Old 05-25-2017, 09:46 AM   #29
Somerandom18
Drives: 2017 manual BRZ
I inject vodka into my engine.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 05-25-2017, 06:56 PM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You risk detonation by using straight vodka. I would suggest mixing it with 50% orange juice.
Somerandom18 (05-25-2017)
Old 05-25-2017, 11:51 PM   #31
BadMOFO
BadMOFO's Avatar
Drives: 2016 Scion FRS Raven Black
TONIGHT Harry!
BadMOFO is offline   Reply With Quote
Old 05-26-2017, 12:02 AM   #32
BadMOFO
BadMOFO's Avatar
Originally Posted by COO86L View Post
I haven't used the NX plate kit but if I was still going Nitrous, I would be using it.
Make sure you run a window switch as a lot of people have said. I'd run a window switch and throttle position sensor through an auxiliary control module such as the Garage 7 IPC unit.
I'd honestly go a little higher than 50hp shot. It's easy enough to do, and you'll NEED to log AFR when you're hitting nitrous to make sure your kit is adding enough/not too much fuel with the nitrous. Changing spark plugs would be the hardest job. Maybe reduce timing by 2 deg on WOT. I'd be running a different map for Nitrous on EcuTek.
Properly set up nitrous isn't cheap. Window switch, pressure gauge, purge system, wiring, bottle heater. All are essential for a safe running Nitrous system and all will run you quite high in price.
Thank you.. this is the kind of information I'm seeking, not shoulda bought this or that.. i know what I have. I know what I want. I just want to do it right. Seems to me running nitrous isn't any riskier than running water meth. If you have proper fail safes. And take the proper measures to ensure it's used proper I honestly think it is one of the best bangs for your buck. It certainly isn't the $500 a kit costs. But is still the 1/4 a cost of a average FI setup.
I don't need to have 275whp all the time. I truly enjoy driving the car spiritedly with the piwer it has, but like anyone else.. who doesn't enjoy a little more from time to time. I know where I sit in the food chain. I just think it would be fun to surprise someone from time to time when this little 200hp NA car goes full retard and we flip the MOOREE POWAHH SWITCH! Lol.
Old 05-26-2017, 03:47 AM   #33
allowe
allowe's Avatar
Do a I/h/e/t and call it a day. That's my setup and I freaking love it. No need to race v8s. If you really wana beat those ****heads, build your motor and drop a huge turbo. Yea it's costly but it's worth every penny
allowe is offline   Reply With Quote
Old 05-26-2017, 09:00 AM   #34
stevesnj
stevesnj's Avatar
Don't throw a screwdriver into the works now.
My 2016 Build thread
The Following 6 Users Say Thank You to stevesnj For This Useful Post:
8RZ (05-26-2017), Captain Snooze (05-26-2017), lantsalot (05-26-2017), MuseChaser (05-26-2017), Tcoat (05-26-2017), wparsons (05-28-2017)
Old 05-26-2017, 10:23 AM   #35
Do you really think it is going to go "full retard" by flipping a switch?
You truly believe that all is needed is a $500 kit to turn you into Paul Walker?
Fast and Furious was a movie not a technical how to or a documentary.
You are in for a world of disappointment.
8RZ (05-26-2017), brzcui (04-12-2019), Cole (05-26-2017), Detroiter (05-26-2017), lantsalot (05-26-2017), wparsons (05-28-2017)
Old 05-26-2017, 11:35 AM   #36
gtengr
Drives: 2017 BRZ
The thing with nitrous is it will generate more torque than a blower, and the rods are really weak on this engine.
If you're only looking at a 50 shot I think it would be cheaper and easier to do header/tune/E85 (assuming you can get E85). I'd just get the supercharger. You'll have a lower risk power that is available all of the time, make more power, and it will have good resale.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
stevesnj (05-26-2017)
Old 05-26-2017, 11:37 AM   #37
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
At the risk of stating the obvious, I'm not sure a switch is necessary in this case...
Given Paul Walker's current status, I'm pretty sure that goal could be achieved even without the $500 kit. I'm hoping, of course, that that is NOT the goal.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 3 Users Say Thank You to MuseChaser For This Useful Post:
Cole (05-26-2017), Tcoat (05-26-2017), wparsons (05-28-2017)
Old 05-26-2017, 11:46 AM   #38
But it is a "MOOREE POWAHH SWITCH" or more accurately a button I guess. I have seen it used! You just push it once and your car doubles in speed instantly.
See:
lantsalot (05-26-2017), MuseChaser (05-26-2017), wparsons (05-28-2017)
Old 05-26-2017, 12:21 PM   #39
Misfire
Misfire's Avatar
Drives: 2017 Series.Yellow, 2005 LGT wagon
But be wary of DANGER TO TEH MANIFOLD!
Misfire is offline   Reply With Quote
Old 05-26-2017, 12:25 PM   #40
Or they will need to rip apart the block and replace the piston rings that get fried.
Old 05-26-2017, 02:02 PM   #41
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
I'm curious if anyone has gone balls out with building a fully forged FA20 potentially a closed deck or sleeved setup and put a massive shot of nitrous in it. Surely some people making 700+ on well built FA20's they are strong enough to hold a good amount of torque. A 200 shot of nitrous would provide a lot of torque to our lacking motor and be potentially much cheaper than a turbo setup.
I'm thinking it would just require upgraded fuel pump to feed enough fuel to the rails and the wet nitrous plate but should be relatively simple to setup.
Or it could be the complete opposite I'm no nitrous expert.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 05-26-2017, 02:23 PM   #42
lantsalot
Derp
lantsalot's Avatar
Hopefully his manifold doesn't fall through the passenger's side floor!
EDIT: Looks like @Misfire beat me to it
lantsalot is offline   Reply With Quote
The Following User Says Thank You to lantsalot For This Useful Post:
Tcoat (05-26-2017)
Nitrous Express, Nitrous Plate mrk1 Engine, Exhaust, Bolt-Ons 5 09-06-2017 11:37 PM
Should I go with Nitrous go_a_way1 Forced Induction 78 02-10-2016 04:23 PM
Nitrous build dallenj Forced Induction 34 08-01-2015 04:27 AM
nitrous? ender2664 Forced Induction 48 06-13-2015 11:36 PM
nitrous eindio Forced Induction 17 09-22-2012 02:09 AM
