Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-25-2017, 03:08 PM | #29 |
Drives: 2017 BRZ
09-25-2017, 03:25 PM | #30 |
Panda Trueno
Drives: No twin now.
I am willing to bet this is out of the norm for either company. It is interesting to see the responses here though ranging from thinking ceramic coating is a cure-all for heat to wanting to blame the manufacturers immediately. While parts failed, it is a bushing in a part of the car that almost retains heat while also being in close proximity to heat. Stuff like this happens when you track a vehicle and / or drive it aggressively for long periods of time. Bushings wear out, all of them do. This is a severe instance, and definitely a new one on the forum, but it does not mean it is a call to burn ACE and whiteline at the stake. Obviously there are many members with products from both companies that have not had this same kind of issue. I'm not sure who is running both the swaybar and the header in conjunction, and this may simply comedown to a compatibility issue between two companies that design completely different products. Just saying.... take a step back and maybe not instigate a witch hunt quite yet.
The Following User Says Thank You to Summerwolf For This Useful Post: | CSG Mike (09-25-2017) |
09-25-2017, 03:38 PM | #31 | |
Drives: 15 BRZ LTD, 05 FXT
I think in looking at this, I'd be tempted to replace the bushing, reinstall the header and confirm clearances, then see what play the components have to gain extra clearance 'here and there'. My guess is that repairing the ceramic coating on the header, and making a small shield you can tack weld to the sway bar bushing bracket with a small strip of DEI reflect a gold would resolve your issue. #justRacecarThings
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | strat61caster (09-25-2017) |
09-25-2017, 03:39 PM | #32 | |
Drives: between cars...
09-25-2017, 04:14 PM | #33 |
I've melted the sway bar bushing and steering tie rod boot on the track too, with a different setup. My issue was an exhaust leak.
The Following User Says Thank You to mkivsoopra For This Useful Post: | B T (09-28-2017) |
09-25-2017, 06:38 PM | #34 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | imnotsureaboutbrz (09-25-2017) |
09-25-2017, 07:05 PM | #35 |
I took this picture last week while doing some maintenance on my 17. Ace A/350 w/ CSG double ceramic + flex fuel tune.
The Following User Says Thank You to CSG Mike For This Useful Post: | Ultramaroon (09-28-2017) |
09-28-2017, 11:19 AM | #36 |
I just replaced the bushing with another one from Whiteline. I'm guessing it must have been an exhaust leak spilling gases directly onto the bushing. I found one bolt at the collector to frontpipe location missing on the bushing side. I did not ever hear any exhaust leak, but I'm posting this as the cause for now.
New exhaust bolts and heat wrap installed. I'll have a track day in early November and report back on any further damage. |
11-10-2017, 02:13 PM | #37 |
Drives: 2017 Toyota 86 M6
I had the same problem on my 2017. Gruppe s ceramic coated headers and overpipe and my oem bushing starts melting (not as much as you tho). When ill install my new front swaybar amd engine mount ill do a heat shield for it or either gonna wrap the exhaust. I have no exhaust leek btw. Not much track i inly did 4 run of autocross but sometimes i drive my car 7-8hours straight and i drive it hard so might be that
Similar Threads | ||||
Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 05:32 PM |
Clutch Release Bearing Melted | Haulin | Engine, Exhaust, Transmission | 37 | 05-29-2016 06:35 PM |
Buddy Club Tails Damaged/Melted? | Krazy | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-07-2016 11:11 AM |
Perrin exhaust with added benefit of melted plastic | s30series | Engine, Exhaust, Transmission | 3 | 09-12-2014 08:44 PM |
Muffler delete on track (melted bumper?) | celica73 | Tracking / Autocross / HPDE / Drifting | 12 | 04-01-2014 04:27 PM |
