Old 04-25-2017, 01:49 PM   #29
pevsfreedom
Drives: 2014 BRZ
Originally Posted by Wyattkb View Post
Where do these little rubber washers go that you speak of?
You actually can remove the plastic reverse lockout piece. There is a small pin near the top that you can tap out and then it just slides off. I did this and added some extra grease in there.
Yeah I'm curious too. And that's interesting I'll give that a try... the 450g shift knob made a HUGE difference.
pevsfreedom is offline   Reply With Quote
Old 04-25-2017, 03:10 PM   #30
SubaruLifer
Drives: 2015 ISM BRZ Premium
Originally Posted by pevsfreedom View Post
I did not and wasn't sure what those were for.. I lost them, but I just remember they were small o-rings or were they rubber washers the size of the stock black one?. Do they go against the washer/pin? Yeah I didn't think you could take that off. Mine bothers the hell out of me unless I'm blasting death metal. Mine's in all gears. It's not really noticeable under 3000 rpm but it's definitely there. I have really good hearing =[
What is weird to me is when I pull up the lever the noise goes away. I'm positive I've installed everything correctly, besides ripping off the dust cover =/. I also bent the little "dust cover" that goes on the bottom of the shifter (from the stock one, probably from messing around with the whole assembly so much), which I can't for the life of me find a part # for but doubt it'd cause a metal rattle sound.
They go on the control shaft linkage. I'm guessing you both used the DIY on this forum for the install--they weren't included with the shifter originally, but if you jump to the last few pages of that thread, others talk about them.
SubaruLifer is offline   Reply With Quote
Old 04-25-2017, 04:06 PM   #31
pevsfreedom
Drives: 2014 BRZ
Are they just o-rings or rubber washers? Did you fit both on or just one? And did that clear up the rattle? Thanks. Yeah I used that DIY.
(i lost them)
Old 04-27-2017, 09:36 AM   #32
SubaruLifer
(i lost them)
I didn't put them on, but it sounds like your rattle is worse than mine. Based on comments in the DIY thread, it seems like most people could only fit one but it did help with the rattle.
FS: Kartboy Shortshifter byun Transmission and Driveline 12 01-26-2016 12:28 AM
[FS]RCE Yellows, Kartboy UDP, Kartboy shifter stay bushing Calum Brakes, Suspension, Chassis 11 11-03-2015 07:19 PM
shortshifter with stock reverse lockout? enjoi23 Engine, Exhaust, Transmission 1 04-03-2014 05:33 PM
>> Kartboy Sale - 10% off all Kartboy Items at RallySportDirect.com!! << RallySport Direct Announcements, Contests, Giveaways 1 07-17-2013 09:28 PM
BPS Shortshifter for FRS review gonzo Engine, Exhaust, Transmission 16 12-14-2012 09:42 PM
