Old 03-28-2018, 03:13 PM   #29
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Note that the Fujitsubo's ID gets rather tiny at the resonators.
Which part pinches in? I don't see it pinching in anywhere that appears abnormal.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-28-2018, 04:17 PM   #30
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Originally Posted by ajcarson11 View Post
I just came from a Greddy SP and now have the CSG Touring86. The CSG IS quieter, but not by much (I'd say 20% at most).
What kind of setup are you running? What made you make the switch and are you happy with the change?
I want to run stock exhaust except catback, really just looking for noise and trying to keep it legal (CA). I'm just hoping to get a little more noise, a little deeper, a little more "racecar". I'm looking to get an Edelbrock SC in the future and I do track the car a few times a year, so the exhaust being less restrictive is a bonus.
I like the sound of both, but the Greddy sounds a little more "racecar" at WOT. Is that true in person?
Horrid_Funk is offline   Reply With Quote
Old 03-28-2018, 07:09 PM   #31
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
33.6 lbs, 28 lbs, 36.4 lbs, 31 lbs, 33 lbs, 34.8 lbs vs 36
Only the miltek and borla are more than 3lbs lighter than the csg mxp, the rest are within 10%
@justinco is on the hunt for volume/weight and is looking at buying a fifth catback, I think he's looking at TRD now to make sound...
And I am about to give up at this point lol. I've done a LOT of testing of exhaust systems and various setups. Light weight and sound conforming is hard to accomplish without going custom. The custom exhaust I use today is basically 2.5" piping and a stock resonator, with a Magnaflow muffler. It's 26lbs, plenty quiet, and sounds good. It is ugly though and the fitment is not optimal (rattles against the tunnel).
What I really want to do is a new custom exhaust, with the stock resonator, and a similar Magnaflow muffler, but one that has a center inlet on the muffler - like a Perrin or TRD (minimize piping). I cannot find one of these mufflers by itself though to save my life, but if I do, I will make it!
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
Qadthane (03-28-2018), strat61caster (03-28-2018)
Old 03-28-2018, 07:13 PM   #32
ATaraxias
Drives: 1994 Geo Metro Hatchback
Catless [UEL] header with catted front pipe is still loud AF
If you pipe it through a Q300, it sounds like a choir of rumbly angels.
ATaraxias is offline   Reply With Quote
The Following User Says Thank You to ATaraxias For This Useful Post:
Takumi788 (03-29-2018)
Old 03-28-2018, 08:19 PM   #33
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I know it's not magnaflow like but spintech will custom make a muffler like that. Only manufacturer I know off hand that will run small batch custom jobs and not be insanely priced. Vibrant has a casing like that too and its a packed muffler.
I somehow lucked out and found a TRD muffler with tips and made a full 2.5 inch stainless catback with an slp resonator included.
The Following User Says Thank You to Summerwolf For This Useful Post:
justinco (03-28-2018)
Old 03-28-2018, 08:37 PM   #34
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks! TRD was the other one I was thinking about (and putting my own tips on) because I know those work from having it on my FRS. Miltek was another, but kind of expensive.
The Following User Says Thank You to justinco For This Useful Post:
Summerwolf (03-28-2018)
Old 03-28-2018, 08:48 PM   #35
Summerwolf
Panda Trueno
Summerwolf's Avatar
https://spintechmufflers.com/unique-...-fabrications/
Main picture on that page.... have no idea how that would sound, and the casings are not the lightest but I have always wondered, lol.
justinco (04-03-2018)
Old 03-28-2018, 09:18 PM   #36
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Tried that. Sounded like garbage lol.
I dont know if it was due to the mileage of the muffler or my specific set-up, but the q300 sounded like a Honda with a pea shooter before hitting VTEC lol
Tristor (09-19-2018)
Old 03-28-2018, 10:00 PM   #37
Skurj
Drives: SOLD...
Originally Posted by mav1178 View Post
Why not? Under 11lbs.
Not sure what you mean "why not?" I don't wish to spend $2k+ for a Ti cat back...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 03-28-2018, 10:04 PM   #38
Skurj
Drives: SOLD...
He did, however, mention a decibel limit, and if there's a limit, it's almost always gonna be 90dB. 93, 96, 98, 103, and 105 are also possible, but have increasingly higher costs associated.
Some AutoX venues also have limits, at which point options become very limited, with stock exhaust always being the cheapest option.
Ok, I am building for STX AutoX, but I also like to get some track time in and that limit is 92 db at one of the available venues.
There is some flex to that 92db limit, here are the rules:
Screening Test – After a brief visual muffler check, a stationary test is undertaken. Sound levels will be measured 15 feet in front and behind the vehicle while the engine is revved at the maximum allowable rpm or the red line of the tachometer.
Cars, the average should be no more than 100 dbA with no single reading over 104 dbA.
Motorcycles, the average should be no more than 98 dbA with no single reading over 100 dbA.
Pass-by Test – With the vehicle under full acceleration on the track, a reading will be taken from 50 feet. The maximum level allowed is 92 dbA. This level and standard is the most commonly used in North America and Europe and is where the entire industry is headed. Tests are valid for 9 months unless modifications to vehicle are made.
Paid for Mar 2018
The Following User Says Thank You to Skurj For This Useful Post:
CSG Mike (03-28-2018)
Old 03-28-2018, 11:21 PM   #39
I'm looking at one in front of me and it's the same ID as the rest of the piping.
It's not the same ID. Unfortunately I'm not at home to take a picture of mine...
Old 03-29-2018, 08:06 AM   #40
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
NO WAY! Did you have a resonated or catted front pipe? I have an OFH, invidia over pipe, invidia resonated front pipe and an Invidia Q300. To quote ATaraxias, it sounds like a choir of rumbly angels. That is the perfect way to describe that amazing sound.
I would have suggested my setup earlier in this thread but the Q300 is heavy heavy. And the OP is looking for something light.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
AbaoKu (01-05-2019)
Old 03-29-2018, 11:10 AM   #41
finch1750
finch1750's Avatar
Tomei UEL, Motiv OP, Berk catted FP, Q300.
I've heard other q300 set-ups that sounded better, but in my case it sounded terrible.
Old 03-30-2018, 05:33 PM   #42
mrg666
pessimistic skeptic
mrg666's Avatar
How about
The Following 3 Users Say Thank You to mrg666 For This Useful Post:
SuperTom (05-20-2018), weederr33 (03-30-2018), yberther (04-03-2018)
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
What is an loud exhaust Harvir Engine, Exhaust, Transmission 36 10-04-2017 03:12 AM
Exhaust Advice. I want a loud exhaust system please help Rambo2469 Engine, Exhaust, Transmission 28 04-21-2017 02:41 PM
How loud is the n1 exhaust? ( in db) jon2 Scion FR-S / Toyota 86 GT86 General Forum 7 02-22-2015 03:04 AM
My exhaust is loud mike2100 Mid-Atlantic 1 08-25-2013 09:13 PM
