If I had a dollar for every old glass fuse I wrapped in foil from a cigarette pack just to get me home (which then stayed that way for weeks).
I found that spent .22 cal brass shell casings lasted longer .....
humfrz
Tcoat (05-02-2018)
Old 05-02-2018, 03:11 PM   #34
humfrz
Well I wanted something that at least had the possibility of melting if things went dreadfully wrong!
humfrz (05-02-2018)
Old 05-02-2018, 03:12 PM   #35
Leonardo
Country Boy 4 Life
Leonardo's Avatar
humfrz
Did you use a live round before trying the spent casing? If you had, I bet you would have known when the fuse blew!
I LIKE TIRES!
humfrz (05-02-2018)
Old 05-02-2018, 03:14 PM   #36
humfrz
LOL So next time somebody tells you that they gained HP through a fuse ask them to explain exactly what they think the science behind that is. Falls right into the same class as the magnets that people put on their fuel lines to "break up the fuel molecules so that it burns better".
Quite simple. The bigger the fuse, the more electricity can run through the circuit. The engine makes power by running. The faster an engine runs, the more power it produces. The ECU controls how fast the engine runs. The ECU is fused ..... so, the bigger the fuse, the more current runs through the ECU, thus making the engine run faster, thus making more power.
Get it .......??
humfrz
Old 05-02-2018, 03:18 PM   #37
humfrz
I didn't but Bubba did ....... shot his cousin, that was a passenger in his wrecker truck, right in the leg .......
humfrz
Old 05-02-2018, 03:19 PM   #38
Get it .......??
humfrz
That makes sense! Since the size of the circuitry in the ECU would now be the bottle neck for the electrons to get stuck I am going to get a bigger ECU. If I use one of these I should be able to get 1,000HP
Old 05-02-2018, 03:30 PM   #39
humfrz
I suggest you start with the 3 deuce system, till you get used to the extra power ....
humfrz
Tcoat (05-02-2018)
Old 05-02-2018, 03:49 PM   #40
humfrz
humfrz (05-02-2018)
Old 05-02-2018, 04:38 PM   #41
Imrac
Drives: 13 SWP BRZ Prem
This may actually work briefly... and depending on the fuse you pulled. Like if you pulled the ECU fuse, the reset may just mess up your fuel trims enough that it will lean out your AFR to get more power before it relearns that is is inducing knock.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 05-02-2018, 04:50 PM   #42
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Life is about perception...if you want a faster lap time or to beat someone at the lights...forget it...but if it 'feels' faster...go for it, because that's all down to you. Placebo is good.
Ever noticed how, when you drive to work sometimes, that depending on your sleepiness, the car seems faster?
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
trying to add some horsepower vitti821 Engine, Exhaust, Transmission 34 05-06-2017 05:47 AM
More Horsepower! joe strummer Scion FR-S / Toyota 86 GT86 General Forum 171 06-02-2016 03:29 AM
Toyota Improves 2015 GT86's Dynamics, Adds Shark-Fin Antenna in Europe vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 93 04-26-2014 04:31 PM
BRZ Limited adds Security System.. What? Sportsguy83 BRZ First-Gen (2012+) — General Topics 49 04-07-2012 12:49 PM
