Old 02-08-2018, 03:23 PM   #29
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Originally Posted by PSim View Post
You think? I feel like by by the time I pay for labor and an alignment I might not come out ahead.
If you were to take it to a shop to do the swap, then you are correct. I had just assumed it would have been a DIY swap. Alignment would be needed regardless though.
BigTuna is offline   Reply With Quote
Old 02-08-2018, 03:32 PM   #30
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I wonder if the previous owner installed LCA's as well. I think you should just get the car, then if you don't like the Flex Z's, offer to swap them locally for a stock suspension. I'm sure there will be takers.
shiumai is offline   Reply With Quote
Old 02-08-2018, 03:45 PM   #31
Originally Posted by ImAdopted View Post
im in a pickle cause i want to be able to adjust it but also dont know how i can maintain and look for things loose or broken lol
Just ask your self this question and be truly honest to yourself - Will I actually ever adjust them?
It has been my past experience (including myself) that maybe, on a good, day, being really optimistic, only about one person in ten ever changes the setting on coil overs once they are installed. If you are not looking to adjust or not after that certain track related setting that you can only get by having adjustment then a good set of springs and struts is plenty and they don't require near the maintenance that adjustable do.
Old 02-08-2018, 03:46 PM   #32
This ^
Just make sure that if you are unable to do the job yourself you say the labour is included in the deal and you totally break even.
Old 02-08-2018, 04:23 PM   #33
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
to be honest no lol, i would only adjust if say i go up to 18's but once i got my wheels and desired ride height that would be it for me aha, it was just trying to keep up with them is my issue as suspension and most car things im still learning about
ImAdopted is offline   Reply With Quote
Old 02-08-2018, 04:32 PM   #34
Going to 18s would not require you to change the suspension height unless you had the wrong size tires on it. The overall diameter of the tire would be the same you just have less sidewall.
ImAdopted (02-08-2018), Leonardo (02-08-2018)
Old 02-08-2018, 04:38 PM   #35
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
just when you think you understand basic knowledge you end up rereading lol
The Following User Says Thank You to ImAdopted For This Useful Post:
Tcoat (02-08-2018)
Old 02-08-2018, 05:14 PM   #36
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I think what you mean is "if I go with wider wheels" because coilovers only give wheel/tire clearance benefits when you go with something wide in the front with higher offsets.
The Following User Says Thank You to mav1178 For This Useful Post:
Old 02-08-2018, 05:30 PM   #37
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
sorry yes thanks, thats more clear with what i wanted to say lol
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 12:34 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
