Old 01-11-2022, 02:59 AM   #29
tomm.brz
Drives: brz 2017 hksv2
it s directly the ECM (engine Ecu), it is inside the plastics in front of the passenger seat
The Following User Says Thank You to tomm.brz For This Useful Post:
x808drifter (01-11-2022)
Old 01-11-2022, 12:21 PM   #30
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Page literally mentions the ECU and you didn't bother to look at that?
This does not bode well for someone boosting their car.
Old 01-11-2022, 07:22 PM   #31
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
were can I get this adapter??
Originally Posted by DeliciousTuning View Post
Steve,
Look a bit closer. The rear 02 connection is a pass through to get clean power/ground without fuss. There is a bare lead to run to the ECM for CPC signal input, sized to appropriate length. CPC input was the entire premise behind us making this OFT compatible kit.
-Zach
how can I get this adapter to tap my CPC input on my BRZ???
G_Rossney is offline   Reply With Quote
Old 01-11-2022, 07:30 PM   #32
G_Rossney
Yes, I was looking. It didn't help that there is a very large wire loom hiding it. I had to really get in there and dig to find it. I was hoping someone would be nice enough to give a little insight as to where it is and the best way to tap into the CPC input.
Last edited by G_Rossney; 01-11-2022 at 07:31 PM. Reason: Wanted to add an image to post
The Following User Says Thank You to G_Rossney For This Useful Post:
Jaden (01-13-2022)
Old 02-02-2022, 01:35 PM   #33
G_Rossney
Okay, I've got the Delicious Tuning OFT Flex Fuel Kit installed and connected to the CPC input on the ECU. I've checked and double checked that it's the right lead in the block and that there is continuity from the D-Box CPC lead through the ECU block connector.
I'm getting the P0037 CEL, I'm guessing it's from the fact that the O2 sensor is disconnected to power the Dbox. It looks as through people are keeping the O2 sensor connected and simply tapping the O2 sensor for the power.
Is that the solution to the P0037 CEL??
Old 02-02-2022, 02:47 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Need to disable that CEL in the tune.
Old 02-02-2022, 08:51 PM   #35
G_Rossney
so, OFT needs to send me a different Tune that disables the CEL. Cool.
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
Delicious tuning flex fuel kit DIM HAWAIICALIVEGAZ Engine, Exhaust, Transmission 0 05-16-2016 03:49 AM
Delicious Tuning Flex fuel kit themooseisloose Engine, Exhaust, Bolt-Ons 26 05-01-2015 12:46 PM
Delicious tuning flex fuel brz23 Great Lakes 2 03-06-2015 08:53 PM
Delicious tuning flex fuel brz23 Software Tuning 4 03-05-2015 01:28 PM
