Old 11-16-2017, 10:16 PM   #29
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by tehShirt View Post
Lots to love in this thread, can't wait to see it all finished.
What are your plans for the exhaust?
Thanks! Me too!
Headers from Vorshlag, build my own mid pipes, haven’t decided if it’s going to be dual 2.5”/3” or a single 3.5”/4” to a Corsa 14785 axle back exhaust for a 2016 and newer camaro SS.
https://www.summitracing.com/parts/cse-14785blk
Tightest area is at the rear around the diff. The 8.8 is much larger than the stock diff and cuts down on the available room for exhaust to be routed around it.
I’m sure I’ll be using some oval exhaust pipe to work it out.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
tehShirt (11-18-2017)
Old 11-18-2017, 10:44 AM   #30
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by ILLSMOQ View Post
Thanks! Me too!
That is bound to sound lovely, Corsa makes excellent products.
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
ILLSMOQ (11-18-2017)
Old 11-24-2017, 06:06 PM   #31
ILLSMOQ
Decided on true duals. 3” back from the headers to a corsa x-pipe
https://www.summitracing.com/parts/c...SABEgJuVfD_BwE
and then into a 2016 camaro axle back kit which is 2.75”
https://www.summitracing.com/parts/cse-14787blk
Of course it isn’t just gonna fit
Now it should
Once the exhaust gets here, I’ll start mocking it up and figure out what needs to happen with the rear subframe at the lower control arms.
DustinS (11-27-2017)
Old 11-27-2017, 03:23 PM   #32
ILLSMOQ
2008 ZO6 k&n intake
I’ll have to cut it down to make it fit.
Hawk77FT (11-27-2017)
Old 11-27-2017, 08:34 PM   #33
ILLSMOQ
There’s a good amount of room to work with. I want to figure out some sort of rigid mount for the filter side.
The Following 3 Users Say Thank You to ILLSMOQ For This Useful Post:
T-Steve (07-30-2023), wutsaiu (11-28-2017), Zer0 (11-28-2017)
Old 11-28-2017, 11:49 AM   #34
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
You're doing God's work sir.
This BRZ is going to fly.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following User Says Thank You to Bowen For This Useful Post:
ILLSMOQ (11-28-2017)
Old 11-28-2017, 09:54 PM   #35
cf6mech
Drives: FRS Silver LS1 swapped.
Your Corvette intake was my next project, was hoping someone would tackle this before me.
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
Old 11-28-2017, 09:56 PM   #36
cf6mech
Doesnt seem to line up to well with the throttle body.
Old 11-28-2017, 10:54 PM   #37
ILLSMOQ
It’s hard to tell from the pics...it’s actually pretty close to being where it needs to be. I ordered a few different 4” 45 degree elbows, some rubber, some silicone and a metal one. I’m certain I need to cut a couple more inches from the k&n duct...once the elbows get here I’ll continue with the project.
There is about a one inch tall pinch weld/seam on the front top part crash bar. I’m going to remove that, which should give me even more room and angle of attack on getting things lined up nice and clean...if I have to I can cut into the crash bar even more.
Old 11-29-2017, 10:11 AM   #38
gtpvette
Drives: 2015 FRS - FFR GTM
Awesome build.
Two questions if you don't mind. I'm obsessing about driveline angles on my build. In particular the engine/transmission angle. Now that your mounts are in,,, have you put an angle finder on your transmission to see the angle???
I'm planning true duals as well. Based on your pictures, after removing the shield from the gas tank,, the both sides are recessed from the factory allowing a pipe on each side????
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
ILLSMOQ (11-29-2017)
Old 11-29-2017, 10:32 AM   #39
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by gtpvette View Post
Awesome build.
His Pinion Angle is at ~1.3 degrees. (More precisely 1.2 on diff and 1.3 on Trans)
He removed the heat shield, then used a large pipe in conjunction with heating the tank to push it in to clearance it for the exhaust.
@ILLSMOQ Hopefully you don't mind me answering those questions.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Old 11-29-2017, 11:11 AM   #40
gtpvette
Driveline angles are right on the mark. I'd like to hear more about the reshaping of the tank if you wouldn't mind sharing as it solves some problems.
Old 11-29-2017, 11:41 AM   #41
ILLSMOQ
Awesome build.
I don’t have all the measurements on the driveshaft angles but yes both the transmission output and differential input angles are pretty close to being equal.
As for the gas tank...I was wondering when someone would ask, no the other side isn’t recessed and this was a tedious project. Wrecked the first tank so I had to buy another one and was successful.
Basically heat, a large steel pipe and some pressure.
This tank leaked at the heat sheild Mount
I was careful with the heat shiel mount area on the next one
Tested the tank with gas to make sure it didn’t leak then I wanted to reinforce the area. There aren’t many(any?) epoxies that are fuel proof or any RTV or silicones either.
I did find something though, aviation fuel tank sealant. “Pro Seal 890b 1/2” it’s a two part epoxy style substance. Kind of rubbery. They use this stuff to seal fuel tanks on airplanes. Found a lot of good information online where it’s been used and tested in senarios other than airplane fuel tanks. My tank didn’t leak but I wanted to have some added security against a fuel leak.
I laid it in really thick.
Also want d to make sure it had heat protection but after messing with the factory heat sheild a few minutes I scraped that idea.
I called Heat shield products and they recommended their HP shield with the sticky back
There is room for a 3.5” pipe to fit maybe even a 4” I’ll be running a 3” through there
I realize this isn’t the ideal way to solve the exhaust problem but I’m gonna run with it and i’m confident it will work out great. The exhaust should be here Friday.
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
DustinS (11-29-2017), Zer0 (11-30-2017)
Old 11-29-2017, 11:48 AM   #42
ILLSMOQ
No worries @DustinS you’ve been a huge help through out the project!
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 12:10 PM
Pure Automotive's 2017 Race and Show Schedule Pure Automotive Mid-Atlantic 4 01-21-2017 01:07 PM
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 07:11 PM
Pure automotive pre meet KslayFRZ Mid-Atlantic 0 07-19-2013 12:32 PM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 03:07 PM
