Old 01-24-2018, 02:24 PM   #29
Tokay444
The logic of retaining the zero is sound.
Old 01-24-2018, 02:26 PM   #30
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Right. Viscosity difference of having 0w vs 5w only really comes into play well below freezing temps.
Originally Posted by Tokay444 View Post
Which is 2 degrees above freezing.
Keep telling yourself that over and over, and eventually in your head it might become true.
Originally Posted by humfrz
I'm old and lazy
Ultramaroon (01-24-2018)
Old 01-24-2018, 02:37 PM   #31
Tokay444
The operating range of 40 stops well above freezing. So what is it you're suggesting he change to? 5w40? 10w40? 20w?
Old 01-24-2018, 02:40 PM   #32
Clipdat
Proud of BOXER
Clipdat's Avatar
I don't think you understand how motor oil works, so I'm done discussing this with you.
I'm old and lazy
Old 01-24-2018, 03:00 PM   #33
Tokay444
I'm quite versed in how motor oil works, though I'm starting question your knowledge base, so please, continue.
Old 01-24-2018, 04:11 PM   #34
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I have had this same debate with friends on more than a few occasions. Yes the operating temp to necessitate the 0w is much cooler than zero, however the thought is the oil will still flow around the engine faster and more efficiently during a cold start around 0 c than a 5w-30 which would be slightly thicker thus reducing wear and tear. Now I probably could switch to 5w-30 but it isn't like 0w-30 is going to harm anything. Until I get a used oil analysis myself I will defer to what mobil 1 recommended for the engine which is 0w-20 and 0w-30 for daily driving. I'm more concerned with cold start up wear and tear than running out of viscosity at higher temps which is unlikely since I don't plan on running this oil on track. However I do leave the option that the 5w-30 may be better suited but from the research I have done the 0w-30 I've been running seems to be adequate protection, this will be confirmed after the oil analyses.
My thinking is now that my engine is above 70k I may run 0w-30 in winter and then switch to 5w-30 for summer. Depending on my used oil results.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Tokay444 (01-24-2018)
Old 01-24-2018, 09:26 PM   #35
Zentec
Drives: 2017 Toyota 86
For cold starts.
They say cold starts in the OM the real reason is for fuel economy ratings and brackets. Hence why almost every new Toyota has 0w20 oil Tuck Camery Prius ect dosent matter. All comes down to Fuel economy.
Zentec is offline   Reply With Quote
Old 01-25-2018, 12:21 AM   #36
Tokay444
The oil isn’t cold long enough for the 0 to have any affect on fuel economy.
The 20 is for fuel economy.
The Following User Says Thank You to Tokay444 For This Useful Post:
Zentec (01-25-2018)
Old 01-25-2018, 09:30 AM   #37
Zentec
Yes this is true as the 0 represents the cold weather tempature heance why it says for cold start. 0 acts as that viscosity at that tempature range. The 20 represents the viscosity at normal engine operating temperatures. But the time is not relevant as un less your in artic temperatures you will never reach that range. They give everyone 0w20 so they can sell to all countries and be covered and get the kick backs for more models that fit the fuel economy bracket.
Subi designed the tolerances to reach that 40 weight. So if your climate dose not reach the temps in your OM for the 0 run the 5w30 and be better off as you will have better protection. If you really track your car and keep it high load or do some crazy thing like FI then you should be at the 40 weight and have at minimum an oil cooler and temp gauges for it. It reall comes down to your climate and driving style/ application if you need an the higher weight oils.
Old 01-25-2018, 11:52 AM   #38
Tokay444
Subi designed the clearances to reach that 40 weight. So if your climate dose not reach the temps in your OM for the 0 run the 5w30 and be better off as you will have better protection. If you really track your car and keep it high load or do some crazy thing like FI then you should be at the 40 weight and have at minimum an oil cooler and temp gauges for it. It reall comes down to your climate and driving style/ application if you need an the higher weight oils.
And how long you'd really like the engine to last. The 20 isn't in there for it's protection benefits.
Zentec (01-25-2018)
Old 01-25-2018, 01:51 PM   #39
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Out of curiosity. Are we sure about this? What is the information source? I'd really like to believe it since in my motorcycle daze I ran Shell RTS 5w-40 in just about all the bikes with good results. In my part of the world it seldom drops below 40F. It does, however, get over 100F every day for several weeks a year and the highs exceed 95 for 4 to 5 months. At some point, I may want to switch.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 01-25-2018, 02:06 PM   #40
Tokay444
The fact the Japanese manual, referenced in this thread tells you you can use 5w40 would be a good indicator.
Zentec (01-25-2018)
Old 01-25-2018, 03:18 PM   #41
Zentec
Nope your right it’s not in there at for protection it’s in for eco.
Personally as long as it can it’s a Subaru and Toyota so baring anything major and regular mantaince is done it will last for well over 100k they make quality stuff.
I have a friend in japan that works for Subaru so he sent me the pic of the brz OM that’s how I got the info straight from the source.
The Following 2 Users Say Thank You to Zentec For This Useful Post:
Capt Spaulding (01-25-2018), Tokay444 (01-25-2018)
Old 01-25-2018, 03:25 PM   #42
Zentec
I live in the desert I see upwards of 110f after my oil change I will be running 5w30. Once I get some extra cash I will be running an oil cooler. So your part of Texas your fine with the 5w30. If you track/race it the they recommend the racing oil that’s why it’s there. But for protection wise you will be fine with 5w30.
Alternate way to open hood Bjack21 Issues | Warranty | Recalls / TSB 21 02-06-2017 08:01 AM
Alternate center caps for RPF1? JGalp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-13-2016 12:49 AM
An alternate to OEM Audio + that's actually affordable BMHumanic Electronics | Audio | NAV | Infotainment 24 02-28-2014 06:28 PM
DIY - Alternate Hood Prop F1point4 DIY (Do-It-Yourself) Guides 13 03-20-2013 10:22 PM
Alternate car? ngabdala Other Vehicles & General Automotive Discussions 35 05-18-2012 01:09 PM
