#29 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
![]() Its turbos that generally have lag.
I like driving!
| The Following 2 Users Say Thank You to 86 South Africa For This Useful Post: | funwheeldrive (10-19-2017), new2subaru (10-20-2017) |
#30 | |
Drives: '12 C63 P31, '23 GRC
I can't stand the stock gearing of my 987S. All Boxsters/Caymans suffer from that problem. I think 2nd gear in the GT4 tops out around 85 mph. And then on the flip side 5th and 6th gears are kinda short. At the last track event I went to I spent 70% of the time leaving it in 3rd gear. So boring.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#31 | |
Drives: '15 BRZ RA
Not an easy task to have a car everywhere optimal and be able to hit 175 mph. |
#32 |
Not sure why you think that. They're really not that similar.
Overall gear ratios (gear x final drive) for a BRZ (pre-2017) are as follows: 1st - 14.866:1 2nd - 8.97 3rd - 6.314 4th - 4.973 5th - 4.10 6th - 3.145 Same for 987 Cayman S: 1st - 12.84 (14% taller) 2nd - 7.57 (16% taller) 3rd - 5.47 (14% taller) 4th - 4.38 5th - 3.76 6th - 3.18 Only thing similar about the two cars are their top gears, and that means even the BRZ is geared for 170 mph . It also means the Cayman as a similarly high cruising engine speed, which isn't great for efficiency when that's a 3.4 liter engine lol .There's a very simple explanation for why the Cayman's gearing is this tall - so that it's not competitive with the 911. For example, here's the 911's gearing from a year comparable to the above 987. Keeping in mind, that usually a more powerful car (i.e. this 911) has taller gearing: 1st - 13.45 2nd - 7.98 3rd - 5.366 4th - 4.403 5th - 3.715 6th - 3.027 It's quite obvious from comparing the 911 to the Cayman that the Cayman was intentionally given taller 1st and 2nd gears so as to not accelerate as fast (or faster) than a 911. In fact just about all Cayman S/GTS's use identical ratios, even the Cayman GT4's gear ratios for 1-4 are actually identical to my own car's. Primary difference being the GT4's redline is 600 rpm higher. Hope I didn't bore anyone with this post.
#33 | |
junior mafia
Drives: 20 sti limited
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
#34 |
Not exactly related, but after owning your Cayman would you ever own another 86, or has the Cayman made you never want to go back?
I probably would have bought a used Cayman a couple years ago if I didn't need to put a baby seat in my car. I still think about buying one though. |
#35 | ||
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
I think this would be better to show that, while you have more horse power, the effective horse power you have at certain speeds is mitigated by the gearing. While the combined demonstration of acceleration or velocity/time may be more available, i think showing the metrics of available effective power is a better view of what you are sacrificing with more power by longer gearing. However, it should be noted this is why more torque would be more important at lower speeds, as those curves are generally flat. Quote:
** There are a lot more factors involved other than just metric performance for that reason, however. |
#36 | |
Thanks, what are you driving now? Mustang? |
#37 |
Old Guy
Corvette C5 Z06 is one of the vehicles I have which I am making the comparison.
I am looking to sell another car and move into a BRZ with the performance pack or into an older BRZ. I have a long history of Subarus, however (8+). None currently or directly with FR-S/BRZ other than co-drives. GC/GM6 RS owner ship I think is the most directly comparable. |
| The Following User Says Thank You to dowroa For This Useful Post: | funwheeldrive (10-20-2017) |
#38 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
It depends on what you want from a car, purpose, build, etc. I have owned 4 BRZs all in different configurations (not at the same time), and I have owned 5 different Cayman/Boxsters (again, not at the same time). Car buying is not a "financial" progression. Okay, it starts off that way....but I jump all over the place on the financial side of it. I pick platforms that I want to experience and give me an X-factor of some type. I have owned a GT4, its awesome....most capable care I have ever tracked. But, I still love to get into a 15 to 20k BRZ and rip on it. For a number of reasons. Do I dare say that I have more fun in Miatas,BRZs, S2000s than I do some of the Porsches. YEP, I can say that. Now...sometimes only a Porsche will do. My comments may not make sense to some...probably the younger crowd. So let me put it this way....lets say the Porsche is a supermodel that you finally had a chance to date. Shes hot, makes you feel good, you may even love her....but she is expensive, and costly if things go wrong. Sex is good, but you don't get it very often (cause on the roads you cant exploit the P-cars very well) .....now there is the BRZ. The girl next door. Pretty, athletic, APPROACHABLE, and truly loves you without needing to empty your wallet. I say experience both, as for which you prefer.....its personal taste...and I promise your taste will change and evolve. But, don't ever think that you should only move up the money ladder when buying cars. That's too boring. A Porsche can do a lot of things that the BRZ can't, but the BRZ has great points to be made that a Porsche can't touch either. Hoep that makes sense.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
| The Following 7 Users Say Thank You to brzaapi For This Useful Post: | brandonblt2 (10-24-2017), funwheeldrive (10-20-2017), new2subaru (10-20-2017), strat61caster (10-20-2017), Submarinesonce (10-20-2017), Subsonic (10-20-2017), WolfpackS2k (10-20-2017) |
#39 |
Oh yeah, I totally get what you mean. I've driven/owned cars a lot faster than my FRS and I think a lot of my friends were confused when I bought one new. To them it looked like I was moving backwards when I could have bought an almost new Mustang GT or 335i for the same price. I've owned a lot of cars over the years and I could quickly tell that the 86 platform was something special in its own right.
But, I wasn't sure if the Cayman was basically a BRZ+. For example, I used to own a 1998 Neon ACR. It was loads of fun for what it was, and great to daily drive. A couple years later I found a bone stock 1999 GSR for sale and bought it. The Integra ruined the Neon for me. It was everything the ACR tried to be, and more. I wasn't sure if I would get a similar feeling if I ever bought a Cayman. Before I bought my FRS I rented an Elise for a week to see if I wanted one. Sure it was a blast, but I still picked the FRS at the end of the day. They similar cars, but completely different at the same time. Thanks for your input. I have never driven a S2000 or Cayman, but they are on my bucket list of cars to drive for sure. |
#40 |
I actually have considered making a switch back to the BRZ. I like the way it looks, love that it's slightly more practical, and I would feel less guilty racking up mileage on a BRZ. Shifting between gears is more enjoyable in the BRZ as well. But I really, really don't like the FA20 engine. The Cayman's flat six power and smoothness is addictive, and gets taken for granted of by me way more than it should.
I suppose that, ideally, if I found a well sorted BRZ that already had forced induction I would definitely consider it. In the near future I want to participate in more HPDEs and I think that would be easier to do with a BRZ than my older Cayman. I also sometimes think about going back to an S2000. Problem there is that I really don't fit in that car. To be comfortable in one I'd have to put in an aftermarket seat with lowered rails. And to track it I'd also have to install a rollbar, which if tall enough to protect me, would be too tall for the soft top to work. So it would basically be a hardtop only coupe at that point. Thus that's unlikely to happen. And then there's my wildcard option, my unicorn. An LS swapped FD RX7... ![]() All this though, is not to say I haven't enjoyed ownership of my Porsche. I love the looks, I love the handling, I love the power, and the steering directness and feel is out of this world! It's been relatively maintenance free, as I've only needed to have it at the dealership once over the last 4 years. Problem is, the car is now almost 12 years old and just a few thousand miles from cracking the 100,000 mile mark. I'm 95% certain the car is still on it's original clutch and that's a $3000 job at a shop (and I don't have the skill set for that work). And then the shocks and suspension bushings are starting to show their age...ugh. IF (big IF) Honda came out with a new S2000 (that wasn't some hybrid-dual clutch transmission only powertrain) or Subaru came out with a turbo BRZ I would consider either very seriously as replacements for the Cayman.
| The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post: | funwheeldrive (10-20-2017), Tcoat (10-20-2017) |
#41 | |
idk I feel like LS swapping an RX-7 is like having a prettier Corvette that was designed in the '80s, a C5+ should be better in every objective way provided the powertrains are equal. And before you say interior the FD is notorious for having an interior that hasn't held up, an FD with a nice interior is more of a unicorn than an LS swapped FD :P |
#42 |
The FD is one of my favorite designs ever. Honestly I'd be perfectly happy with an FD with the original engine as well. The FD is one of the best handling cars ever built and the LS engine swap doesn't upset that balance much. Done properly you still have a car that's several hundred pounds lighter than a Corvette.
| BRZ vs Cayman/Corvette | Norcalkid | FR-S / BRZ vs.... | 128 | 01-31-2017 01:36 PM |
| Twins vs Cayman/Boxster 211 | botbs | FR-S / BRZ vs.... | 15 | 10-06-2014 11:09 AM |
| 2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 08:03 PM |
| FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 05:17 PM |
| GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-28-2012 12:26 AM |
