#29 | |
Rugger Extraordinaire
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
| The Following 4 Users Say Thank You to thejevans For This Useful Post: |
#30 |
Drives: 2013 BRZ Limited
Well done!
#31 |
Drives: FRS :D
Did you get that from TiTAN by any chance?
I sent him my money but later found that he got banned which would explain the lack of communication from a otherwise really quick to respond vendor. have any contact info I could use?
Out of the FRS game
#32 |
Sallbaru
Drives: raven FRS
anyone in socal that has done this mod that can helped me do mine???its been a month since i received my pulley i already try 3 times to take off the stock pulley but i cant.the stock pulley keeps rotating everytime id try get it loose.ive done everything right,car in 6th gear,ebrake,brakes but the stock pulley rotates so i cant get it loose helpppppp
#33 | |
I Love custom Turbo kits
Drives: Limited BRZ
#34 | |
Drives: accord
though it wasnt easy, i was able to do it in under 30 min. I usually gets home around 8, let me know if you want to bring your car by. |
| The Following 2 Users Say Thank You to wu_dot_com For This Useful Post: | paintdude258 (10-21-2020), Sall (07-31-2012) |
#35 |
Sallbaru
Drives: raven FRS
like i said im doin everything right.but my stock pulley rotates way too much idk why
#36 |
Drives: Limited BRZ
How long is the breaker bar you are using?
#37 |
That Guy
Drives: 2013 asphalt FRS MT
I did mine the other day. The vast majority of what I did was the same as the OP's. The biggest difference though is that I didn't need to remove the filter box or sensor, only the intake tube.
My list of tools was sockets: 8mm, 10mm, 14mm, and 22mm. Also a ratchet, short extension, and a breaker bar. You may also need needle nose pliers to remove the PCV tube from the intake tube. Oh, and of course a small amount of oil. |
| The Following User Says Thank You to Calum For This Useful Post: | BabaYaga (03-05-2015) |
#38 |
Drives: Subaru BRZ
Also, make sure the O ring doesn't slip off.
#39 |
Drives: Whiteout Scion FR-S
Great DIY! I wonder if you could use anti-sieze on the crank pulley bolt instead of motor oil. [Speaking here from the land of road salt and sand.]
#40 | |
-Put the car in neutral -Put the beaker bar with socket on the pulley -Move the breaker bar as far CLOCKWISE as it will go -Put the car in sixth -Pull the breaker bar COUNTER-CLOCKWISE and you should have enough room to break the bolt loose even with the play in sixth Good luck. |
#41 |
Drives: accord
we tried 24" breaker (the longest avaliable at autozone). no help. he and i were going at it for at least an hour.
we think the problem is something his friend did to the car during his first attempt. we crank the bolt so hard that the car even rotate while the bolt just stay dead on. as a last resort, we even spray some WD40 on the bolt head flange hoping it would loosen it up... no luck. im now thinking perhaps kroil might help... |
#42 | |
Drives: accord
we tried something similar, like releasing the break and let the car roll for a bit in 6 to get a good grip... no luck... perhaps your methond is better and worth a try. |
| The Following User Says Thank You to wu_dot_com For This Useful Post: | Sall (08-03-2012) |
| Tags |
| brz, crank pulley, diy, frs, perrin, raceseng |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 04:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 11:24 PM |
