Old 02-25-2018, 09:43 PM   #29
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by DesertLava View Post
But if you tune for 4000ft and have shorter pulleys then go to sea level you can over boost and blow your engine. Read CSG Mike post above.
It's safe to run sea level tune and pulleys and just deal with the loss at 4000ft. But a tune and pulleys for 4000ft would definitely risk blowing the engine at sea level. Unless you want to run two different tunes every single day you would have to change pulleys at sea level for a 4000ft optimized tune or sacrifice performance at elevation with a sea level optimized tune.
Sent from my Nexus 6P using Tapatalk
How much power are you looking for? I rode in a guys car a while ago, made 340hp to the wheels and he DD'd it around 40 miles one way. Stock motor. Based on what you are saying in your OP that is more then what you want even at elevation.
Old 02-25-2018, 10:00 PM   #30
DesertLava
Drives: '17 Hot Lava
270/200 at elevation and whatever that means at sea level is more than enough for me.
DesertLava is offline   Reply With Quote
Old 02-25-2018, 10:13 PM   #31
new2subaru
Weight Weenie
Drives: 15 FR-S
Perhaps saying that I was okay with NA performance at sea level is adequate was a mistake. If I'm paying $5,000+ I'll want some performance improvement. Not chasing numbers, as it is my DD. But some improvement will be welcomed. Not planning to track it and be competitive at least until I can replace it's DD duty with a Tacoma.
I would just buy a CARB legal kit with tune and call it a day. I'm sure you will have plenty of power for your needs. Most are in the 250WHP range give or take.
Old 02-25-2018, 10:59 PM   #32
Sounds like a bolt-on kit is perfect for your needs.
Old 02-26-2018, 01:23 AM   #33
FRS Justin
Drives: 2013 Asphalt FRS
What this guy says.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-26-2018, 02:55 AM   #34
Harey
Drives: 2013 Toyota 86
I think the thread was asking which kit. Looks like turbo is confirmed.
What are your preferences on the kit DesertLava? You will be able to choose a pretty basic kit to satisfy those power goals.
Harey is offline   Reply With Quote
The Following User Says Thank You to Harey For This Useful Post:
DesertLava (02-26-2018)
Old 02-26-2018, 02:57 AM   #35
DesertLava
That's where I have no real idea. I'll have to do a lot more digging and visit local shops who can advise me on the decision.
I'm lucky enough to be local to CSG and Delicious Tuning but there are so many turbo kits out there. Looking for the most solid stage 1 kit available. Don't know if there is a popular consensus among this forum as to which kit that is. I also need to figure out if my car being automatic will cause any additional researching.
Old 02-26-2018, 03:11 AM   #36
Harey
So reliability is high on the list, does it need to be carb legal? What fuel?
Old 02-26-2018, 03:35 AM   #37
DesertLava
CARB legal, yes. Fuel I pump 91 in Southern CA. Typically Costco or Chevron.
Old 02-26-2018, 04:32 AM   #38
Then you're stuck with WORKS, and... well... the only selling point of it is that it's CARB legal.
It makes CARB supercharger levels of power, but with turbo lag. You're better off going supercharger.
DesertLava (02-26-2018), x808drifter (02-26-2018)
Old 02-26-2018, 03:48 PM   #39
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Also sounds like your gonna have to pay someone to install this for you.
All in your gonna be near 6-8K for cost.
The Following User Says Thank You to x808drifter For This Useful Post:
Old 02-26-2018, 06:02 PM   #40
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
This.
Only CARB legal turbo for our cars is from WORKS. And its a 6000$ kit. And only roughly makes 220-240 whp on 91 pump.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
CSG Mike (02-26-2018), DesertLava (02-26-2018)
Old 02-27-2018, 05:03 PM   #41
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
A question from another view point...
It sounds like you are asking for MAX power both at high elevation AND at sea level. Or am in misunderstanding it and you want MAX power at sea level and simply MORE than stock power at elevation?
If you are in the inland empire (Redlands to Ontario) you are more than welcome to take a ride in my supercharged (Harrop, but Edelbrock is same) 2017 (manual trans). We can even zip up to Big Bear to test elevation. I haven't even had a chance to do that yet myself.
PhyrraM is offline   Reply With Quote
Old 02-27-2018, 05:15 PM   #42
This sounds fun.
does OFT have a specific tune for any catted header? frs_caskey Software Tuning 48 11-17-2017 03:15 PM
OFH OFT Tune Octane Specific GVegas Software Tuning 2 04-18-2017 08:16 PM
Help selecting Coilovers, for my needs :) Mikeez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 83 12-14-2014 03:58 PM
Need help Selecting a Body kit ImpressiveWrap Southern California 6 12-16-2013 05:20 PM
Selecting new wheel help Biggdogg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-15-2013 07:13 PM
