Old 11-26-2012, 01:35 PM   #29
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Originally Posted by nashsnazzy View Post
Is there no vapor barrier behind the door panel / card? If there is can someone tell me what sort of adhesive is used?
There is and the adhesive is butyl im guessing..
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 11-26-2012, 03:21 PM   #30
Daless2
Nice write-up!
Thanks for posting it.
Daless2 is offline   Reply With Quote
Old 11-26-2012, 08:53 PM   #31
nashsnazzy
Drives: 2013 Scion FR-S White Out
Boo, is there an easy way to get that off and not get high as a kite?
nashsnazzy is offline   Reply With Quote
Old 11-26-2012, 10:15 PM   #32
-max-
Drives: Firestorm FRS
There is a layer of clear plastic with the normal black goo sticking it on.
Just pull it off fast and it comes off pretty easy. Got it all off and did not use anything.
-max- is offline   Reply With Quote
The Following User Says Thank You to -max- For This Useful Post:
nashsnazzy (11-28-2012)
Old 11-26-2012, 11:02 PM   #33
Norkoastal
Norkoastal's Avatar
Yup the sticky goo pulls off better with a nice tug.. Didnt notice any noxious fumes from the goop..
CO>CA Cartel
Old 11-28-2012, 04:24 PM   #34
nashsnazzy
Oh that is so great to hear. I'll order some CCF and get ready to do my door speaker install.
Old 11-28-2012, 05:45 PM   #35
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I've always called them Door Cards. I know that Edd China calls them cards as well, so
Nice writeup!
Move to the DIY section?
Old 12-05-2012, 02:52 PM   #36
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Excited to use this technique to install Dynamat on the doors.
slizoth is offline   Reply With Quote
Old 01-10-2013, 05:09 PM   #37
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Step by step removal of the door panel.
First there are 3 screws that need to be removed.
First is inside the door handle.
Second 2 are under the door pull handle.
So first you must pull off the trim piece that covers the screws. Start at the bottom.
The 2 screws are behind.
Last thing to remove is the clip in the upper forward door. Just use a flathead screwdriver to pop it out.
Now you just pull the door panel off. There are a bunch of clips inside and it takes quite a bit of force to get off.
Once you get it loose you will have to diconnect the cables that hook to the lock and door handle.
Last thing holding on are the wire plugs connected to power window and locks.
Just out of curiousity, when you pull the silver part off from the door handle and take the screws out, does the black padding come off as well?
abutterman is offline   Reply With Quote
Old 01-26-2013, 12:38 AM   #38
Pandle
Drives: CBS BRZ
No. Anyway I'm having trouble getting the actual panel off. I've removed the silver trim and the 3 screws plus the plastic piece near the front of the door but I just can't get it off. Is there a certain spot I should start at? Possibly a video tutorial or a picture of what it should look like where you start pulling it off at?
Pandle is offline   Reply With Quote
Old 01-26-2013, 01:25 AM   #39
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Anyone have a picture of the whole door right after panel removal? I would like to see how much plastic is on there. Is everyone putting the plastic back on the door when finished, if so how?
Cade01 is offline   Reply With Quote
Old 01-26-2013, 07:01 AM   #40
-max-
Where every you can get a grip. Just give it a sharp pull. If that doesnt work, pull harder. Repeat.
Old 01-26-2013, 11:25 AM   #41
Fever
Drives: '13FR-S Ultramarine 6MT
Here's a cheap tool that will help pop the plastic plugs out.
Or the link to it because I don't think the image insert worked for me.
http://http://imgur.com/wm4v93C
Edit: The link may not work either, it's a panel pry tool, can be found at any automotive shop.
Fever is offline   Reply With Quote
Old 02-05-2013, 02:33 AM   #42
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
How do you take of that silver trim piece on the handle???
Minovsky is offline   Reply With Quote
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 12:55 PM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 07:38 PM
Scion boost card? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 30 08-01-2012 10:20 AM
Buying a car on credit card? SteelReign Other Vehicles & General Automotive Discussions 8 06-25-2012 01:54 AM
FR-S Badge Removal skoodge Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:46 AM
