#29 | |
Drives: frs
#30 | |
TRACKBREAD
A properly designed and manufactured header will not fail because of thermal stresses. A ceramic coating will reduce the max temperature delta and thus stress/strain due to differences in CTE between components. Every header I've seen crack on here has been due to bad welds. Each OFH that cracked and was documented here showed a crack propagating from a fisheye in the weld. The OEM one looks to have cracked in the heat affected zone as well. Coatings have nothing to do with it as long as they're applied correctly. That's why is recommend getting the header coated from the manufacturer. OF doesn't offer that, so I went with JDL Sent from my iPhone using Tapatalk |
#31 | |
Drives: 2013 FRS
As for reported OFH failures, I can count all of them on one hand. And we have sold close to 1000 of them in the past 4 years. And most of those failures were seen on units that were stolen and sold before they even went through the QA process which means they should not have even been sold in the first place. In this case, the unit lasted 2 years despite an improper implementation of a 2800F ceramic coating. Years ago, we sold ceramic coated headers for the Subaru 2.5RS. The only thing was that the ceramic coating wasn't very effective. it looked nice but didn't do much in the way of thermal shielding. As a result, it was a pretty benign option. These days, there are ceramic coating options that work very well. And care must be taken in using them. |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | strat61caster (05-04-2017) |
#32 | |
TRACKBREAD
Crack in My ofh
Thanks for your insight shiv. I don't have any numbers to back up my gut feeling, but wouldn't tracking the car cause much higher header temps than the ceramic coating alone would? I might have to borrow an IR camera and compare external temp at the header and EGT temps between mine (coated) and my friend's car (uncoated) to see the how much of a difference we're talking about. Sent from my iPhone using Tapatalk |
#33 | |
I don't think there is anybody in this thread saying coatings are bad. If you draw a resistor network to calculate the heat transfer rates you will see that coating just the outside traps heat in the metal, you don't even have to know any equations or plug in numbers, it just doesn't allow the metal to reject heat to the engine bay, which is typically the goal, but as a consequence the header saw increased temperatures. It's more common to see coating of the inside of the header for a reason, that's what will reduce not only engine bay temps but the temp of the metal as well lowering the thermal stresses. https://www.centuryperformance.com/e...o-not-use.html http://www.ft86club.com/forums/showp...1&postcount=10 |
#34 | |
TRACKBREAD
Oh absolutely! No question about the mechanism at work, but depending of the coating performance, how much are we really talking about? If the delta is 50F, that won't do a thing considering running the car hard for long will bring the header temps up hundreds of degrees anyway. If it's 150F it might be a different story. It'd be nice to see come data for us engineering pedants. :P Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | strat61caster (05-04-2017) |
#35 | |
Drives: 2013 FRS
#36 | |
TRACKBREAD
Makes sense. The IR data compared to the egt might tell a story, but I agree, the IR data itself is useless. Sent from my iPhone using Tapatalk |
#37 |
Alternative to thermal coating header is to adjust radiator fan activation temps and vehicle speed setting in tune.
You biggest problem is bunderbonnet heat at low speeds in traffic, once your doing say ,60kmh plus there enough air flow to keep things cool. Ive run uncoated header with adjusted fan settings no issues for three years |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | FISHBURGLAR (05-04-2017), Tcoat (05-04-2017) |
#38 | |
86
No problem, debate is a healthy part of democracy and freedom of speech, I respect that and you. I won't go in to the sordid details of my bad customer service experience with OFT but I promise you, it wasn't good at all. I now go to other sources(on the forum) for tuning help and advise. Seems strange that this needs to happen, going to somebody other than the vendor for help with their product? Respect Shiv and his busy times however if you can't support your customers adequately, you need more staff to do so. It may cut in to your profit margin but will ensure positive feedback(and more sales) in the future. Peace out |
| The Following 2 Users Say Thank You to Boomerang For This Useful Post: | FISHBURGLAR (05-04-2017), Tcoat (05-04-2017) |
#39 |
Drives: whiteout fr-s
Just to add this in here. I did make a mistake making the claim that it was just coated externally to shiv as that is what I thought and remember. I called jet hot and had them pull my receipt. They had me coated inside and out.. btw not looking for a change in his response I'm past it. Just for reference
Btw car strictly daily driver. 0 track time. Last edited by FISHBURGLAR; 05-04-2017 at 09:01 PM. |
| The Following 2 Users Say Thank You to FISHBURGLAR For This Useful Post: | -Phil (05-04-2017), strat61caster (05-05-2017) |
#40 | |
Drives: Subaru BRZ
At this point, ACE, JDL and PTuning have (in my opinion) the best exhaust manifolds for the twins. Sounds like you'll want to re-invest. |
| The Following 2 Users Say Thank You to SpectreRT For This Useful Post: | allowe (05-06-2017), FISHBURGLAR (05-04-2017) |
#41 |
Jdl uel was ordered today with ceramic coating. Lifetime warranty and good torque for daily driving, and good price. Already have adjusted ots tune 93 for these.once they come in I will install asap, and redo the exhaust. Will make custom exhaust, and add a flex pipe towards the middle where catback should meet front pipe. As A safety measure. New grimspeed gaskets, and vibrant gaskets for exhaust.
Going for simple, not to loud, and cut weight. Thank you all for staying attentive. |
#42 | |
I have now made the full adjustment as per your recommendation. I had the fans to kick on at a higher temp. But I lowered it even more as per your post. The fans will now be on under 60 kmh |
| Header crack question | alchemis | Engine, Exhaust, Transmission | 3 | 04-07-2016 03:36 AM |
| Random Windshield Crack | Superman | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 07-14-2014 04:14 PM |
| Crack in the glass.. | Miss_Red | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-27-2013 01:06 PM |
| Advice for this crack and scratch? | noc | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 02-26-2013 07:43 PM |
| Anybody crack open the oil filter yet? | Bonburner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-20-2012 02:42 PM |
